Welcome to the North American Subaru Impreza Owners Club Saturday February 6, 2016
Old 10-10-2012, 01:18 PM   #126
M45
Member#: 333446
2013 Impreza SL CVT
Originally Posted by 79letour View Post
I still lol at VAG!!!!
I snicker.
M45 is offline   Reply With Quote
Old 10-10-2012, 01:22 PM   #127
kenny doggins
Member#: 326540
2012 Impreza MT SP
Originally Posted by flyboy1100 View Post
What didn't work? The brake override or heal toe?
yeah i wonder too, if you're not properly heel-toeing or rev-matching your downshifts, you are totally missing out on some higher points of MT driving
kenny doggins is offline   Reply With Quote
Old 10-10-2012, 01:25 PM   #128
flyboy1100
Member#: 314216
2012 2.0i Sport 5MT
i double clutch most downshifts but i have never been able to figure out heal-toe. the pedals in our jetta are too close for my big feet and the impreza is supposed to be disabled anyway.
i might try it today when i go driving.
Old 10-10-2012, 02:15 PM   #129
kenny doggins
Member#: 326540
2012 Impreza MT SP
It's got nothing really to do with your heel, it's more like you're slowly braking with the left side of your foot, then blipping the accelerator with the right side of your braking foot, to match revs and downshift. Basically braking while you downshift. It's rad for entering corners, and you'll get that aha moment when you are practicing this as you approach a red stoplight, as it turns green when you reach 2nd gear and you can just gas it cause you're already in gear.
Also handy for saving your brake pads by using engine braking. Good for offramps, downhill turns, etc. It's great.
Old 10-10-2012, 02:15 PM   #130
sgoldste01
Member#: 322264
2012 Impreza Sp 5sp
Obs Blk Prl/Drk Gray Mtl
Why do you double-clutch your downshifts?
sgoldste01 is offline   Reply With Quote
Old 10-10-2012, 02:20 PM   #131
flyboy1100
Member#: 314216
2012 2.0i Sport 5MT
easier for me to rev match that way.
Old 10-10-2012, 02:22 PM   #132
kenny doggins
Member#: 326540
2012 Impreza MT SP
I might have to try this too. Hmm
I find the boxer is great for those blips, since you get it up around 3,500 and it just hangs there for a moment. Pretty forgiving that way
Old 10-10-2012, 07:22 PM   #133
RoyB
Member#: 316190
I think I might drive my car to work tomorrow. It's been a couple weeks since I even took it out of the garage. Maybe a month now?
RoyB is offline   Reply With Quote
Old 10-10-2012, 07:27 PM   #134
n00b on demand
Member#: 158355
2012 Sport 5MT
Anyone change out their stock shift knobs? Post pics!
n00b on demand is offline   Reply With Quote
Old 10-10-2012, 07:29 PM   #135
subiTWO
Member#: 273054
2012 Impreza CVT HB
Expect you can't press gas and brake at same time because of the brake override
You *can* do a brake-stand for at least a second or so, for a quicker launch in a CVT.
subiTWO is offline   Reply With Quote
Old 10-10-2012, 07:31 PM   #136
subiTWO
Member#: 273054
2012 Impreza CVT HB
Originally Posted by M45 View Post
I'm not sure if I can simulate a heel-toe type smooth downshift with the CVT - it would be interesting for someone with heel-toe experience (which I do not have) to try out.
The throttle gets a little blip during a downshift, but there's also a jolt of slow-down. So there's no double-clutching type behaviour available.
Old 10-10-2012, 07:42 PM   #137
Zeeper
Member#: 299286
2015 WRX CVT
I just ordered one of these:
http://www.ebay.com/itm/280805114119...84.m1497.l2649
4.5 ounces. The red version is cheaper, but I don't like red.
I'll let you know what I think after install.
Zeeper is offline   Reply With Quote
Old 10-10-2012, 07:52 PM   #138
subiTWO
Member#: 273054
2012 Impreza CVT HB
On one of my favorite dirt roads I didn't feel the cvt loaner car did as well as my mt. A couple times I swear I could feel the car losing grip and then the rear would grab, but it didn't have the same predictability that the mt has. Ymmv
The stab control will interfere long before you get the rear much out of line. I get mine jumping on during hard cornering on *dry* pavement from road bumps. You can't have sideways fun in this car...
Old 10-10-2012, 08:00 PM   #139
subiTWO
Member#: 273054
2012 Impreza CVT HB
Shifting points are going to differ with drivers, but usually, you want to shift once the torque has peaked to fully harness the acceleration potential.
Actually, you usually want to shift after the HP peak, because the lower gearing multiplies torque in the lower gears. You can see this in a graph of wheel-torque vs road speed. I don't have torque, but here's HP from my bike:
You want to shift where the lines cross. BTW, those rpms are the same using either T or HP.
Old 10-10-2012, 08:03 PM   #140
subiTWO
Member#: 273054
2012 Impreza CVT HB
Originally Posted by auskip07 View Post
Its also been documented and stated in many places that 4800 is the peak of the hp/ tq curve
This is what I got measuring my car and calculating 'road horsepower':
My car absolutely pulls hard past 6000 rpm.
Old 10-10-2012, 08:21 PM   #141
flyboy1100
Member#: 314216
2012 2.0i Sport 5MT
Yes. I got a lathewerks stainless sphere and then i leather covered it. weighs in at 1.2lbs
I redid this and it is tighter and better fitting now it feels great and is exactly what i wanted
Old 10-10-2012, 08:26 PM   #142
flyboy1100
Member#: 314216
2012 2.0i Sport 5MT
I tried to heal toe today, i am not good at it, bit it does seem possible. Just another thing that is incorrect in the manual i guess
Old 10-10-2012, 08:28 PM   #143
M45
Member#: 333446
2013 Impreza SL CVT
what does the button turn off? something else?
Old 10-10-2012, 08:28 PM   #144
flyboy1100
Member#: 314216
2012 2.0i Sport 5MT
Traction control
Old 10-10-2012, 09:43 PM   #145
auskip07
Member#: 315643
2012 Impreza Sedan
DGM 5mt
What did you use to get that?
auskip07 is offline   Reply With Quote
Old 10-10-2012, 09:48 PM   #146
auskip07
Member#: 315643
2012 Impreza Sedan
DGM 5mt
Originally Posted by Zeeper View Post
Where is the 90/10 split documented? I've seen it on Cars101. Anytime the split is brought up someone with a CVT states they heard Subaru of Canada claims 60/40.
http://www.awdwiki.com/en/subaru/
I dont see our specific model. Given that the point was the squeeze as much MPG out of the vehicle it wouldnt surprise me that 90/10 is used. Since its an electronic controlled clutch it can be set to what ever they desire from the factory
ratios
80/20
60/40
are also mentioned
Old 10-10-2012, 10:11 PM   #147
sgoldste01
Member#: 322264
2012 Impreza Sp 5sp
Yup, I replaced my plastic knob with an OEM Subaru leather knob (for a WRX, I think), with the proper 5-speed shift pattern shown on top.
In addition, I wrapped my steering wheel with a Wheelskins leather cover. I did this not only because I like the feel of leather, but mainly because I couldn't stand the feel of the groove that Subaru molded into the plastic steering wheel. Whatever idiot decided to add that groove as a way of stylizing the wheel should be shot.
Here's the thread with pics of both the shift knob and steering wheel:
http://forums.nasioc.com/forums/show...ght=wheelskins
Old 10-10-2012, 11:02 PM   #148
RoyB
Member#: 316190
I thought it wasn't workin for awhile too, but then I tried holding the button for a SUPER long time, then the way it describes in the book works fine. It was like 20 seconds or so. Use the force
What the heck am I doing wrong? start the car, hold the button down for like 25 seconds and it just turns off. I let off the button and I hit the button again within 2 seconds and absolutely nothing happens. no light goes back on or anything. I cant even get the traction light to go back on. What part am I missing?
Old 10-10-2012, 11:45 PM   #149
WStrembitsky
Member#: 323877
2012 Impreza Limited
ratios
80/20
60/40
are also mentioned
This states that the CVT does have a 60/40 split. I guess when Subaru Canada posted that information on their website it wasn't just lies from the marketing department.
WStrembitsky is offline   Reply With Quote
Old 10-11-2012, 08:49 AM   #150
Zeeper
Member#: 299286
2015 WRX CVT
Wiki is not a reliable source of information. Why? Because it is a collection of information submitted by whomever wants to submit it, and corrected by whomever wants to correct it.
Generally Wiki works well, but if the material is not linked to a reliable source it is not reliable.
For all you know, Subaru of Canada marketing department quoted 60/40, and someone added it in the wiki document.
So show me the test data!
