Old 10-05-2012, 04:37 PM   #1
FrankWhizzite
Member#: 317178
2009 Impreza
Spark Silver Metallic
Default Help with wiring
Can anyone who has installed their own sound system please help me out with figuring out where to run the power cable from the battery to the amp? Specifically finding or making a hole in the firewall to get the wire through....
FrankWhizzite is offline   Reply With Quote
Old 10-05-2012, 04:41 PM   #2
FrankWhizzite
Member#: 317178
2009 Impreza
Btw 2009 2.5i... Sorry forgot to add that
Old 10-05-2012, 06:07 PM   #3
tru scoob
Member#: 309011
2012 wrx
swp
That's how you do it. find a spot with no obstructions, get a proper size hole saw or unabit and watch the metal fly
tru scoob is offline   Reply With Quote
Old 10-05-2012, 07:08 PM   #4
blessthekellen
Member#: 273859
MY98
WRX
blessthekellen is offline   Reply With Quote
Old 10-05-2012, 07:29 PM   #5
FrankWhizzite
Member#: 317178
2009 Impreza
hmmm thats the only way huh? i was a little skeptical about this but i gues it is what it is!
Old 10-05-2012, 07:31 PM   #6
FrankWhizzite
Member#: 317178
2009 Impreza
can i assume that if there are no obstructions on the engine side, there will be none on the interior side?
Old 10-05-2012, 07:37 PM   #7
ChesterWRX
Member#: 328794
2012 WRX Premium
Ice Silver Metal
there is a rubber boot that you can go through on the passenger side and the cable will feed in right under your glove box. -that's what i did.
also, there is a hole behind the intecooler on the driver side, but i didn't go that route. -i'll be tapping that one tomorrow to install my boost guage though.
ChesterWRX is offline   Reply With Quote
Old 10-05-2012, 07:43 PM   #8
ChesterWRX
Member#: 328794
2012 WRX Premium
Ice Silver Metal
ETA: pics
like i wrote in my previous post, it will feed in underneath the dash. you can route the cable along side the doors *or* along the center console. i suggest the center route as it's easier to unistall and the carpet removes easier.
Old 10-06-2012, 07:59 PM   #9
dsn112
Member#: 332561
2016 WRX LTD
That is just about the last resort. There is always factory locations with rubber grommets you can use. Never came across a car without them.
dsn112 is offline   Reply With Quote
Old 10-06-2012, 08:28 PM   #10
gunz4me
Member#: 305130
2013 GTI
Candy White
I ran mine through the driver's side fender. Didn't get any pics of pulling the fender liner to run it though. It was a royal PIA too.
gunz4me is offline   Reply With Quote
Old 10-06-2012, 09:43 PM   #11
tru scoob
Member#: 309011
2012 wrx
swp
You'll be hard pressed to get anything bigger than 4g wire through the"only" accessible factory grommet on the pass. side. at least on the later model wrx's. Stinger makes a nice compression style firewall grommet for 1/0g and looks much cleaner IMO.
Old 10-06-2012, 09:52 PM   #12
tibug
Member#: 273906
2006 VTECAccordVTEC
Also it has VTEC.
I ran mine through the driver's side fender as well. This is on my '03 Outback, but there was a perfectly sized hole for the wire on the side of the engine bay directly in front of the battery to run it into the fender, then I just ran it into the kick panel, under the factory plastics and out to the cargo area. I don't think I was able to find an existing grommet big enough to run it through the firewall, but this worked out well and kept the engine bay cleaner (not that I really care about that).
tibug is online now   Reply With Quote
Old 10-07-2012, 06:04 PM   #13
djinn
Member#: 212818
2010 Impreza 2.5i
Satin White Pearl
I'm in the Brooklyn Area if you need help with it i can give you a hand. I ran mine through the driver side firewall. 4ga kicker wire.
djinn is offline   Reply With Quote
Old 10-13-2012, 12:14 AM   #14
FrankWhizzite
Member#: 317178
2009 Impreza
I see the cable thats attached to the hood latch runs in the fender, I'm gonna see if I can go alongside that
