Old 10-25-2012, 01:41 AM   #101
ans2k
Member#: 315631
2012 Impreza Sport
i wonder if you could put a 35 watt bulb in there.
ans2k is offline   Reply With Quote
Old 10-25-2012, 07:12 AM   #102
jr0bb5
Member#: 315353
2012 Impreza Sp Prem
5MT OBP/DGM
Originally Posted by ST Eye
There was a member on here that had HIDs in his fog lights, he said that it heated up too much and cause the housing to get hazy. The stock bulb is a low power low heat bulb.
Yeah, I def wouldn't suggest HIDs in the stock fog housing... I was referring to headlight bulbs. Guess it slipped my mind that this was a discussion on fog lights.
jr0bb5 is offline   Reply With Quote
Old 10-25-2012, 02:54 PM   #103
Blackmamba24kb
Member#: 330797
2012 Impreza 5dr Prm
Satin White Pearl
no need to buy bulbs if you want the yellow look....LED wont help much imo...just buy yellow film and wrap the housing lens.
Blackmamba24kb is offline   Reply With Quote
Old 10-26-2012, 06:20 AM   #104
pkL
Member#: 313093
2012 Impreza 2.0i
5-door Sport. Dark Grey
I've read a post where 35w HIDs were installed in the stock fog light housings and they caught fire and burned most of the bumper away.
pkL is offline   Reply With Quote
Old 10-26-2012, 08:01 AM   #105
ST Eye
Member#: 73068
2008 STI Boost Wagon
2014 Honda Accord Hybrid
You probably read the thread where an owner of a 06-07 STI did that. That was faulty wiring that caused that. It was NOT because they were HIDs. You can put HIDs in the glass/metal housing foglights on the previous Impreza. I had a set in my STI and it actually ran cooler than the halogens.
ST Eye is offline   Reply With Quote
Old 10-27-2012, 09:19 AM   #106
Artie56789
Member#: 325507
2010 Impreza 2.5 OBS
2 tone silver
Is there any way to aim the fog lights on a 2010 outback sport?
Artie56789 is offline   Reply With Quote
Old 10-27-2012, 10:06 AM   #107
Zeeper
Member#: 299286
2017 Legacy Limited
Probably, you have to get into where they are and look for an adjuster -- ours have a cheap crappy plastic adjuster, but it does allow you to adjust them.
I readjusted mine last night. If you aim them as high as they go they do provide useful light, but I noticed road signs had a noticeable yellow glow (I have a yellow film over mine).
I brought them down to hit closer to the ground, but that got rid of most of the benefit they provided before, so I split the difference.
Still probably higher than they are designed, but at least they contribute additional useful light. Without turning them on there isn't much difference in illumination right in front of the car, but with them on the sides of the road get a bit more light, to avoid deer I'll sit with that compromise.
Zeeper is offline   Reply With Quote
Old 10-30-2012, 03:44 AM   #108
pkL
Member#: 313093
2012 Impreza 2.0i
I think you are right. I would be a little hesitant to put HIDs into the plastic fog light bowls though (even though HIDs run more efficient and cooler).
