Old 09-27-2011, 10:54 PM   #1
orijinalx
Member#: 253355
2013 VW Golf R
Question Stage 2 SF Intake Log
Hey guys, first time posting a log here. Just put in SF Intake on my09 wrx and reflashed with COBB Stage 2 SF 93 octane. I was running a perrin stage 2 map before, but unfortunately I never logged that setup. Current mod is full Perrin TBE, and the Cobb intake.
From bottom of 3rd to top of 3rd. Car feels great, but does everything look okay? Anything else i should log? Thanks in advance.
https://docs.google.com/spreadsheet/...Y0clE&hl=en_US
orijinalx is offline   Reply With Quote
Old 09-28-2011, 07:22 AM   #2
Cobb Tuning
Member#: 4803
Log looks good - no knock correction. You are overboosting a tad at higher RPM, but not a big deal at this point. However, I would watch this when the outside temps get colder during fall/winter.
Bill
Old 09-29-2011, 12:23 AM   #3
orijinalx
Member#: 253355
2013 VW Golf R
Thanks for the reply! I rarely take my car up to high RPM's so I'm hoping i'll last until i get a bigger intercooler and a protune. I know the accessport Injector duty cycle isn't accurate, but when in WOT it hit 95%. Is that okay?
Old 09-29-2011, 10:12 AM   #4
Cobb Tuning
Member#: 4803
That isn't a problem considering the map and your set-up.
Bill
Old 10-08-2012, 07:07 PM   #5
orijinalx
Member#: 253355
2013 VW Golf R
1 year bump. When the weather started to get colder I was overboosting and it put me in limp mode, so I switched to the LWG map and it helped so I've been using that map for awhile. Kinda got tired of the intake noise so I went back to stock intake and running stage 2 map I got from perrin. Everything looks fine, but the -1.56 in the A/F Learning. I've read it's "safe" upto +/- 5% but is it something I should worry about? Thanks. (3rd gear pull)
https://docs.google.com/spreadsheet/...k1hS3Z5Tmw1LVE
Old 10-08-2012, 11:31 PM   #6
wildt267
Member#: 161812
06 Wrx STi
CGM
Didn't read the log but -1.56 is nothing to be concerned about. :-)
wildt267 is offline   Reply With Quote
Old 10-09-2012, 11:03 AM   #7
Cobb Tuning
Member#: 4803
A/F Learning 1 values will vary - that is normal. As long as you don't see any extreme values (well outside of +/- 5%), you are fine. You can actually view all 4 of the stored values via the A/F Learning 1 A,B,C,D values. You can check those out using the live data feature of the AccessPORT even with the engine off (ignition ON).
Bill
Old 10-09-2012, 07:40 PM   #8
orijinalx
Member#: 253355
2013 VW Golf R
I checked the A/F Learning 1 A,B,C,D while the was off and in the ON position.
A- 3%
B- .3%
C- -.7%
D- .3%
Old 10-10-2012, 08:43 AM   #9
Cobb Tuning
Member#: 4803
A- 3%
B- .3%
C- -.7%
D- .3%
All values are within +/- 5%, so you are good to go.
Bill
Cobb Stage 1 +sf intake 93 octane concerns JordanM9 AccessPort 8 04-20-2011 12:00 PM
Cobb Stage 2 0-90 MPH log - how's it look? Drivinwest AccessPort 3 06-18-2009 04:09 PM
Stage 2 STI 07 log E-Tuned 3rd gear pull Defmxtones AccessPort 2 06-17-2009 02:40 PM
Stage 2 STI 07 log E-Tuned 3rd gear pull Defmxtones Open Source Reflashes 17 06-03-2009 10:14 AM
UTEC Newbie - STi Stage 2 Base Map Log MattSTi Engine Management & Tuning 4 12-14-2004 06:45 AM
