Welcome to the North American Subaru Impreza Owners Club Sunday August 28, 2016
Go Back   NASIOC > NASIOC Subaru Models > BRZ Forum
Old 02-02-2013, 02:26 PM   #176
OrbitalEllipses
Member#: 178811
2011 White Corolla
Over 400hp
Get in on the steering rack bushing group buy, n00b!
OrbitalEllipses is offline   Reply With Quote
Old 02-02-2013, 02:30 PM   #177
chanomatik
Member#: 159474
2013 BRZ Ltd 6MT CBS
SNOSLO
I have no complaints about my steering rack, so no clue why I'd need bushings? Explain to me and then I'll look into it. I got money to burn. Tom's missing out.
Old 02-02-2013, 02:35 PM   #178
OrbitalEllipses
Member#: 178811
2011 White Corolla
Over 400hp
From their page that you could have easily navigated to and read yourself:
So we've had this BRZ for a while, and in going through it we found a vast number of shortcomings for your performance enthusiast looking for a bit more.
One of the first things out of the box that we were unhappy with were the steering rack bushings. Here's what we found:
  • Stock bushings use a bolt with a rolled thread. This means that the shank is only 11mm.
  • The stock bushing crush tube has a bore of over 13mm.
  • Between those two items you immediately have a good bit of slop. Sure you could argue that small amount isn't that much, and you'd be right until you consider what that translates to at the tire.
  • The other big item we found is that the rubber is soft. I mean S.O.F.T. Like bubblegum. Not so good.
  • The last item we found is the hole on the rack for the stock bushings isn't all that concentric. That would explain the really soft rubber.
I mean here's this car than handles great out of the box, but could be made that much better with some simple forethought on how the car is going to be used. Especially when someone throws on a set of sticky tires. What's going to happen then? I can tell you - slop, inprecision, poor handling. Not good.
So what we did was make something better, and here's how:
  • Our bushings are aluminum. Nice and solid, and fill more of the hole on the rack.
  • Our bushings have a bore that fits the bolt with a proper clearance
  • Our bushings get you a new grade 8 bolt with a consistent thread to shank transition
  • Our bushings feature a split design for easier install.
  • Our bushings also use retaining o-rings to make for a really tight fit to account for stock bore inconsistencies so you get a postive snap into place.
In other words you get what should be in there from the factory. Plain, simple, and functional. Just how we like to do things here at TiC.
Old 02-02-2013, 02:44 PM   #179
chanomatik
Member#: 159474
SNOSLO
Yeah, but you kept the code and all that when pasting and I make a mess and stuff and yeah thanks I'll look into that appreciate it so awesome goodness !
Old 02-02-2013, 02:51 PM   #180
OrbitalEllipses
Member#: 178811
2011 White Corolla
Over 400hp
Omg thanks for noticing!
SRSLY MORE PPL MAKES IT CHEAPER BRO. $35 bushings? **** yeah mang.
Old 02-02-2013, 02:56 PM   #181
chanomatik
Member#: 159474
SNOSLO
$25 in the pot, son! Done and fork stuffed in and all that.
What else do you want me to buy?!!?????! I'm about to tear it up with these GT-86 black interior pieces: http://www.ft86club.com/forums/showt...t=22352&page=4
Old 02-02-2013, 03:19 PM   #182
OrbitalEllipses
Member#: 178811
2011 White Corolla
Over 400hp
I think Jive was looking at some too. I'd rather have genuine brushed aluminum TBH. Or maybe Alcantara wrapped...
Old 02-02-2013, 03:52 PM   #183
chanomatik
Member#: 159474
SNOSLO
Put the pipe down. Brushed aluminum? No one's going to make that. Maybe vinyl overlay to make it LOOK like that. Otherwise I plan on painting the black pieces since they're a matte finish and should adhere pretty well to customized paint.
Old 02-02-2013, 08:06 PM   #184
OrbitalEllipses
Member#: 178811
2011 White Corolla
Over 400hp
Meh. I can always get it made if I'm feeling posh.
I got a question for you though, my igloo dwelling friend! How's your transmission behaving in the weather? When cold I can hardly get into second without double clutching (like I ought to instead of granny shifting ) and even first from a slight roll is really hard to get into. I imagined that it would be worse up there in the great American North (or is it Russian? Or Canadian?).
Old 02-03-2013, 06:40 PM   #185
delongedoug
Member#: 124113
and beyond!
I'd get re-banned there sofaking fast!!!
delongedoug is offline   Reply With Quote
Old 02-04-2013, 11:56 AM   #186
chanomatik
Member#: 159474
SNOSLO
Nobody knows! I haven't had any issues driving around in the "cold". It's been super warm this past winter, though. We got a cold snap in October to early November. It's been high 20's to mid-40's since then, though. Some rain mixed it. I almost never start my car and go, though. I let it warm up for at least 15 minutes on especially chill days, then I take off to battle the employed elements. The only time I'm especially careful about shifting is when the steering wheel and knob are freezing.
What did you do?!
Old 02-04-2013, 12:22 PM   #187
OrbitalEllipses
Member#: 178811
2011 White Corolla
Over 400hp
Oh. I get in and go. Sitting for 15 minutes at idle is a great way to wash out the cylinder walls...
Old 02-04-2013, 12:27 PM   #188
chanomatik
Member#: 159474
SNOSLO
Sacrifices. If this car can't handle 15 minutes of idling, it's going back sooner than expected!
Old 02-04-2013, 02:31 PM   #189
Calamity Jesus
Member#: 44501
1984 That's *Sir*
Weinerlicks of Douche 2u.
That might be a problem for richly tuned turbo cars, but I seriously doubt there's much fuel dilution of the oil on the cylinder walls in a modern, direct injection, ULEV II car.
Old 02-04-2013, 02:46 PM   #190
Jive Turkey
Member#: 219492
change the fluids, did that in my sti and it worked wonders on cold starts. i plan on changing the dif/trans fluids when my next oil change is up.
my pieces are alcantara wrapped. i'm posh as **** but i messed up the door handles so i need black ones ASAP. also the silver buttons are killing me.
and it wont let me putt the deposit down on the website for SR bushings!!!!
Jive Turkey is offline   Reply With Quote
Old 02-04-2013, 03:05 PM   #191
itwillboost
Member#: 289693
2013 BRZ
Sterling Silver Met.
That's my thoughts too, only thing that sucks is of course the trans doesn't warm up to easily.
itwillboost is offline   Reply With Quote
Old 02-04-2013, 03:36 PM   #192
OrbitalEllipses
Member#: 178811
2011 White Corolla
Over 400hp
I'm having other weird issues. Dealer better flush fluids or give me a new box if my issues continue. Or I could learn to drive, but really...
Call 'em.
Old 02-04-2013, 09:18 PM   #193
Jive Turkey
Member#: 219492
Call 'em.
figured it out.
i see the problem here, not double clutchin like you should?
chano! i need black trim, let me know how and where you get it and how much!
Old 02-04-2013, 09:26 PM   #194
OrbitalEllipses
Member#: 178811
2011 White Corolla
Over 400hp
Gotta double clutch to even get into first and second when cold.
Old 02-04-2013, 09:54 PM   #195
chanomatik
Member#: 159474
SNOSLO
Like dude said on FT86Club, that one site seems to be cheaper. I'm conflicted because I'm wanting to get red parts from the GT-86 as well. I'm thinking that center part is all I'll need (button, shifter trim and either side of the A/C knobs). Although those non-chrome door levers are a really nice touch, too. Oh, and the a/c circular bezels.
Otherwise from the GT-86 I'm looking at door panels, knee pads, e-brake and door handle trims. I'm trying to imagine all of that flowing together.
I just ordered my footwell illumination kit in red.
Old 02-04-2013, 10:52 PM   #196
Jive Turkey
Member#: 219492
****ing ricers.
Old 02-05-2013, 12:19 AM   #197
kayetealynn
Member#: 253304
2001 Impreza 2.5RS
Plus MOAR
... Did you try Kendall?
They may be able to get that stuff no freight dependant on whether or not it shows up in their parts system as available. I mean... You can order JDM part numbers (well at least some part numbers) from Conti... So Toyota should work the same way...
And in AK.. No freight = win. _
kayetealynn is offline   Reply With Quote
Old 02-05-2013, 03:06 AM   #198
chanomatik
Member#: 159474
SNOSLO
Do we have a local dealer for Toyota that isn't Kendall? Otherwise, yes, I went to Kendall and was quoted $60 for the buttons. I don't know how much cheaper it is on the site linked on FT86Club, but those buttons come with everything needed, I believe, so $60 isn't terrible for electronic doodads.
Old 02-05-2013, 03:07 AM   #199
chanomatik
Member#: 159474
SNOSLO
****ing ricers.
I gotta see my footwork, son!
Old 02-05-2013, 08:13 AM   #200
zavier
Member#: 141189
2007 2.5i (NBP)
2014 BRZ (DGM)
I'm really starting to wish this forum had a "like" button...
zavier is offline   Reply With Quote
