Welcome to the North American Subaru Impreza Owners Club Saturday July 2, 2016
Old 10-08-2012, 07:10 PM   #1
smggtr
Member#: 305515
2005 Impreza sti
blue
Default 1st day at track opinions on my time
Now this was 4th pass and best but my first time at a track.
Its an 05 sti. full exhaust but bad header it may still have a crack. catless up pipe and downpipe. high flow final cat. cold air intake at 16.5 psi. 8.5:1 forged pistons. stock top mount
What do you think about how my car is running and what it might run with a good launch. I was a soft on my launching. and slow into 5th with a bit of lag on spool due to that.
reaction - .5814
60ft - 2.2264
330ft - 5.9882
594ft - 8.4692
1/8 - 9.0162
1/8 mph - 82.26
1/4 - 13.8048
1/4 mph - 102.63
smggtr is offline   Reply With Quote
Old 10-08-2012, 07:19 PM   #2
Extreme Turbo Systems
Member#: 194655
08 STI
not bad. 60' could use a little work but overall for the first time at a track, its good. congrats man. Hopefully you had fun! that's what its all about. An ETS TMIC would help keep the air cool and really help on the top end. ;-)
Extreme Turbo Systems is offline   Reply With Quote
Old 10-08-2012, 08:49 PM   #3
424wrx
Member#: 171948
08 wrx stg3 vf52
14 legacy, 11 fozzy
not bad. my first time was 3 weeks ago. i went 13.30@ 103. my 08 wrx is vf52 swapped and stage3 with a perrin tmic and tomei el headers. im running 22 psi. my best 60ft was a 1.99. lanching was hard to master. with some practice, 12s are within reach. op, it is a rush racing though right?? i had a blast. im looking foward to going again in the spring. my other times were a 13.39,13.6 and a 13.7. i was getting pretty heat soaked by the 13.7 pass.
Old 10-09-2012, 05:43 PM   #4
CTSparky
Member#: 282204
2011 5 Door STi
Plasma Blue Pearl
reaction - .5814
60ft - 2.2264
330ft - 5.9882
594ft - 8.4692
1/8 - 9.0162
1/8 mph - 82.26
1/4 - 13.8048
1/4 mph - 102.63
Dear OP I'm not a 1/4mi track god but I've started doing some track stuff now and again. I've also searched out on 1/4mile threads to see what I need to do to be competitive.
for a new person a .5814 RT is ok. If the tree is a .500 tree then you should release the clutch on the third light. If on a pro tree you should release the clutch when the yellows light up.
a 2.2 60ft is slow.... I think that perhaps you are bogging, and therefore not launching from as high as an RPM as you should. There are other factors to take into account and I'll ask that at the end.
your quarter mile time is high. I'd expect a 05 sti with a full exhaust including a header to be in the high 12's. your MPH also suggests this.
The real question:
If you have a rebuilt block (forged pistons) and a full exhaust, then why are you running such a relatively low boost pressure? I'd expect at least 18lbs. but with a built block your engine could handle 24 lbs (your turbo maybe not, but the block could) Maybe the header leak is preventing this?
So why are you so low? how are you recording it? Is it a bad gauge or a poor tune, or you just being very conservative.
I hope this helps.
CTSparky is offline   Reply With Quote
Old 10-10-2012, 09:07 AM   #5
k04sti
Member#: 171773
04 wrx sti
jbp dom 3 xtr w meth!
The real question:
I hope this helps.
So much false information here where do I begin. First off, bogging is not because he is not launching at a high enough rpm. He is bogging because he is dropping the clutch too fast.
Also, his mph which is 102 does not suggest a 12 second 1/4 mile time. Also, higher boost does not mean more power especially on the stock turbo. He should not be boosting 24 lb because this would not be efficient on his turbo.
Please don't post information that you are not sure of because you will mislead the community and you obviously don't know what you are talking about.
k04sti is offline   Reply With Quote
Old 10-10-2012, 10:08 AM   #6
CTSparky
Member#: 282204
2011 5 Door STi
Plasma Blue Pearl
I admit to not being very experienced in this application. In fairness I'm just trying to help.
So what would a 102 trap speed equate to?
He could be bogging from letting up too fast or too low a rpm, or not letting go on the upswing of the tach (building boost). There are many reasons. Even the OP says he was soft on the launch.
With a forged block what boost pressure is the engine capable to?
If on a stock turbo a 2005 is a vf39 which can get up to about 300whp when everything is addressed. That is if the OP has a stock turbo. and on this turbo about 20lbs is at the end of it's efficiency.
Old 10-10-2012, 11:57 AM   #7
Steve.804
Member#: 68647
07 STI 35R
05 BMW M3 ZCP
Really tough to give insight because if you have a crack in the header the car may be a bit faster than it appears. 16.5psi is a little low but increasing that is really just going to make more peak torque and midrange. The stock turbo cannot sustain anything above that at high rpm (mine was around 15.5psi at 7k) because it is simply too small so it won't help with the quartermile. More boost is not the answer for a quicker time or faster trap speed.
Ignore reaction time. It plays NO ROLL in the end result of your quartermile time. Your first time out you should be as calm and relaxed as possible, concentrate on the launch and leave at your own time. May not want to sleep at the tree for a couple of minutes but a few seconds is fine.
2.2 60ft is slow for an AWD vehicle. Do some research on how to properly launch or send me a PM and I can review with you my technique on the stock turbo that always worked well and consistant for me.
Your 330ft isn't terrible considering the 60ft but you want to get that as close to 5.0 as possible. That will come as you get better at the 1st-2nd shift and as your vehicle makes the proper power.
Also, drag racing is pretty abusive, I personally wouldn't take my car out there and beat the hell out of it unless it is running flawlessly.
Steve.804 is offline   Reply With Quote
Old 10-10-2012, 06:13 PM   #8
smggtr
Member#: 305515
2005 Impreza sti
blue
Oh the turbo is not stock but I have no idea the make of it because there is no manufacture label on the turbo anywhere. But on the inlet wheel it has the larger fins plus shorter fins inbetween if someone knows who makes it that way id like to know. Ive seen a couple pictures of the blouch with those type of fins. It has a mbc and gets to the set psi easy in 3000rpm range and is steady all the way to 7000.
The cracked header is minor i think because it was welded but the little bit hidden in the collector could not be reached.
I wanted mostly street use so wanted the lower psi. Before all the fixing it was set high and easily hitting 26psi.
As for the launching i dont know the best way. And really did not launch. that time was at maybe 3000rpm or just under with a little slip taking off.
the only built part of the engine is the pistons the rest is stock parts. dont know high to aim for in turbo pressure.
Old 10-10-2012, 06:15 PM   #9
Mike Costin
Member#: 131787
06 STI,OB,OME XJs
Merkur Junkyard
Two things to work on before you go out again, your launch and shifting. You can practice in a parking lot and on the highway, respectively.
Launching: Let out the clutch until the drivetrain engages and the car wants to move, then push it back in a tiny amount. Rev the engine up to around 4,500 RPM and release the clutch somewhat quickly but not ninja fast.
Once you get that down you can rev the engine up to around 4,500 RPM and then repeatedly blip the throttle very quickly so that the revs drop to 4,000 and then shoot up to 5,000 RPM, drop to 4,000 RPM, raise to 5,000 RPM, and so on. After a few of these blips when the revs are on an upswing towards 5,000 RPM let the clutch out the same way. This should improve your 60' compared to launching at a fixed RPM.
The clutch shouldn't smell too badly. Lift if you get bad wheel hop. Don't do too many launches in a row.
Shifting: Shift 1st and 2nd gear at red line. You may want to stay in 1st gear for a couple bounces off the rev limiter in case you are spinning tires. 1st to 2nd can be a slow shift depending on your synchros, don't force that one too hard. Practice shifting 2-3, 3-4, etc. fast enough that the car doesn't jerk. Keep your foot on the accelerator pedal when you shift, and only lightly lift it so you don't hit overrun. This should help with reducing the jerk and maintaining boost.
Like everyone says, ignore reaction time until you start racing. If you are next to a loud car it is sometimes best to wait a few seconds for them to launch and disappear before you initiate your launch procedure.
Don't worry about peak boost at this point. That initial surge of torque will wear your clutch and break the drivetrain faster and will not improve your quarter mile performance significantly. A exhaust manifold is a concern, a broken car should only be driven to limp it home.
Mike Costin is offline   Reply With Quote
Old 10-11-2012, 08:45 AM   #10
k04sti
Member#: 171773
04 wrx sti
102 trap speed is around stock / stage 1 and is 13 seconds. Bogging the car is not from rpm at all. Even if you launch the car at 3k rpms you don't bog because the rpms are too low. You bog the car because you are letting the clutch out too fast.
Old 10-11-2012, 09:23 AM   #11
Steve.804
Member#: 68647
07 STI 35R
05 BMW M3 ZCP
Hmm I wonder what turbo your car has on it
My biggest recommendation to you is to find a reputable shop in your area. A quick google search I did came up with Speed Industry located in Troy MI. I'd have them do a complete vehicle check and sort out any leaks (header, intercooler, vaccum, etc.) and retune the car for the highest grade of pump gas available in your area.
Do you have a complete mod list? Or at least details on the fuel system? What are you using to tune with? AccessPort?
Old 10-11-2012, 09:33 AM   #12
mtarr07
Member#: 246990
2010 Wrx
^ I strongly agree with the poster above.
You have a nice car and spent your hard earned money on it. I wouldn't go beating on it at the track when/ if you think something is wrong with it. Bring it to a shop nearby. Figure out if there really is a crack/ leak somewhere, fix it, then get tuned properly at a power level you are comfortable with/ is safe for the car.
mtarr07 is offline   Reply With Quote
Old 10-11-2012, 10:53 PM   #13
ByeBye4g63t
Member#: 290896
2004 STi, FOR SALE
I did a 13.2 at 101 with cyl #4 on low compression (ringland) so your time is pretty bad no offense. Considering your trap speed, A very high 12 might be possible, but a 13.1ish is probably about all it has in it. Get that 60 ft down! I did consistent 1.8's and 1.7's on a basic stage 2 '04, I don't see why you can't achieve that considering you trapped 1mph better than me.
ByeBye4g63t is offline   Reply With Quote
Old 10-12-2012, 07:13 AM   #14
wrxlaunch
Member#: 181298
Really slow my dude... My bugeye ran 13.9 bone stock.
wrxlaunch is offline   Reply With Quote
Old 10-12-2012, 03:00 PM   #15
NSFW
Member#: 140444
05 Stage Free LGT
ATP 3076, 6MT, AVO FMIC
Any chance you could post it here for more of us to learn from?
I have a couple of techniques depending on the track, but I'm still looking for other ideas.
If the track will allow rear wheelspin, I'll set DCCD completely open, rev to about 5k, then simultaneously lift quickly off the clutch ("like you just stepped in dog **** by mistake" as one guy here put it) and floor the throttle. Almost a clutch dump, but not quite, as I really don't want to break an axle and I am pretty sure I have enough torque to do that. Basically I spin the rear wheels instead of slipping the clutch. I've done my best launches this way (1.6, 1.7, and maybe even a 1.38 but that was probably just a timing glitch). But launching this way depends a lot on the track.
If the track is too sticky for wheelspin, I rev to 4000, hold it, then floor it and release the clutch just slowly enough to avoid bogging. That's gotten me consistent 1.8s. I haven't tried blipping the throttle yet to build boost but I am sure it would help. When I get more consistent with this simpler approach I'll try adding the throttle blips.
I prefer the wheelspin approach because replacing tires is less work than replacing clutches. And I'm more consistent with it, even though I have a lot more practice with the clutch-slip approach.
Old 10-13-2012, 02:13 AM   #16
TwinscrollGT35R
Member#: 256810
This is a good thread so far. I have never run my car with the last build. Once its up and running I want to go out.
How many of you are using cobbs launch control and flat foot shifting?
TwinscrollGT35R is offline   Reply With Quote
Old 10-13-2012, 02:39 PM   #17
NSFW
Member#: 140444
05 Stage Free LGT
...or "open source" LC/FFS ?
("open source" in quotes because the most popular version isn't)
I have experimented with them a bit off-track, but not yet at a track, so I'm more interested in reading about them than in writing about them...
Old 10-13-2012, 02:43 PM   #18
NSFW
Member#: 140444
05 Stage Free LGT
Has anyone noticed their car stumbling on 1-2 shifts in a way than never happens in 2-3 or 3-4 or 4-5 shifts? If anyone has any theories about why the 1-2 shift is different, I'd love to hear them. The motor seems to fall on its face more often than not, like the power doesn't come on until well after I've released the clutch and floored the throttle.
This happens with and without FFS... it's particularly blatant with FFS since power ought to just come on like a light-switch, same as every other shift.
The 1-2 shift is still really hard to get right, and I'm not sure what I'm doing wrong, but FFS works great for 2-3 and 3-4.
Old 10-13-2012, 05:28 PM   #19
NateLS1
Member#: 132380
2004 WRX
rojo
I noticed my ecu learned to pull timing due to flat foot shifting. My problem was especially noticeable once I hit 4th gear, it had no balls for a couple hundred rpm, then like a lightswitch it just kicked in the engine had power again.
NateLS1 is offline   Reply With Quote
Old 10-14-2012, 10:18 AM   #20
wrx2007sti
Member#: 335058
2007 STI
great
wrx2007sti is offline   Reply With Quote
Old 10-14-2012, 10:36 AM   #21
silverboost0303
Member#: 83266
2011 WRX Sedan
Just gotta get the launch down. And it's tough to practice because you don't want to break anything. I went 13.1 at 104 with a crappy 1.967 60ft. The cracked header may be playing a huge role. Not bad for your first time though. My first time at the track, I had an 03 bugeye with an untuned up, and blitz tbe and went [email protected] Don't remember my 60ft. I was frightened when I smelled the clutch lol.
silverboost0303 is offline   Reply With Quote
