Welcome to the North American Subaru Impreza Owners Club Thursday August 28, 2014
South West Impreza Club
Go Back   NASIOC > NASIOC Chapters > South West Impreza Club Forum -- SWIC
Old 09-17-2013, 08:02 PM   #276
Evil Imports
Member#: 14732
+ 13 B8
Evil Imports is offline   Reply With Quote
Old 09-17-2013, 08:14 PM   #277
lox
Member#: 348423
08 fxt 05 x
dgm rbp
clean pants
i do not have them
lox is offline   Reply With Quote
Old 09-17-2013, 10:22 PM   #278
kpluiten
Member#: 120273
06 WRBWRXWGN
Now with 100% more Spec-C
Wow. That looks fantastic. Great color as well.
Old 09-17-2013, 11:28 PM   #279
yman
Member#: 199051
04 sti
psm
Very solid work Jay, it looks great.
yman is offline   Reply With Quote
Old 09-22-2013, 12:09 AM   #280
blkscooby
Member#: 44422
2005 LGT
Saw it in person tonight, stance and wheels are amazing
blkscooby is offline   Reply With Quote
Old 09-22-2013, 12:11 AM   #281
Evil Imports
Member#: 14732
+ 13 B8
Thanks man
Old 10-09-2013, 02:09 AM   #282
kpluiten
Member#: 120273
06 WRBWRXWGN
Where are the pictures of the finished engine bay? I've seen it, but I'm sure others would enjoy it...
Old 10-09-2013, 06:18 PM   #283
Prettym1k3
Member#: 329981
2004 Forester XT
Car looks fantastic, man. Can't wait to one day build up a motor.
You linked me here from the Cobb Tuning FB page.
Cayenne Red Foresters... unite!
Prettym1k3 is offline   Reply With Quote
Old 10-09-2013, 08:46 PM   #284
learmiller
Member#: 229740
07 STI ltd/FXT STI
I wanta see this in person!
learmiller is offline   Reply With Quote
Old 10-09-2013, 11:07 PM   #285
Evil Imports
Member#: 14732
+ 13 B8
Mine is Garnet Red Pearl
(for now, most likely will change this winter)
Old 10-10-2013, 11:25 AM   #286
Psirene
Member#: 308506
2011 WRX Limited
Obsidian Black Pearl
o.O
Change to what?
Psirene is offline   Reply With Quote
Old 10-10-2013, 11:35 AM   #287
lox
Member#: 348423
08 fxt 05 x
dgm rbp
doubtlessly something beyond the scope of mortals
Old 10-10-2013, 12:26 PM   #288
Psirene
Member#: 308506
2011 WRX Limited
Pshaw. Why do you think I asked?
Old 10-10-2013, 03:34 PM   #289
kpluiten
Member#: 120273
06 WRBWRXWGN
This car is begging to be painted a nice brown. Like the rootbeer brown color Subaru puts on the Outbacks.
Old 10-15-2013, 01:11 AM   #290
Spanky7081
Member#: 352055
2005 STi
Nice build!
Spanky7081 is offline   Reply With Quote
Old 10-15-2013, 03:14 AM   #291
kpluiten
Member#: 120273
06 WRBWRXWGN
I drove this car the other night. This thing MOVES. The 2.5L with a TS 18g makes gobs of torque and at like 3000 rpm or less. So much fun.
Old 10-15-2013, 11:23 AM   #292
Z0rr0
Member#: 23123
15 WRX 6MT
07 Legacy SpecB
It's only going to get better.. once we add boooooost!
Z0rr0 is offline   Reply With Quote
Old 10-15-2013, 04:01 PM   #293
Evil Imports
Member#: 14732
+ 13 B8
you should stop being a Pus*y when tuning it and put more boost into it
Old 10-15-2013, 04:10 PM   #294
Z0rr0
Member#: 23123
15 WRX 6MT
07 Legacy SpecB
It's okay, i'm not a "ProTuner" anyway
Old 10-16-2013, 12:14 AM   #295
lox
Member#: 348423
08 fxt 05 x
dgm rbp
wait, what?
Old 10-16-2013, 07:17 PM   #296
Z0rr0
Member#: 23123
15 WRX 6MT
07 Legacy SpecB
wait, what?
Inside joke
Old 10-17-2013, 02:18 PM   #297
Evil Imports
Member#: 14732
+ 13 B8
08+ steering wheel in 07-08 FXT
This was pretty easy to do, My instructions are for only the 07-08 forester (canbus) all other years you will need to find your own wiring way. also do at your own risk
For the Cruise control the fxt and 08+ sti are pretty much the same since they are both canbus, you just need to move some wires around, i cut the ends off and resoldered the wires so i could keep it easy to plug in at the clockspring behind the airbag
On the 08+ sti wheel plug you have 6 wires
Yellow: Cruise
Brown: Cruise
Green: Cruise
Red: 12v Illumination (for lights)
Black: Ground for lights
White: Audio signal
Blue: Audio ground
On the FXT you have 3 wires in the white plug and 1 in the green plug
I honestly thought i took pics of these before i rewired them but can't find them, so i am not sure what color the wires were, but either way you just need to know where the wires need to go so here you go. Pic you can see the 3 wired (in what place they go) using the color from the STI steering wheel controls
As you can see the wires are Green/brown/yellow in the white cruise control plug, putting them in the order shown the cruise will work. I haven't had any problems with it at all since doing it
In the Green clip you only have 1 wire coming out,
Green with red strip, this is your horn wire (12+)
I added 3 more pins to the clip and wired the wires like this
White/red - White from STI wiring
black - Black and blue from sti wiring
Red - Red from STI wiring
Under the dash all 5 pins from the green clip have wires out the bottom of the clockspring (at least on my 08 it did) when you follow the wires down to a white plug, here is what color/pin from the green clip at the wheel to the white plug under the dash
P1 - Green/red (horn) = Red
P2 - empty = Light blue
P3 - empty = Black/white stripe
P4 - empty = Green/red stripe
P5 - empty = White
Just make sure whatever wires you put in each pin you connect the same wire below
I then added pins again to the other side of the white clip (as since the wires aren't used they stop at the clip) (pic above)
Red = 12+
Black = Ground
White = Audio signal (connects to the ASWC-1)
I had a 2 pin plug behind the radio not being used, it was 12+ and ground so i ran the red and black wires to this, and that worked perfect for the lighting on the steering wheel controls
Now the white wire need to be connected to a unit that works for aftermarket radios and steering wheel controls, I used the Axxess ASWC-1, I wired it up the way it showed on there website, this unit will "auto detect" what radio you are using and program itself.
ASWC-1 Connections
1) Connect the Black wire of the ASWC-1 to chassis ground.
2) Connect the Red wire of the ASWC-1 to a 12+ accessory wire,
3) Connect the Gray/Red wire of the ASWC-1 to the white wire that is coming from the steering wheel that we just ran
4) Connect the White/Green wire of the ASWC-1 ground. (Use the same ground as the black wire from the ASWC unit).
Old 10-17-2013, 02:24 PM   #298
Evil Imports
Member#: 14732
+ 13 B8
Next i was bored and decided to do a yellow tint on the headlights, I am still not 100% on if i like it or not, but for now i am keeping it on
Old 10-17-2013, 02:26 PM   #299
Evil Imports
Member#: 14732
+ 13 B8
I then picked up a set of 06-07 STI front seats for my car, and wrapped some of the interior panels with 3M carbon vinyl
Old 10-17-2013, 02:30 PM   #300
Evil Imports
Member#: 14732
+ 13 B8
Also in the spirit of wasting money on this damn car, I picked up a blue stitch GT-spec steering wheel for it, since they are only made for the 08+ sti/wrx ect. it was a perfect fit with my car running the newer airbag
Thanks to the guys a Vivid Racing for the great price on it
