Old 10-15-2012, 01:53 PM   #26
gutie04
Member#: 219717
05 FXT Dom2.5R
4EAT FTW!!!!
Subscribing for more IR awesomeness.
gutie04 is offline   Reply With Quote
Old 10-15-2012, 05:27 PM   #27
gutie04
Member#: 219717
05 FXT Dom2.5R
4EAT FTW!!!!
How flexible is the aluminum stuff? Does the gold foil have any foam or some kind of separator? Without a separator it is just adding density to whatever you stick it to, which will result in it maintaining its temperature longer whether it's hot or cool, which makes sense with your results. As opposed to actually blocking the heat.
Old 10-15-2012, 08:39 PM   #28
HeroCrank
Member#: 301089
2013 Toyota Tundra
Rock Warrior
the aluminum shield is pretty flexible. The gold foil has no separator but it has the technology to reflect the heat.
HeroCrank is offline   Reply With Quote
Old 10-15-2012, 08:52 PM   #29
the suicidal eggroll
Member#: 51961
2005 STi
2012 WRX
It's purpose is to lower the panel's emissivity, which will reduce the radiative transfer of heat. However, the shiny silver heat shield has a very low emissivity to begin with, so it's not going to make much of a difference. Now if the heat shield was matte black, things would be different.
Old 10-18-2012, 12:46 AM   #30
90crxfreak
Member#: 318642
2012 WRX Premium
subscribed
90crxfreak is offline   Reply With Quote
Old 10-18-2012, 10:51 AM   #31
SeeeeeYa
Member#: 129681
2016 WRX EyeSight
LBP
In fact, in my opinion, based on successes in the past with this, better results than the gold and all is possible with just black paint... Rustoleum BBQ Black High Temp. This is what I, and everyone else who cared, used to coat intake manifolds on big blocks, for example. You can't do much about heatsoak due to most influences, but you can influence emissivity.
In fact, putting reflective material ON the TMIC probably reduces its effectiveness.
SeeeeeYa is offline   Reply With Quote
Old 10-18-2012, 03:21 PM   #32
RallySport Direct
NASIOC Storefront Vendor
Member#: 33174
We are Open Late!
888-457-2559 Every day!
This is some great info! Thank you very much for taking the time to do these tests and to list it
Kirill
RallySportDirect.com
PS. What thermal imaging camera are you using?
RallySport Direct is offline   Reply With Quote
Old 10-18-2012, 08:22 PM   #33
HeroCrank
Member#: 301089
2013 Toyota Tundra
Rock Warrior
do you have any real data showing that your rustoleum spray paint out performs reflect a gold foil tape? reeeeeaallllyyyyy skeptical about this claim. Ive actually used this before on exhaust of a 1996 honda civic hatchback. Now that d16 engine had a close coupled cat than the first exhaust piece all the way back was painted. That stuff doesnt last and flaked off because of the heat of the 96 hp engine. I still may have a partial can in my garage still.
Old 10-18-2012, 08:41 PM   #34
Member#: 51961
2005 STi
2012 WRX
It all depends on whether the part in question is hotter than the surrounding parts or cooler than the surrounding parts, and what direction you want the heat to go.
Old 10-19-2012, 12:48 AM   #35
meebs
Member#: 3251
2009 WRX Hatch
I was thinking about this as well; gold foil on the bottom of the hot side end tank would probably suffice. Blanketing it fully seems counter productive when the turbo is cranking hot air into it. But, the IC seems to be able to keep up just fine though with whatever additional heat that might be.
meebs is offline   Reply With Quote
Old 10-19-2012, 06:27 PM   #36
HeroCrank
Member#: 301089
2013 Toyota Tundra
Rock Warrior
Kirill
you are very welcome, thanks for the support
Old 10-20-2012, 05:14 PM   #37
HeroCrank
Member#: 301089
2013 Toyota Tundra
Rock Warrior
And awesome it is.
Old 10-21-2012, 08:26 PM   #38
scby rex
Member#: 104878
02 wrxbastardchild
aw, MPS 2.34 breaking in
This is all good and all, but could you post the ambient temp during testing also?
scby rex is offline   Reply With Quote
Old 10-22-2012, 08:56 AM   #39
HeroCrank
Member#: 301089
2013 Toyota Tundra
Rock Warrior
68F in a climate controlled setting.
Old 10-22-2012, 01:24 PM   #40
Leafy
Member#: 330625
2006 WRX
It shouldnt even be a close comparison. Black is the worst color for a heat treatment designed to reduce radiative heat. Black naturally has the highest emissivity, white would be a much better choice if you were to paint. But honestly nothing really comes close to the gold foil for low emissivity.
Leafy is offline   Reply With Quote
Old 10-24-2012, 09:48 AM   #41
HeroCrank
Member#: 301089
2013 Toyota Tundra
Rock Warrior
Anyone have any thoughts or experience with a ceramic coated heatshield with gold foil on the inside?
Old 10-24-2012, 10:35 AM   #42
Member#: 51961
2005 STi
2012 WRX
Complete waste of time and money.
Old 11-03-2012, 12:50 PM   #43
HeroCrank
Member#: 301089
2013 Toyota Tundra
Rock Warrior
This is going to be tested very shortly. Be checking this section for some more action.
Old 11-21-2012, 02:35 AM   #44
0BlueSTi4
Member#: 98955
2011 WRX Hatch
Awesome crack...you are my hero...subscribed to new addiction
0BlueSTi4 is offline   Reply With Quote
Old 11-21-2012, 06:55 PM   #45
HeroCrank
Member#: 301089
2013 Toyota Tundra
Rock Warrior
It becomes very addicting removing as much heat as I can now that I can actually see how effective these products work
Old 11-23-2012, 01:31 AM   #46
0BlueSTi4
Member#: 98955
2011 WRX Hatch
Have you looked into extracting heat from the engine bay? I'm thinking hood vents, front fender side vents, and front fender top vents(like S206) as well as front bumper side vents. Might be tricky to take pics of these as they work best at speed but might still be possible to see those in action with radiator fans on. I'm thinking with all the other cooling mods you have implemented those might have a good additive effect.
Old 11-23-2012, 02:23 PM   #47
SlomoWRX
Member#: 298132
2011 WRX
Subscribed.
Thank you for doing the research in heat management in the engine bay. I have always been curious as to how well the different products worked.
SlomoWRX is offline   Reply With Quote
Old 11-24-2012, 04:41 PM   #48
HeroCrank
Member#: 301089
2013 Toyota Tundra
Rock Warrior
Originally Posted by SlomoWRX View Post
Subscribed.
you are very welcome and thanks for stopping by
Old 11-24-2012, 08:46 PM   #49
HeroCrank
Member#: 301089
2013 Toyota Tundra
Rock Warrior
This would be a very challenging test to complete as you have stated that they are designed to work while the car is in motion.
Old 05-26-2013, 11:24 AM   #50
HeroCrank
Member#: 301089
2013 Toyota Tundra
Rock Warrior
I've been seeing a lot of new faces around here with new cars the past few weeks. The thermal questions are starting up again and I encourage you all to research before you buy and ask as many questions as you can. Ill bump this thread and please contact me if you have any questions.
