Welcome to the North American Subaru Impreza Owners Club Saturday February 6, 2016
Old 10-05-2012, 02:30 AM   #1
pet3r
Member#: 283134
2008 STi AW
550whp - 530wtq
Default Weird knocking sound
Car: 2008 STi, built block (CP pistons), every other bolt on imagineable
So, my car has driven perfectly the last 3k miles. I started hearing this knocking sound on Monday. Only driven it maybe 40 miles since then, but, it seems to be getting louder now. Car drives normal, acceleration is fine, idles perfectly.
However, tonight I pulled up to a light and the car died. I got a jump start, it started up and I was able to get to the next auto store and get a new battery. I put the new battery in and it couldn't start the car. Tow truck shows up, he jumps the car again. It'll run, but after a few seconds it'll die for no reason.
The knock is apparent after I let off the gas, usually only between 2200-4000rpm. Higher RPM I don't hear it. But, it's a loud sound, very obvious. If you let it idle, and lightly bring the RPMs up you'll hear it like in the video below.
I have a bad feeling about this one...but would love any thoughts on what it could be. The car was towed to a shop, and I forgot to check the oil before I dropped it off. I haven't had any oil consumption problems with the car, and it has been maybe 2000 miles since the last oil change, if that.
Video here: http://s1052.beta.photobucket.com/us...39a15.mp4.html
pet3r is offline   Reply With Quote
Old 10-05-2012, 05:26 AM   #2
Onnimanni
Member#: 230060
1998 Impreza GT
Sounds like a bad rod knock
Onnimanni is offline   Reply With Quote
Old 10-05-2012, 07:05 AM   #3
k04sti
Member#: 171773
04 wrx sti
jbp dom 3 xtr w meth!
Either ur block wasn't built correctly or u had a poor tune u need to take it up with them. Post up your dyno sheet so we can see how it was running and if that looks fine then u got screwed on ur block. Sounds like rod knock
k04sti is offline   Reply With Quote
Old 10-05-2012, 09:55 AM   #4
Leafy
Member#: 330625
2006 WRX
Sound like you need to go to your engine builder. I hope you have a 2nd car, because that baby is toast.
Old 10-05-2012, 01:13 PM   #5
pet3r
Member#: 283134
2008 STi AW
550whp - 530wtq
Gulp. Bought the car from someone else, the engine was rebuilt in 2010 by RAW Performance. Yep. Read about that guy. Don't think I'm gonna get anywhere with that.
Old 10-05-2012, 03:30 PM   #6
MaddMax
Member#: 9264
2012 WRX 5dr
Ice Silver
Rod knock
Old 10-05-2012, 04:20 PM   #7
pet3r
Member#: 283134
2008 STi AW
550whp - 530wtq
Yep. Rod knock combined with a blown main bearing. Oil starvation. I burned 3.5 quarts in just over 1000 miles. Lots of debris in the filter. Engine is toast
Old 10-05-2012, 04:34 PM   #8
MaddMax
Member#: 9264
2012 WRX 5dr
Ice Silver
Unfortunate. Was the car raced hard, over-revved, pushing significant power, or some other event that may have toasted the bearing? Luckily, the short blocks are relatively cheap and hopefully the pistons are salavagble.
Old 10-05-2012, 05:39 PM   #9
UK-Wagon
Member#: 232430
555 XTi
1 AW & 1 CGM
The engine shut off because the bearing was trying to seize at first. Jump staring it added more amperage than usual to the starter and thus it turned over. So essentially you made it worse but it was already damaged and the inevitable was coming.
A poorly built engine wont last 3k miles. So what ever happened was likely due to driving error or wrong oil of some sort, maybe the combo of both. Hard to say and likely wont ever know.
Old 10-06-2012, 12:01 AM   #10
Baja_Gernaut
Member#: 229922
2005 F-Inductd BAJA
rumble black
I'll bet you never knew that car was burning oil and you ran it dry. If that engine lasted 2k then it was surviving but I really have a feeling you fell asleep on the wheel on checking oil consumption in a turbo charged vehicle. I also bet your heavy foot did not help the cause. Anyway, stick with a stock engine if you want to enjoy a good subaru. That's my .02. Sorry to hear that you have this heartache.
Baja_Gernaut is offline   Reply With Quote
Old 10-06-2012, 01:44 AM   #11
pet3r
Member#: 283134
2008 STi AW
550whp - 530wtq
Sorry if I miscommunicated when the engine was built...it has over 18k on it, not 2k.
Old 10-06-2012, 02:37 AM   #12
UK-Wagon
Member#: 232430
555 XTi
1 AW & 1 CGM
Well, thats definitely operator error at that point....
Old 10-06-2012, 12:07 PM   #13
meebs
Member#: 3251
2009 WRX Hatch
For the statistically minded... what brand and weight of oil did you use post rebuild?
meebs is offline   Reply With Quote
