Old 02-28-2013, 11:44 PM   #1
97cv
Member#: 151048
2003 Baja
Black/ Silver
Default 2005 Baja water pump weep hole ?
I'm kinda new to the H4 so I could a quick tutorial.
Is there a weep hole on this water pump ?
Can I see it without taking the timing cover off ?
Buying a car out of state and want to check everything out.
Thanks a ton.
97cv is offline   Reply With Quote
Old 03-01-2013, 03:16 PM   #2
mod maniac
Member#: 300551
2002 DD wgn 6 spd
2.1 kel 272's meth 2.5xtr
If there was a weep hole you couldn't see it.
Old 03-01-2013, 03:18 PM   #3
Dr. Octawakaoctapus
Member#: 262003
1994 Legacy
teal
Yes and yes but its tucked away a little, you usually see at the bottom of the pump if its been leaking or use a mirror, its on the bottom of the engine btw little bit drivers side of center
Dr. Octawakaoctapus is offline   Reply With Quote
Message Board Statistics All times are GMT -4. The time now is 07:39 PM.
