Welcome to the North American Subaru Impreza Owners Club Monday December 5, 2016
Old 09-18-2012, 12:51 AM   #1
jokers
Member#: 136839
Default anybody?
wondering if u could answer this for me, at a stop shift gear is in neutral and 1st gear idle will be fine but once the car moves i leave it in 1st gear clutch depressed the idle dips low lower than idle until the car stops or i put it in neutral, another scenario ill be coasting down the road clutch depressed all the way in, in neutral idle will be idle fine just putting it in gear 1st gear to say the rpms dips, back to neutral idle comes up fine, in gear dips again????
im running sti ra gears, street act lightened flywheel and stage 1 act clutch
jokers is offline   Reply With Quote
Old 09-18-2012, 12:59 AM   #2
recce02
Member#: 13815
02 GCRally prepped
277TQ 281HP 19PSI
How long has the fw and clutch been in?
recce02 is offline   Reply With Quote
Old 09-18-2012, 01:24 AM   #3
jokers
Member#: 136839
april of this year , could it be a tuning issue, i still need to get my car tuned
Old 09-18-2012, 01:33 AM   #4
brew02wrx
Member#: 259970
2002 wrx cobb stg2+
psm proper fitment
I think it can be tuned out, not 100% on that tho best bet would be to talk to a tuner and see what he thinks about it and if its possible
brew02wrx is offline   Reply With Quote
Old 09-18-2012, 03:54 PM   #5
ride5000
Member#: 32792
2003 GGA MBP
12.9 / 105+
the ecu is aware of a neutral position switch in the tranny.
Old 09-18-2012, 04:30 PM   #6
jokers
Member#: 136839
i'll see if its a tuning issue
Old 10-06-2012, 07:39 PM   #7
jokers
Member#: 136839
update, tuning the car has no effect
something in the transmission or something? clutch?
