Old 10-06-2012, 02:03 PM   #1
99redimpreza
Member#: 320998
Default Where do i hook up a rpm gauge
I have a 99 impreza and it doesn't have a rpm gauge I tried everything and can't find the wire to tap into to. Can anyone help
99redimpreza is offline   Reply With Quote
Old 10-07-2012, 09:09 AM   #2
hoffmanEstates
Member#: 122043
04 wagonier
psm
Don't ya tap into something under the Hood. Like on the distributor or something
hoffmanEstates is offline   Reply With Quote
Old 10-07-2012, 09:32 AM   #3
CRAZYHAWK
Member#: 198067
2009 IMPREZA 2.5i 4d
WHITE Premium
cam position sensor would give 1/4 rpm reading.
crank position sensor would give 1/2 rpm reading.
Good luck
CRAZYHAWK is offline   Reply With Quote
Old 10-07-2012, 10:11 AM   #4
alt14
Member#: 271928
2014 WRX Limited
Crystal Black Silica
Take the cluster out, unplug everything from it, hook your gauge up, start the car then start sticking the wire for the signal into the pin connectors for the cluster till you find the right one, mine was dark green with a black line and silver squares in it, after you find which one is the right wire, use a vampire clip to tap into the wire
alt14 is offline   Reply With Quote
Old 10-07-2012, 10:37 AM   #5
Uncle Scotty
Member#: 16200
OK buy Nates beans
westcoastroasting.com
on my gawd.....
YOU are the heart of all that is stupid in this world
Old 10-07-2012, 12:52 PM   #6
alt14
Member#: 271928
2014 WRX Limited
Worked fine for me stupid or not, just out of curiosity for future reference what was wrong with the way I did this so I don't have problems if I should ever need to find this again?(only did it this way to try and get the tach on an sti cluster to work)
Old 10-07-2012, 05:40 PM   #7
99redimpreza
Member#: 320998
I tried to get to the coil pack and I tried all the wires and nothing. Would there still be a plug in in the dash if I don't have a tack gauge in it?
Old 10-07-2012, 06:05 PM   #8
alt14
Member#: 271928
2014 WRX Limited
I thought that the wire was still there from the factory with or without the tach stock
Old 10-07-2012, 06:07 PM   #9
69subaru360
Member#: 159682
1995 WRX
2015 F150
Just pick up a factory tachometer, it will cost next to nothing used and just plugs right into your existing cluster in place of the blanking plate. No wiring needed at all.
Old 10-07-2012, 06:24 PM   #10
99redimpreza
Member#: 320998
The thing is I just bought a aftermarket one. I looked online and everywhere. I can't find the plug in. Wire or nothing.
Old 10-07-2012, 06:28 PM   #11
alt14
Member#: 271928
2014 WRX Limited
Would the connector for the factory tach be just its own connector?
If so you can just narrow down the tach signal to that connector
Old 10-07-2012, 08:49 PM   #12
99redimpreza
Member#: 320998
There is three plug ins with a bunch of wires going into them. I still couldn't find it. Could I tap into the alternator?
Old 10-08-2012, 11:42 PM   #13
alt14
Member#: 271928
2014 WRX Limited
I'm not sure that would have an rpm signal
Old 10-09-2012, 09:33 AM   #14
Uncle Scotty
Member#: 16200
OK buy Nates beans
you need to stop screwin around before ya blow the electrical system up
sell the kiddie tach and get a factory cluster to use while ya learn something about how TO do things....not how NOT to do things
Old 10-10-2012, 09:52 PM   #15
99redimpreza
Member#: 320998
Thanks for that MOM..............................................z z
