Old 10-06-2012, 03:18 PM   #1
justinbrigham12man
Member#: 334311
Default 2006 stock sti misfire...?
Hey guys..my sti has a misfire on cylinders 1and 3...I replaced the plungs and didn't make a diffrrence..I have yet to replace the coil packs but plan on doing that ...my Cel light is on and my Cruise light flashes on and off..?.it doesn't lug and has plenty of power ...but...only on warm start up the car has a super rough idle for a few seconds..then starts running smooth...??? HELP..
justinbrigham12man is offline   Reply With Quote
Old 10-06-2012, 03:37 PM   #2
HinshawWRX
Medium Frank
Member#: 140114
2014 Porsche
GT3 (Currently on Fire)
Try swapping the coils. Then if nothing changes, swap the injectors.
FYI the cruise light will flash to tell you it is disabled. You cannot use cruise with a CEL on a Subaru.
Old 10-06-2012, 04:16 PM   #3
justinbrigham12man
Member#: 334311
Sounds good I'll do that..thanks for the help..
Old 10-06-2012, 04:35 PM   #4
STi410
Member#: 158800
2010 STi
good luck and let us know if this fixes things
STi410 is offline   Reply With Quote
Old 10-06-2012, 04:46 PM   #5
justinbrigham12man
Member#: 334311
Just a question about the injectors...if the investors were bad wouldn't the car lug under load and run sluggish all the time..?
Old 10-06-2012, 07:45 PM   #6
elemperador87
Member#: 330600
Mine dose the same thing did the coils and still the same let me know what happens to urs
elemperador87 is offline   Reply With Quote
Old 10-06-2012, 11:52 PM   #7
justinbrigham12man
Member#: 334311
Will do..
Old 10-07-2012, 04:28 PM   #8
'02 Subaru Rex
Member#: 160725
2005 STi
WRB sittin on GOLD
Have a compression test done??? Misfire is sometimes indicative of a head gasket...how many miles do you have?
'02 Subaru Rex is offline   Reply With Quote
Old 10-08-2012, 10:52 AM   #9
justinbrigham12man
Member#: 334311
I had a compression test done and everything was in the right ratios...it only has 49k on it
