Old 10-06-2012, 06:40 PM   #1
jokers
Member#: 136839
Default misfires
im getting a check engine light giving me all this
Diagnostic Trouble Code(s):
DTC MEMORIZED: P0301 MISFIRE CYLINDER 1
DTC MEMORIZED: P0302 MISFIRE CYLINDER 2
DTC MEMORIZED: P0303 MISFIRE CYLINDER 3
DTC MEMORIZED: P0304 MISFIRE CYLINDER 4
DTC MEMORIZED: P0000 PASS CODE (NO DTC DETECTED)
car drives fine, in the process of tuning it
jokers is offline   Reply With Quote
Old 10-06-2012, 06:50 PM   #2
kendalja
Member#: 321043
2002 WRX Wagon
Good luck man I'm chasing down misfires as well!
kendalja is offline   Reply With Quote
Old 10-06-2012, 07:12 PM   #3
kendalja
Member#: 321043
2002 WRX Wagon
What mods / year / model?
Old 10-06-2012, 08:15 PM   #4
quazimoto
Member#: 70395
It's because of the lightned flywheel. Read the FAQ's..............
http://forums.nasioc.com/forums/show....php?p=9878792
quazimoto is offline   Reply With Quote
Old 10-06-2012, 09:15 PM   #5
Groundup
Member#: 294682
02 wrx
Sedona Red
I told him that once already, hopefully he listens to you.
Groundup is offline   Reply With Quote
Old 10-06-2012, 09:40 PM   #6
jokers
Member#: 136839
good point, just wierd that ive had it for a long time and only now getting the check engine light
Old 10-06-2012, 09:41 PM   #7
kendalja
Member#: 321043
2002 WRX Wagon
Jokers: how long have you had the lightweight flywheel in for? Everyone has been saying its mine as well but it's been in for 20k. Also what brand?
Old 10-06-2012, 09:49 PM   #8
jokers
Member#: 136839
act street
just weird cuz im etuning and it started popping up the light all of a sudden, before the tuning was fine
Old 10-06-2012, 09:49 PM   #9
jokers
Member#: 136839
im gonna be changing back to the stock flywheel though, hate the chattering etc
Old 10-25-2012, 11:59 AM   #10
jokers
Member#: 136839
i have changed back to the stock flywheel and have a lightened crank pulley
i still get the misfire codes?
my idle still dips and with the heavier flywheel it sure shakes heavy until it catches itself?
btw i have a hybrid build, it idles around 850-950
Old 10-25-2012, 12:35 PM   #11
kendalja
Member#: 321043
2002 WRX Wagon
Get rid of that lightened pulley also!
Old 10-25-2012, 01:04 PM   #12
rocketperson7
Member#: 283968
2003 WRX
MBP
I'll trade pulleys if you want OP
rocketperson7 is offline   Reply With Quote
Old 10-25-2012, 03:15 PM   #13
CanadianImprezaSTi
Member#: 312159
2004 WRX
I know I post this in most misfire threads haha, but do you have your EGT Sensor still? If so do the resistor mod to it and report back. If it's on it's way out it can tell the ecu false misfiring.
Joel
CanadianImprezaSTi is offline   Reply With Quote
Old 10-25-2012, 10:01 PM   #14
jokers
Member#: 136839
ur talking about the sensor at the bottom of the downpipe? if yes no i do not i have my a/f sensor in place
Old 10-25-2012, 10:02 PM   #15
jokers
Member#: 136839
looks like ill have to try that too
Old 10-25-2012, 10:05 PM   #16
kendalja
Member#: 321043
2002 WRX Wagon
Anything that is lightened can cause misfires. As mentioned I would ditch the lightweight pulley. Did you replace the stock flywheel yourself? Was it hard?
Old 10-25-2012, 10:52 PM   #17
rocketperson7
Member#: 283968
2003 WRX
MBP
but seriously..if you want/need to trade for a stocker, let me know
Old 10-26-2012, 09:36 AM   #18
jokers
Member#: 136839
i have my stocker crank pulley
yea i changed it myself, i pulled the engine out, did some other things as well
Old 10-27-2012, 01:42 PM   #19
dgriff992002
Member#: 158090
2004 Impreza WRX WRB
Hta68 ewg 382 awhp on e85
I recently started having misfire issues in cyl 2 I've had thr perrin pulley for 4yrs never had an issue til now ... At wot it hesitates bad & get poor mpg
dgriff992002 is offline   Reply With Quote
Old 10-27-2012, 02:09 PM   #20
s0ber_p
Member#: 172689
2004 WRX
The lightweight items will cause a misfire in ALL cylinders, not just one. Likely you have a bad injector, coil or plug.
That being said, I have never seen a EJ engine have misfire issues from just a lightweight pulley. Flywheel sure, if it is super lightweight, but not only the pulley.
s0ber_p is offline   Reply With Quote
Old 10-27-2012, 11:46 PM   #21
CanadianImprezaSTi
Member#: 312159
2004 WRX
No, I'm talking the one on the top of the uppipe.
Joel
Old 10-28-2012, 12:24 PM   #22
jokers
Member#: 136839
i dont have one on the uppipe, been deleted years now
Joel
Old 10-16-2015, 10:50 PM   #23
bnelson748
Member#: 432310
Default simmilar issue, any help grateful, log attached
https://drive.google.com/file/d/0B_2...ew?usp=sharing
very simmilar issue, just replaced timing belt and started up to find missfires on all 4 cylinders, cracked back into it and realized the lines on the new belt did not match up (was very much rushing on first install) reinstalled and bingo, perfect, ran great and no issues, no cels after many hundred miles. now out of nowhere these codes : P0000 PASS CODE (NO DTC DETECTED) false true
P0301 MISFIRE CYLINDER 1 false true
P0303 MISFIRE CYLINDER 3 false true
.... does the log look ok, it looked fine to me, and what would cause these codes... im pretty confident its not the timing belt after i reinstalled it everything was lined up and on its proper teeth, could it have jumped teeth? thanks, hope this might help with op issue, i would guess cams jumped teeth,, think mine did the same... im gonna tear back into it and check as well the sensors but i cant understand why the codes would take so long to appear
bnelson748 is offline   Reply With Quote
