Welcome to the North American Subaru Impreza Owners Club Thursday May 28, 2015
Old 10-06-2012, 06:41 PM   #1
96BARU
Member#: 132319
02 wrx
blue
Ok I have a 2002 Wrx. With a 2.5 block and a Ra gearset in the Trans. So in 08 I put a act hd clutch kit in the car ever since them I had to put a new disk in the car about once a year to present. Last December I got fed up with it and thought the car was just right at the power limit and put an act extreme with sprung six puc in the car. When installing it had trouble and found out from act that I had to run the 03 and up flywheel with both the Hd kit and extreme. Once it was in it chattered so bad that I took the six puc disk out and put an street strip disk in with the extreme pressure plate. The clutch stilled chattered just as bad as the six puc now to the point the Trans broke. While it was out I had the flywheel and pressure plate resurfaced sin e the six puc created some uneven wear to it. I figured it would solve the problem sure enough it didn't. I contacted act and they had me send everything to them and I received it last week and they said the disk was bent. So they provided me with a new disk. I just got done putting everything in and it still chatters very badly. Anyone have any solutions or have come across this issue. I also thought it might be a bad motor mount so that was replaced as well today thanks
96BARU is offline   Reply With Quote
Old 10-07-2012, 09:06 AM   #2
Aaron'z 2.5RS
Member#: 1026
'00 RS/WRX Stg5
'98 RS Stock
Cant read the brick of words, hit edit and hit enter a few places...
