Old 10-28-2012, 09:45 PM   #1
lb05wrx
Member#: 172704
2005 Impreza WRX
Default Weird vibration
Hello all,
I recently developed a vibration coming from the engine under moderate to heavy acceleration. It feels like the engine bogs and can't create the power. I have also been hearing more backfires especially after the engine bogs down. I've been thinking its something with the combusting either fuel, air or spark plugs but idk. Any ideas?
lb05wrx is offline   Reply With Quote
Old 10-28-2012, 10:31 PM   #2
burdo1990
Member#: 233300
2002 impreza wrx
Maybe a miss fire? Are you throwing a cel? If its flashing its deff a miss. Could be bad plugs or bad coil packs, I'd start with plugs if they haven't been done in a while.
burdo1990 is offline   Reply With Quote
Old 10-28-2012, 10:46 PM   #3
lb05wrx
Member#: 172704
2005 Impreza WRX
Not throwing a CEL and they're none pending. Plugs were done about 2 years ago.
Old 10-29-2012, 01:47 AM   #4
burdo1990
Member#: 233300
2002 impreza wrx
Are you running too rich so its just sputtering? I would deff change your plugs since its been 2 yrs
Old 10-29-2012, 02:33 AM   #5
lb05wrx
Member#: 172704
2005 Impreza WRX
I guess it's kinda like sputtering. The only thing I can compare it to is it feels like when I have no traction on dirt and the wheels spin. The wheels aren't burning out or anything it's when I push the gas more than half way the car sputters for a bit and then keeps going.
Old 10-29-2012, 09:38 AM   #6
frederik
Member#: 64405
2003 WRX Sedan
WRB - Cobb Stg 2
But the RPM does not go up during that time, right? (because that would be your clutch slipping from being worn out)
frederik is offline   Reply With Quote
Old 10-29-2012, 02:43 PM   #7
lb05wrx
Member#: 172704
2005 Impreza WRX
I don't think it's the clutch because I have replaced my clutch before. When the clutch starts to slip the revs start to climb when I accelerate but the speed stays the same. In this scenario the revs go up and the car accelerates with it but there is a vibration when I start to push it. It doesn't last for awhile, but it is still there.
Old 10-30-2012, 09:10 PM   #8
lb05wrx
Member#: 172704
2005 Impreza WRX
Update. Changed the spark plugs. Problem solved. I was just surprised that I didn't throw a CEL.
Old 10-30-2012, 09:12 PM   #9
frederik
Member#: 64405
2003 WRX Sedan
WRB - Cobb Stg 2
Good to hear. I might try that too for my ongoing knock and hiccups issue.
Old 10-30-2012, 09:28 PM   #10
frederik
Member#: 64405
2003 WRX Sedan
WRB - Cobb Stg 2
When you replaced the plugs, did you notice if the coil packs or the plugs were not tightened enough? Or was it all apparently all well tightened?
Old 10-31-2012, 01:02 AM   #11
burdo1990
Member#: 233300
2002 impreza wrx
Figured, always good to change them
Old 10-31-2012, 10:57 AM   #12
PrezaDriver2011
Member#: 336356
2005 Wrx Wagon
What was the vibration? I have a 2011 2.5i and I have a vibration when I first start to drive it then it goes away.
PrezaDriver2011 is offline   Reply With Quote
Old 11-03-2012, 02:44 PM   #13
burdo1990
Member#: 233300
2002 impreza wrx
His vibration was the car mis firing due to old spark plugs. Your vibration could be anything from low tire pressure, a wheel not balanced or your cars out of alignment which I would count out because its so new.
Old 11-04-2012, 01:27 AM   #14
BoboTheMonkey
Member#: 224615
2004 WRX
San Remo Red
What are the plugs gapped at? Out of the box NGK's come at .40 which could cause misfire since they are supposed to be gapped at quite a bit less depending on mods.
BoboTheMonkey is offline   Reply With Quote
