Mid West Subaru Owners Club
Go Back   NASIOC > NASIOC Chapters > Mid West Subaru Owners Club Forum -- MWSOC > MWSOC Private Classifieds
Old 10-07-2012, 09:05 AM   #1
wrxss
Member Sales Rating: (34)
Member#: 27361
02 Subaru WRX
Default Rear Tein Flex coilover (5x100)
I'm trying to replace my rear passenger side Tein Flex coilover due to the lower bracket piece seized onto the damper.
I'm only interested in non leaking/blown rear passenger Tein Flex coilover for 5x100 bolt pattern.
PM me with details. Thanks all
--Imran
wrxss is offline   Reply With Quote
Old 10-07-2012, 10:14 AM   #2
2gnt2wrx
Member Sales Rating: (47)
Member#: 123625
2002 wrx
vf34 Tuned at Cobb
Have you contacted tein? Maybe they could fix it?
2gnt2wrx is online now   Reply With Quote
Old 10-07-2012, 10:15 AM   #3
hoffmanEstates
Member Sales Rating: (28)
Member#: 122043
04 wagonier
psm
Remove knuckle and soak it.with pb. Or just soak it on the vechicle and pry bar it if not working use torch to heat and pry.. if fail then go buy a better set of coil overs
hoffmanEstates is offline   Reply With Quote
Old 10-07-2012, 12:37 PM   #4
wrxss
Member#: 27361
02 Subaru WRX
I appreciate the feedback guys.
I guess I worded it wrong. The coilover is off the car. Upon removing I was cleaning debri etc off the dampers and making sure I was able to adjust all the components.
It was then I noticed the lower bracket of one of the coilover was seized and would not adjust. I've soaked it in WD40 for weeks now and absolutely no play at all. Took it to a few shops hoping they would have better luck with their expertise but no luck.
I'll contact Tein tomorrow and see what they have to say.
--Imran
Old 10-07-2012, 01:54 PM   #5
hoffmanEstates
Member#: 122043
04 wagonier
psm
Try heat. Even. Do not over do it as strut might go kaboom or leak out some o ring
Tein will tell ya send it in. As they usually do.
Old 10-07-2012, 03:14 PM   #6
wrxss
Member#: 27361
02 Subaru WRX
Yea I'm afraid to try heat. Tein will definitely have me send it in. I'll explain my issue and see what they have to say.
Thanks!
--Imran
Old 10-07-2012, 08:11 PM   #7
dsristau
Member Sales Rating: (9)
Member#: 210383
2004 WRX
Java black
I heated my old jic's to the point they were glowing red to break them loose with no problems. Just try it. Worst thing that could happen is they'll leak and then you have to send them in to Tein anyways. Anti seize is your friend especially if you run them in winter
dsristau is offline   Reply With Quote
Old 10-11-2012, 10:46 PM   #8
wrxss
Member#: 27361
02 Subaru WRX
tttttt
Message Board Statistics All times are GMT -4. The time now is 10:02 PM.
