#1 |
Member#: 212154
South East
Vehicle:02 bugeye, manley ej257, pt5857, MBP on E85 |
So I blew a head gasket at 2500 miles on new build.
ej22t with 5857 turbo at 25psi on cometic. 027 thick gaskets. Using Arp head studds tq 30/60/90 ft/lbs. The block was decked and heads surface cut. Are cometic gaskets not that great or something? What are you big power guys using for head gaskets and studds? Car busted a heater hose so I repaird that. Filled with coolant only to have the car idle rough and spit coolant out the exhaust. Damn thing... kinda figured the gasket blew when the hose busted.
#2 |
Member#: 25768
RMIC
Vehicle:35R bugeye Awdsome |
Just use the stock head gaskets, they seem to work the best. I like to use the copper head gasket spray and add a few extra ft lb on the two center studs.
#3 |
Member#: 206851
Vehicle:99 V4 EJ20K RS |
your surface finish may not have been as smooth per cometic's tolerances
the gaskets aren't bad, they're so good that shoddy machine shops/idiot psuedo-builders here just bitch when their shortcomings result in failure. |
#4 |
Member#: 212154
South East
I assure you it wasn't anything to do with the build process or mchining. I doubled checked the surfaces with a mac straight edge and was WAY within spec. Also used a digital snap on tq wrench. I was told by quiet a few peeple not to use cometic due to not holding boost past 25 psi.
#5 |
Member#: 134949
VIC
Vehicle:'07 SWP STi Twinscroll ViPec Anti-lag |
Built a few engines using oem gaskets, 29 psi no problems. Went cometic on most recent build and pushing coolant at 25psi. I'm not the only one too. Going with cosworth gaskets now. There's an article on motoiq comparing actual clamping load on oem vs cometic vs cosworth.
#6 | |
Member#: 212154
South East
Let's talk studds. Is there a better option than the standard ARP? One that doesn't need to be tq higher than 90 ft/lbs as that is what I had the tq plates at when it was honed. |
#7 | |
Member#: 163108
International
Vehicle:07 EuroDM STi 2.5L Silver |
http://forums.nasioc.com/forums/show...2313586&page=3 |
#8 |
Member#: 212154
South East
While were on the subject, what about the spray sealants like copper sealant and hylomar? How many of you actually remove the rivet on the mls gaskets and clean between them before applying a sealant?
#9 |
Member#: 84105
SCIC
Vehicle:2005 Super Slow STi CGM |
Cometics are very picky when it comes to the RA finish of the decks.
