#1 |
Member#: 238820
Vehicle:13 wrx hatchyyy ISM |
I wanted to go a little wider with my back wheels. Can I fit 18 x 10 73mm offset on my 06 wrx. Or should I just stick with 17x9.5 68mm offset.
#2 |
Member#: 97135
NWIC
oh god.
NEITHER of those will work. WAY too high. we have this thing called the "wheel and tire" forum that has 2 threads specifically relating to wheel/tire fitment as well as how to correctly measure and calculate offset. simply put, with a question like that, its quite obvious you are pretty new to wheel fitment (which is fine), you don't need to be worrying about a wheel wider than 8". |
#3 |
Member#: 180204
AKIC
Vehicle:2005 FXT Stg II 1/2 SSM |
I'm no wheel expert by any means but 17x8 35 offset is probably about right without rubbing. Someone correct if I'm wrong
#4 |
Add Lightness
Moderator Member#: 13699
NESIC
Vehicle:2007 Lotus Elise (From General) |
That offset will look like this, and I am not kidding.
#5 |
Member#: 263949
NESIC
Vehicle:2007 WRX Wagon Ltd. WRB |
#6 |
Member#: 286408
Vehicle:2005 P&L Tuned STi WFC #952 |
Go look up my posts. I'm not showing you as I am lazy but I've run 17x9 +30 no a 225/45/17 and it fits fine when dumped with appropriate fender work. Those offsets you posted are too high and you won't be able to clear your suspension with that amount of backspacing
#7 | |
Member#: 261612
Vehicle:2011 WRX 5 Door NF Performance Stage 1 |
I agree that the OP is probably looking at hub bore instead of offset. |
#8 |
Member#: 239469
Vehicle:2004 WRX PSM for now ;) |
![]() ![]() ![]() I know it's the newbie forum but ![]() |
#9 |
Add Lightness
NESIC
