Old 10-08-2012, 07:16 AM   #1
Black07STiGuy
Member#: 155930
2008 WRX Josh Tuned
VF39+JoshTune=330hp/350tq
Default "Lift springs"
Hey guys, I have searched around and can't find an answer so I have come here for knowledge.
OK so here what I would like to know: what spring/strut combo can I buy used off of another year/model Subaru that I can use to lift my wrx in the winters? As you can see in my profile I have an 08 wrx sedan. Any insight would be awesome. Thanks in advance.
Chris
Black07STiGuy is offline   Reply With Quote
Old 10-08-2012, 07:39 AM   #2
Aaron'z 2.5RS
Member#: 1026
'00 RS/WRX Stg5
'98 RS Stock
Drop the top-hats install longer bolts and spacers, bolt top hats back up, get alignment..
Old 10-08-2012, 08:23 AM   #3
gsrcrxsi
Member#: 236952
2010 WRX (SSM)
Stg "2+" 300hp/360trq
You can use 2009+ forester struts with WRX springs. That will raise you about an inch.
Or you can use King Standard Springs. About 1/4" lift with 25-30% stiffer rates. Recommend upgraded shocks. Bilsteins or Konis.
Or you can use King Lift Springs. About 1-1.5" lift with 25-30% stiffer rates. Recommend upgraded shocks. Bilsteins or Konis.
Or you can use spacers, personally I don't like this option since you don't get any added bump travel, which can be advantageous.
gsrcrxsi is offline   Reply With Quote
Old 10-08-2012, 09:03 AM   #4
Aaron'z 2.5RS
Member#: 1026
'00 RS/WRX Stg5
'98 RS Stock
Recently saw this at a semi-local shop that does Subaru motor rebuilds (SSi Subaru Specialists)
and this
I didn't get pics of the spacers, but literally, they took the bolts out of the tophats, installed longer ones and had 3 1.5" diameter aluminum rod-stock spacers per strut, they simply center drilled the rod-stock for the bolt diameter and bolted it back up...
Old 10-08-2012, 09:06 AM   #5
Aaron'z 2.5RS
Member#: 1026
'00 RS/WRX Stg5
'98 RS Stock
Primitive Racing sold/sells similar spacers set-ups as well
Old 10-08-2012, 09:26 AM   #6
Black07STiGuy
Member#: 155930
2008 WRX Josh Tuned
Hey guys thanks for all the replies. I will go do some research on what you guys have provided and see if I can put a kit together for a couple hundred. I have Cobb drop springs now and have lost my stockers in one of many military moves. So we will see. Thanks again guys
Old 10-08-2012, 10:41 AM   #7
Black07STiGuy
Member#: 155930
2008 WRX Josh Tuned
and this
Do they have a website or can you provide a contact number? Please and thank you.
Old 10-08-2012, 11:00 AM   #8
Uncle Scotty
Member#: 16200
OK buy Nates beans
westcoastroasting.com
WAY more hassle than it is worth
just find some decent springs and be done with it
Old 10-08-2012, 11:12 AM   #9
Black07STiGuy
Member#: 155930
2008 WRX Josh Tuned
OK I'll take your word for it. Do you know if like forester springs will work on my struts?
Old 10-08-2012, 12:54 PM   #10
sc00by4life
Member#: 97135
they'll be too long.
forester struts + wrx springs will give you a solid 2", as well as moving the spring perch higher so you can run a taller tire.
Or, just buy a set of 09+ forester take off's and swap the entire unit over. it will save you the hassle of only swapping out springs or struts alone.
Old 10-08-2012, 02:19 PM   #11
Aaron'z 2.5RS
Member#: 1026
'00 RS/WRX Stg5
'98 RS Stock
Google will know.. (im on my phone cureently)
Old 10-08-2012, 02:24 PM   #12
Aaron'z 2.5RS
Member#: 1026
'00 RS/WRX Stg5
'98 RS Stock
So somehow swapping springs summer/winter is going to be easier than unbolting the tophats/kuckles and installing spacers... Call me crazy, but no...
Old 10-08-2012, 03:27 PM   #13
sc00by4life
Member#: 97135
Either way the whole unit has to come out.
Might as well just swap in a fully assembled forester or outback unit.
Old 10-08-2012, 03:32 PM   #14
Counterfit
Member#: 124254
2006 06 SGM Slowbaru
"The Scoobinator"
You have to take the tophat off the strut to change springs. It doesn't seem like that's necessary for the spacers mentioned in this thread.
Counterfit is offline   Reply With Quote
Old 10-08-2012, 07:06 PM   #15
Uncle Scotty
Member#: 16200
OK buy Nates beans
no-no-NO
swapping suspension seasonally is a fools errand
find ONE set of springs and THAT'S IT AND DONE
needing to swap suspension out means ya need another vehicle or ya got the wrong vehicle
Old 10-08-2012, 09:47 PM   #16
Black07STiGuy
Member#: 155930
2008 WRX Josh Tuned
no-no-NO
Although I admire your conviction, I wouldn't be asking if I didn't want to do it. Suppose to be a heavy winter and I think it's worth it to not be a snow plow and risk buying another front bumper.
Old 10-08-2012, 09:57 PM   #17
bue car
Member#: 176134
07' Impreza STi wrb
95 L...
king lift springs.
bue car is offline   Reply With Quote
Old 10-08-2012, 11:43 PM   #18
Black07STiGuy
Member#: 155930
2008 WRX Josh Tuned
Originally Posted by bue car
king lift springs.
Thanks man. Now I just have to figure out what year forester is interchangeable with my 08 wrx
Old 10-09-2012, 12:49 AM   #19
bue car
Member#: 176134
07' Impreza STi wrb
95 L...
no problem. check with Anthony. He's super knowledgeable!
http://www.vaughnperformance.com
Old 10-09-2012, 01:53 AM   #20
Black07STiGuy
Member#: 155930
2008 WRX Josh Tuned
Thanks buddy. I put an email into them.
Old 10-09-2012, 07:50 AM   #21
Aaron'z 2.5RS
Member#: 1026
'00 RS/WRX Stg5
'98 RS Stock
no-no-NO
Roll your eyes all you like, its not what the OP asked...
We all know you're the "man"... But your word ISNT the final word... Thanks
Old 10-09-2012, 08:09 AM   #22
Black07STiGuy
Member#: 155930
2008 WRX Josh Tuned
It's OK. Not his fault he was born with a small penis. He has to make up for it some How.
Old 10-09-2012, 03:26 PM   #23
sc00by4life
Member#: 97135
While he can be a dick, he's one of the most knowledgable people on the forum. If you don't like his wording, just keep scrolling.
09+ is a direct swap. (I mentioned this earlier in the thread).
Old 10-09-2012, 03:46 PM   #24
Aaron'z 2.5RS
Member#: 1026
'00 RS/WRX Stg5
'98 RS Stock
I doubt its got anything to do with penile anything...
Smart people tend to act this way, god knows US has helped me over the years... Its just thinking your word is the final say is where things go sideways...
Old 10-10-2012, 12:29 AM   #25
gsrcrxsi
Member#: 236952
2010 WRX (SSM)
Yeah.
I still don't know if I want to go with the LIFT springs or the standard springs.
