Old 08-04-2013, 11:24 PM   #1
Mechie3
Member#: 120152
Default Mechie3's Factory Five 818S
For that that are unaware, Factory Five Racing (makers of the Roadster, aka "Cobra Kit Car") have designed a kit car to use a Subaru WRX as a donor. The 1800lb completed car is a 2 seat, mid engine, RWD, open top roadster.
I was asked to start a build thread, though the "build" started a year ago June when a lady ran a red light totaling my 2006 WRX. I won't lie and say I didn't think about building an 818 as I stood on the side of the road watching the crews clean up everything.
Instead of rehashing the entire story, tear down, and what have you, I'll just post some videos to get you up to speed. Long story short, I bought the impreza back from insurance, got a decent payout for the totaled car, and just had my kit (chassis #15) delivered Friday.
The tear down:
Friday video. I made the mistake of trying out 1sec photo intervals. Bad idea. I previous used 10sec which resulted in 1000 photos to make a video. I had 1,400 pictures to compile which took forever and then Vimeo said "sorry, your video is too big. So, for your youtube viewing pleasure... Day 1. Not terribly exciting.
Here's the video from Saturday. Photos now at 5sec spacing, but played back at the same rate per frame, so time is 5x faster. Makes for shorter videos, easier rendering, and prevents ADD. For some reason, it seems to render the first two frames at the very end as well. Who knows why. Placing, drilling, cleco-ing, and aligning firewall and some interior panels
A few random pics:
From my original build thread (not on Nasioc)
And so it begins!
I find it only fitting that the second chapter of my WRX begins where the last chapter left off. Here is where the sadness of losing the WRX is replaced with excitment that through the accident, the 818 project is fully funded with a known history donor car. God works in mysterious ways.
From lemons comes lemonade, from my wrecked WRX comes the 818.
Oh Hello!
First part off the truck!
Hanging by a thread!
Vroom Vroom!
Old 08-05-2013, 06:46 AM   #2
25rsti
Member#: 166324
Wow, you're stong holding that chassis in the air! lol
Congrats on the project. I was looking into getting one of those but it just wasn't the right thing for me. Can't wait to see more pics and progress.
25rsti is offline   Reply With Quote
Old 08-05-2013, 11:33 AM   #3
Mechie3
Member#: 120152
Day 3 video finished uploading. Mostly fitting the fuel tank (still needs work), rear firewall, and the center tunnel (required some trimming to clear two weld beads in the front).
Old 08-06-2013, 09:51 AM   #4
Mechie3
Member#: 120152
The suspension spacers provided by FFR are saw cut plain steel. I measured them and most of them were actually within +/- .005". Certainly good enough and cost effective too. I was going to deburr them and powder coat them when I realized I could just make my own from stainless steel, save money on coating, and not worry about the coating wearing off.
Top row of each set is the FFR spacers, bottom row are mine made from solid rod stock I found in the scrap pile.
Here's all I got done last night. The control arms were a bit tricky to get in. Passenger side was easier. Driver side I put the top bolt in first with the aluminum bracket 1/2" above the steel so I had room to angle the lower bolt in place. Tapped it in with a mallet. I couldn't find nuts for the bolts in the hardware package. I'll have to look again. I was too tired last night to do anything straight after awhile.
Old 08-06-2013, 10:19 AM   #5
krang00
Member#: 364524
Can't wait to see this thing finished!
krang00 is offline   Reply With Quote
Old 08-06-2013, 06:44 PM   #6
lil'redwagon
Member#: 10854
2002 Sedan V8 ej207
Dom 3 XT-R, 400WHP
subscribed! i'm on the fence about these kits. depending on what the street coupe ends up looking like, and how your build goes, i just might pull the trigger.
lil'redwagon is offline   Reply With Quote
Old 08-06-2013, 07:00 PM   #7
torquemada
Member#: 128484
2006 EDM WRX STI
too much bandwith used, you pb account sucks
Old 08-08-2013, 10:31 AM   #8
Mechie3
Member#: 120152
Yep. I'm too cheap to pay for an upgraded account. I'll probably have to do that. Bandwitch exceeded in just over 12 days into my month. The vimeo videos still work.
Got a few things done.
Rear suspension links. Some of the spacers were tight! Able to use a pry bar in some areas, had to grind down the spacers in others. I checked my measurements and they were all within .005", but .005" x 3 pieces is .015", a considerable overlap and not unexpected. Thankfully the camera died partway through so you don't see me fumbling around with a hammer.
Shifter: Located it, installed riv nuts....spacing is off. Waiting to hear from FFR what they did on their white car. I was hoping for enough compliance in the bushings to make it fit, but there isn't. Edit: FFR is making some offset washers for these.
Gas Tank: I had to pound the corner in. FFR has already updated the components for future kits. It got it to fit, then got "greedy". I wasn't happy with the clearance so I gave it a little more and got too tight to of a wrinkle to feel comfortable. Back to my original plan of cutting the corner, bending the sheets in, and re-welding it. Got it mounted so it fits really easily now though. Started on the in tank assemblies too, but I'm missing two parts to get very far.
Old 08-08-2013, 04:58 PM   #9
Mechie3
Member#: 120152
Painted my trans cover with WRB paint, clear coated, then machined out the Zerodecibel Motorsports logo in the middle. Didn't like the machine marks from 5 different tools all visible so I decided to spray silver in a cup, pick it up with a syringe, then let it bleed out in teh cavities. Good idea, bad execution. It must have retained some gas in the paint because as it bled out it would randomly spatter all over. I'm letting the silver dry and then I need to redo the paint on the raised portion of the monkey by hand.
Old 08-08-2013, 11:43 PM   #10
dgyukujian
Member#: 364842
dgyukujian is offline   Reply With Quote
Old 08-09-2013, 01:02 AM   #11
Mechie3
Member#: 120152
Thanks to Travis, I got a super deal on powdercoating a bunch of steel brackets and aluminum panels. I think I had a total of 78 pieces powdercoated for less than it would cost me to buy an eastwood gun and powder.
Old 08-09-2013, 07:06 AM   #12
Mechie3
Member#: 120152
Last nights video. Inventoried powdercoated pieces (with thanks to Travis Camp) and installed the rear suspension. Went and played vball in between, thus the change of clothes halfway through.
Old 08-09-2013, 04:28 PM   #13
Mechie3
Member#: 120152
Used a toothpick and model car enamel to hand paint the monkey. After it dries I'll clear coat it all.
Old 08-11-2013, 09:03 PM   #14
Mechie3
Member#: 120152
Some riveting video.
Old 08-11-2013, 09:04 PM   #15
ZOPTAA
Member#: 364432
ZOPTAA is offline   Reply With Quote
Old 08-11-2013, 09:55 PM   #16
96accord
Member#: 145105
2015 WRB WRX Limited
2007 WRX Limited (sold)
Some of the pictures exceeded bandwidth
96accord is offline   Reply With Quote
Old 08-12-2013, 09:50 AM   #17
Mechie3
Member#: 120152
Yeah, those are the photobucket ones. I've switched to Imgur for my latest photos but most of them are only good as a resource for the next round of builders not so much for ooing and aahing. PB will reset on the 24th. I'll take more pics when I get something picture worthy.
Didn't get a whole lot this weekend. Saturday was my wife's Bday and we had our scuba diver certification dives saturday afternoon and sunday am. Managed to get a couple hours in Sunday evening after a nap.
Old 08-14-2013, 09:14 AM   #18
Mechie3
Member#: 120152
The only "bad" part of being an early adopter is being one of the first to try out production parts. The mount for the steering rack was a little off and while it's currently being fixed by FFR, I didn't want to stop and wait.
Here's my solution to the no bushing not quite right bracket. It's a simple aluminum block sized to mate with the bushing and upper bracket and bolt through the existing holes. I didn't need a CNC, just a manual mill and a jig boring head. It's kind of blocky looking, but now that I know it fits I can go back and pretty it up with some radii. No sense wasting time adding radii to something you might end up scrapping.
Here's my video from Monday. Missing springs and I lost the cone adapters for the OEM ball joints. DOH. Probably in that box of scrap metal that I accidentally put three parts in that werent scrap.
Pedals and cylinder installed:
Old 08-15-2013, 02:02 PM   #19
Mechie3
Member#: 120152
Just in case someone out there is listening.
Video from Tuesday finished uploading. Had to use the usb power cable which doesn't let me use the go pro housing, so the angles are a bit benign without very good views.
I've always wanted a cool looking alternator. Since my motor isn't ready to go in yet anyways I figure I might as well "waste" more time prettying things up. Painted with legitimate WRB paint and clearcoated. Center portion painted in black. Replaced rusty hardware (had to drill out 4 of the screws) with stainless. Now to see if it still works when I plug it back in...
Old 08-15-2013, 02:38 PM   #20
ScoobyJD
Member#: 185910
Everything amazing as always mechie!
ScoobyJD is offline   Reply With Quote
Old 08-15-2013, 03:25 PM   #21
franchisco7
Member#: 286429
1989 Nissan Cefiro
Blue Pearl
I'm listening and its amazing!
franchisco7 is offline   Reply With Quote
Old 08-15-2013, 03:41 PM   #22
GMU-BRZ
Member#: 332040
Yeah I haven't chimed in yet but I'm subscribed and check out every update. Keep em coming!
GMU-BRZ is offline   Reply With Quote
Old 08-15-2013, 03:47 PM   #23
dburgoon
Member#: 310366
03 vf37'd WRB
Bugeye
Sweet! I've been waiting for someone to do a build thread on one of these! Can't wait for the final product!
dburgoon is offline   Reply With Quote
Old 08-16-2013, 02:17 AM   #24
lil'redwagon
Member#: 10854
2002 Sedan V8 ej207
Dom 3 XT-R, 400WHP
i'm still here, El Guapo!
Old 08-16-2013, 09:29 PM   #25
MDRex
Member#: 38477
2015 Crosstrek
Orange
Very nice, can't wait to see the completion of this car. It's very tempting to me, but I think the Cobra will come first.
MDRex is offline   Reply With Quote
