#1 |
Member#: 155178
Vehicle:06 STG 2 WRB |
I just got the full results back on my leakdown test and 4th cyl ringland is toast
so what i an asking i am looking at doing forged pistons i would like to get to 350 whp..I am guessing it would be wise to do rods also anything else i should do also while i am in there i teally dont want to do sleeves i was told ther would be no need for them at the goals i want to make bit just wanting some oppions... also i have worked on lots of motors but never torn into a boxer engine before so i would to do it myself to save some cash to throw towards a bicer turbo... Shoot anything at my like what pistons rods do you guys like CP i here makes good pistons never looked into there rods
#2 |
Member#: 329319
CP pistons are great, and if you are looking to save a little money, I suggest going with Eagle rods. For the power levels you are looking at, Eagles will be more than enough rod for you.
#3 |
Member#: 68647
Vehicle:07 STI Rotated 35R Jorge Tuned |
If you want to be real smart about it, you need to decide what if any plans you have for the car. What fuel do you have available in your area? How much money do you plan on investing into your car? Do you already have a tuner? If not, now would be a good time to find a reputable shop and get their advice on your plans.
350whp honestly is not a ton of power so you really won't need the most ballar set-up to make it reliable. I think who does the engine build will play the biggest roll in how long it's going to last. The only advice I can really give you at this point is don't buy too much turbo if all you're looking for is 350whp. Spend some time in the Proven Power section of the forum and check out other peoples set-ups that are in a similar power range as your goal. Blouch Dom 3 XTR comes to mind if you plan on sticking with stock location. Or check out the latest and greatest from Forced Performance. |
#4 |
Member#: 155178
92oct i would like to keep the turbo in the stock location if i can i would also like a turbo with more headroom for when i get my 6 speed swap and that wont be till next summer...
I have been told eagle rods suck by people then other people to tell me they are great so go figure lol.. how hard is it to do pistons and rods on our blocks like i said i have torn into many blocks before just never a boxer engine i have a tuner already but he really said it was my choice.. On pistons and rings he said there is a upside and downside to them all problem is they are a great shop for tuning cars but they do not rebuild blocks in their shop so i was going to do it or find another shop that does I have never had a shop rebuild a motor for me so when you ask my budget i guess what is about the going rait for a shop to do pistons and rods ??? |
#5 |
Member#: 171773
South East
Vehicle:04 wrx sti jbp dom 3 xtr w meth! |
cp pistons manley rods valve springs arp head studs. While you rebuilding your engine you might as well do it right. Even if it costs a little more just do everything. Not saying get cams and everything but do pistons rods and all the basics.
#6 |
Member#: 155178
Yeah i was going to do head studs as they are not to much extra what is a good brand of valve sorings have not looked into those to much
#7 |
Member#: 68647
#8 |
Vehicle:OK Houston we have an Uncle |
wrong forum
#9 |
Member#: 232430
RMIC
Vehicle:555 I haz 5 Subarus GC8/GF/SG/GD sedan & wag |
CP pistons are loud as hell and uncoated Ive seen them do some really bad scoring of the cylinder walls in very short time. Either get them with the coating or buy something that comes with a coating. Or send them to Specialized coatings in So cal (is where JE sends their pistons to be coated).
#10 |
Member#: 155178
What pistons do have coatings never even thought of that
#11 |
Member#: 314810
Vehicle:2009 STI SWP |
eagle rods have worked great for me in my experience, used to be problems with the rod bolts but now they use arp rod bolts and ive taken eagle rods to 600whp for over 50k miles
#12 |
Member#: 68647
Any data/tests on how long these coatings actually last? If it buys you another 10k miles on your built block I'd say it certainly would be worth the money. If it is made to stay on for a few races (or say between engine rebuilds for a pro race team) then it may not add a whole lot of life to a built engine that is being driven on the street/highway where miles are racked up pretty quickly.
