Welcome to the North American Subaru Impreza Owners Club Wednesday September 2, 2015
Old 10-08-2012, 08:25 PM   #1
Layvon
Member#: 195711
STi 04/05/06/07
JBP / OBP for now
Default Logging Wideband Serial
I have had some major issues trying to get my computer to read this serial output from my AEM wideband. I have searched.
Hardware:
I have Windows 7 32 bit professional.
I have a gigaware cable
I have a Busted finger motor sport female serial adapter.
Black lead I have a 10ga wire hooked to, and tried grounding under the passenger seat where that ground stud is. And up near the ECU.
Blue Lead is obviously coming from the gauge. I'd estimate I have about 6-7feet of 14 gauge wire coming to that. I'm using a bolt through two ring terminals, that way once it is working, I can push the aem blue cord back into the bottom of the gauge pod, and it is out of sight till i want to log again. I dno't think that this connection is an issue as I have it bolted right down tight.
Software.
I had BFMs Serial to USB adapter and the thing was a piece of poop. Glad I got it free. So today I bought this gigawear one to try it out. At least my yellow exclamation mark went away and the drivers appeared to work.
First I tried Romraider. Initial setup was with the proper settings from AEMs site and no luck. Confirmed that I was using the port that my tactrix cable wasn't plugged into, and tested again. Still no luck.
I have tried to use hyperterminal as a standalone to communicate with the gauge. hyperterminal boots up and doesn't spit an error when I go through it, but I've never used this program before so I'm not 100% sure I'm doing it right. Seems pretty easy to do this with though.
I then started really digging, and I came across some AEM progauge program, which I think might be a good program if you wanted to log everything from gauges only, so you could monitor more stuff.
In short. . . I'm stuck. I'm trying to get some logs to my tuner that include AFR in them so I can get off this darn initial base map.
Any help appreciated. I have thick skin so if i'm being a dumb ass tell me!!
Layvon is offline   Reply With Quote
Old 10-08-2012, 08:42 PM   #2
Layvon
Member#: 195711
STi 04/05/06/07
JBP / OBP for now
http://imageshack.us/a/img21/5619/9600q.jpg
I have also tried 19200 to see if that worked and no luck with that either.
Levon
Old 10-09-2012, 10:02 AM   #3
Layvon
Member#: 195711
STi 04/05/06/07
JBP / OBP for now
Bump for some help!
Old 10-09-2012, 01:04 PM   #4
Black94Snake
Member#: 274499
1994 5.8T Cobra
565rwhp @ 10psi
I'd like to see how you connected your wires (blue) and how you have them hooked to the serial cable.
Don't tell me, show me.
Black94Snake is offline   Reply With Quote
Old 10-09-2012, 01:42 PM   #5
Layvon
Member#: 195711
STi 04/05/06/07
JBP / OBP for now
Thank you for the potential help!
However I just stopped at home because my newest serial to USB cable arrived ... I got everything working within 10 seconds. It was purely a software issue with windows 7 communicating to the serialcable.
I will post the 1 that I used very shortly once I get to a computer. I cannot believe how much of a struggle it was just to get windows 7 to communicate with it, this is the first instance I have not like Windows 7.
Oh well no harm no foul I will be data logging tonight after work.
Old 10-09-2012, 02:51 PM   #6
Black94Snake
Member#: 274499
1994 5.8T Cobra
565rwhp @ 10psi
When I ran mine, I used a female(I think) DB9
Old 10-09-2012, 02:52 PM   #7
Black94Snake
Member#: 274499
1994 5.8T Cobra
565rwhp @ 10psi
When I ran mine, I used a female(I think) DB9 connector from radio shack. I used the crimp on/slide in pins. Then used a serial to USB that I bought off Amazon. Grabbed some random drivers I found off Google. I had it all working on the first shot.
But then again... I am using WinXP...
Old 10-10-2012, 08:21 AM   #8
Layvon
Member#: 195711
STi 04/05/06/07
JBP / OBP for now
Yeah, Windows XP is nice because a good portion of the laptops that came with XP from the factory have a serial port on them. My original computer did, and would have made logging a breeze, but my logging computer decided to brick on me saturday, so I had to use my company computer to do it. Not all bad, my xp computer didn't have internet so it was a pain in the butt to work with, and had no battery life, so it was just a bricked ECU waiting to happen.
CABLE THAT WORKS WITH WINDOWS 7CABLE THAT WORKS WITH WINDOWS 7
