Old 10-08-2012, 11:42 PM   #1
Russ Jerome
Member#: 255397
2003 Multiple
Default What ECM pin feeds ground to front O2?
People have posted scans of pinouts but they are expired, simple pin location would help greatly. No ground feed to front o2, heater code with good power feed but weak (6v) ground side (no load, dvm).
Edit, correct answer is:
Connector "D" has pins for front O2 sensor:
Sensor + D19
Sensor - D29
Heater 1/2 is D4 and D5.
Disregard colors as they change between ECM and underhood connector.
Russ Jerome is offline   Reply With Quote
Old 10-09-2012, 09:36 AM   #2
Uncle Scotty
Member#: 16200
OK buy Nates beans
westcoastroasting.com
what code is it throwing????
the CODE....the verbage is irrelevant
and it isnt the ecu....there is a fuse that may be blown....but ya not gonna figure this out without the factory manual....poke and hope anint gonna get it with these things
Old 10-09-2012, 07:54 PM   #3
Russ Jerome
Member#: 255397
2003 Multiple
Front o2 heater code low input, battery voltage to heater is KOEO at 12+ volts, ECM ground apears weak at 6v with DVM at o2 connector at strut tower.
Simply need pinout for heater ground supply from ecm (that apears to be ecm means of monitoring heater function thru amp draw).
Old 10-09-2012, 11:29 PM   #4
Russ Jerome
Member#: 255397
2003 Multiple
Sensor + D19
Sensor - D29
Old 10-10-2012, 12:34 PM   #5
Uncle Scotty
Member#: 16200
OK buy Nates beans
what exactly are you trying to accomplish here???
i THINK you may be pissing in the wind and could accomplish what you need without doing anything that you THINK you need to do or want to do
this is quite common as subarus are DIFFERENT and people who are used to other kinds of cars quite often chase their asses with both hands and never figure it out
and the fix they were chasing was a VERY simple one...IF you know subarus
Old 10-10-2012, 12:35 PM   #6
Uncle Scotty
Member#: 16200
OK buy Nates beans
also....the factory manual is quite easily found...for free...if you look around
Old 10-10-2012, 12:36 PM   #7
Uncle Scotty
Member#: 16200
OK buy Nates beans
and you STILL didnt tell us the CODE....the CODE that it is throwing....you gave the irrelevant verbage
Old 10-11-2012, 05:31 PM   #8
Russ Jerome
Member#: 255397
2003 Multiple
Since nobody has answered the question the code realy doesnt matter does it??? 30yr ASE master tech simply asked if you knew the pinout for the grounding circut of front sensor, I posted the answer if the original question was unclear, thanks for help.
Old 10-11-2012, 10:56 PM   #9
Uncle Scotty
Member#: 16200
OK buy Nates beans
that's bloody marvelous
ive seen lotsa stupid car techs out there....30 years or not
and it is an almost certanty that people who ask these kinds of questions around here are just about to do something stupid to REALLY stupid
but I dont know nuthin......
