Old 10-09-2012, 11:40 AM   #1
nutinbuthehits
Member#: 214758
Default HELP! APS DR525 issue
i bought the fmic used and it didnt come with the turbo outlet >>>> charge pipe silicon connector.... no wonder why it was a good deal
i have searched and searched and searched some more and read up on people with the same issue but no solutions found. ive been looking online for silicon couplers that i could mabye combine together to make work, but i found this....
aftamaf tube from perrin for 08 and up wrx/stis and legacy gt's
anyone have any insight on this??? im hoping that would work as they have the same basic shape, different diameters though
nutinbuthehits is offline   Reply With Quote
Old 10-10-2012, 01:52 PM   #2
07VTRex
Member#: 179023
07 CGM WRX TR
Dom 1.5xtr + PPG's
you nee to take measurements of the pieces you need. inside diameter, length and angle of each bend, also whteher or not its increasing or decreasing in diameter.
then once you know the exact size and shape of the silicone pieces you need go online to www.siliconeintakes.com and order the pieces you need. they make them in any size and shape so you can get exactly what you need. You just have to tell them what exactly it is you need. they will make it. done.
07VTRex is offline   Reply With Quote
Old 10-10-2012, 03:22 PM   #3
nutinbuthehits
Member#: 214758
so what your saying is theyll make a custom silicon coupler? sounds expensive, ill check it out tho
Old 11-15-2012, 11:23 AM   #4
nutinbuthehits
Member#: 214758
all is good! the guy i bought the fmic from FINALLY found the coupler i need, 2 months later lol.
