Old 10-15-2012, 07:53 AM   #1
tcon
Member#: 302431
Default 2006 WRX front brake failure (both sides at same time...)
So just yesterday my front brakes on both sides started sticking and heating up really bad. I took it to a shop and they are telling me the calipers failed, but I don't understand how both could have gone at the exact same time. Is there anything else that could be causing the brakes to stick that the shop might not be picking up on?
2006 WRX
~55k miles
tcon is offline   Reply With Quote
Old 10-15-2012, 08:11 AM   #2
Turn in Concepts
Member#: 93646
Many Track Records
Let us help you go fast!
That would be strange for both to do that at the same time. Plus as you have the 4 piston front brakes it is uncommon for them to "lock up" without extreme track use. Anything is possible though.
Tony
Old 10-15-2012, 08:49 AM   #3
Aaron'z 2.5RS
Member#: 1026
'00 RS/WRX Stg5
'98 RS Stock
Sounds suspect...
I imaging if the slide pins aren't taken care of "maybe" but not likely...
Alas, this is why I do my own work... you can't trust shops 95% of the time...
Not saying it's NOT true, I'm not there... I'm just saying it sounds fishy..
Old 10-15-2012, 09:54 AM   #4
KNS Brakes
NASIOC Storefront Vendor
Member#: 125739
2015 WRB WRX
Need Brakes? 919.420.0021
Originally Posted by Aaron'z 2.5RS View Post
Sounds suspect...
It does not have slide pins.
KNS Brakes is offline   Reply With Quote
Old 10-15-2012, 02:16 PM   #5
bushflyr
Member#: 89628
'02 Wagon VF39'd
& Quick Racked
Could one side dragging have boiled the fluid and transferred pressure to the other side? I know the fronts and rears are on separate circuits, but what level of isolation does the ABS unit provide between sides in front?
bushflyr is offline   Reply With Quote
Old 10-16-2012, 02:30 AM   #6
Uncle Scotty
OK buy Nates beans
westcoastroasting.com
fluid contamination could do this
or the shop is just trying to assrape the poor guy
or maybe somebody ****ed with the OP's brakes
the 4pots are quite well known to be bomb proof even under pretty extreme circumstances....
