Old 10-09-2012, 07:13 PM   #1
OC_Nooby
Member#: 311781
2003 WRX w STI V8
Default Beating A Dead Horse, 03 USDM WRX + 2004 2.5L STI + JDM V7 ECU
I was searching around, got some conflicting information. So I'm making a thread. I think I got the right idea.
I have the following:
2003 WRX USDM (all harnesses WRX)
STI 2.5L (AVCS not running), controlled by the WRX ECU
Can I get a v7 STI ECU and plug it directly to my 03 WRX USDM ECU connector? Then get the IAP AVCS wiring kit and hook it up to its designated location in the ECU connector?
All my sensors will work, no rewiring? I read something about the temp sensor not working (did JDM Subaru's have a separate one other then the one located in the MAF)?
Thanks!
OC_Nooby is offline   Reply With Quote
Old 10-09-2012, 09:03 PM   #2
yellowbus
Member#: 42537
02 wrX
baby blue carbon
Im acutally stuck on the same issue. A friend of
Mines told me that the jdm ecus will plug in and avcs will need to be wired or plug in via the plug in play wirings.
yellowbus is offline   Reply With Quote
Old 10-12-2012, 01:05 PM   #3
OC_Nooby
Member#: 311781
2003 WRX w STI V8
anyone can confirm?
Old 10-12-2012, 02:13 PM   #4
lukeskywrx
Member#: 59837
2004 Spec-C Type RA
What MAF? -Speed Density!
You need JDM cam sensors, JDM cams and you need to add the front cam sensor that sits above the drivers intake cam gear on the 16 bit ecu motors. You will have to machine the heads a bit to get the JDM sensors to sit right and pickup off the JDM cams.
The JDM ecu plugs right in and you just add the AVCS, intake temp sensor will work just fine the ECU uses the one in the MAF. Later models V8-V9 have a sensor in the manifold but it is not used by the stock ECU, most believe it comes into play when the cars are setup for group N rally.
A local guy did this exact swap so I know it can be done, and everything works.
lukeskywrx is offline   Reply With Quote
Old 10-12-2012, 07:57 PM   #5
OC_Nooby
Member#: 311781
2003 WRX w STI V8
There is a difference between the JDM cam sensor and the WRX cam sensor? I have the cam sensor on the STI motor in the same location as it was on the WRX motor. Also why do I need JDM cams? My STI cams are AVCS capable.
Thanks!
Old 10-12-2012, 10:37 PM   #6
lukeskywrx
Member#: 59837
2004 Spec-C Type RA
Thanks!
By cam sensor I am referring to the sensor on the back of each head that reads the rear of the cam for AVCS position. JDM cam sensors are hall effect the USDM ones are optical, Each sensor can only work with its matching cam. The JDM ecu can only use the signal from the hall effect sensors.
So simply put you must match cams, AVCS cam sensors and ECU. In addition you must add the front cam gear sensor, but it sounds like you already took care of that.
Old 10-13-2012, 01:01 AM   #7
OC_Nooby
Member#: 311781
2003 WRX w STI V8
Well my motor has those rear cam sensor. Can I use those? They are the stock ones that came with my sti motor.
Old 10-13-2012, 07:56 PM   #8
lukeskywrx
Member#: 59837
2004 Spec-C Type RA
Not with the JDM ECU, I dont know how I can make this more clear. The JDM ECU cannot read the USDM sensors and vice versa. The JDM sensors cannot pickup the USDM cams and vise versa.
JDM ECU + JDM Cams + JDM AVCS Sensors = Working AVCS
USDM ECU + USDM Cams + USDM AVCS Sensors = Working AVCS
JDM ECU + USDM Cams + USDM AVCS Sensors = NO AVCS
USDM ECU + JDM Cams + JDM AVCS Sensors = NO AVCS
JDM AVCS sensors ≠ USDM AVCS Sensors
JDM Cams ≠ USDM Cams
Old 10-13-2012, 08:01 PM   #9
OC_Nooby
Member#: 311781
2003 WRX w STI V8
ok that's clear, and slightly shattered my dreams.
Old 10-13-2012, 10:52 PM   #10
lukeskywrx
Member#: 59837
2004 Spec-C Type RA
Get a set of JDM cams with sensors and you are in business
Old 10-14-2012, 12:21 AM   #11
OC_Nooby
Member#: 311781
2003 WRX w STI V8
Eventually, thanks for clearing it up!
