Go Back   NASIOC > NASIOC Classifieds > Vendor Storefront Forums > Perrin Performance
Old 10-09-2012, 06:17 PM   #1
PERRIN
NASIOC Manufacturer
Vendor Sales Rating: (10)
Member#: 6776
Default NEW > Down Pipe Blanket By PERRIN
Introducing the NEW Down Pipe Blanket By PERRIN
MSRP $149.99
Available Now!
PERFORMANCE
PERRIN Thermal Blankets will improve response while lowering under hood temperatures. Thermal losses from headers, uppipes, turbine housings, and downpipes, cool exhaust temperatures thus the exhaust loses energy and velocity. This cooling effect reduces turbo response and horsepower. PERRIN Thermal Blankets insulate the exhaust from losing that critical heat, which in turn maintains the velocity of the exhaust gases. Improve power and protect vital under hood components from heat damage with this easy-to-install and economical part from PERRIN!
DESIGN
PERRIN Downpipe thermal blanket fits snugly around the downpipe to keep nearly all radiant heat away from your intercooler, intake and other engine components. The downpipe blanket features 3-layer construction. Including an outer cover made from Silicone Impregnated Fiberglass (rated to 500F continuous), an inner layer made of Calcium Magnesium Silicate Insulation (rated to 2000F continuous) and Silica (rated to 1800F Continuous) insulation used to contain the inner layer.
INSTALLATION
Stainless steel rivets are mounted to the blanket and stainless steel wire is supplied to secure the blanket to your downpipe. This allows for simple “Lace Up” type installation, even with the downpipe already installed!
FITMENT
The shape of the PERRIN downpipe thermal blanket is specifically designed to fit over all stock Subaru downpipes, PERRIN downpipes and most aftermarket downpipes. The PERRIN downpipe thermal blanket works great with the PERRIN Heat Shield for the ultimate in heat control.
5 YEAR WARRANTY
PERRIN Performance warrants to the original purchaser, all PERRIN products to be free from defects in material and workmanship within a sixty (60) months period from the date of purchase.
Click HERE to check this out on our web site.
Wholesale clients please contact your PERRIN sales rep for more information.
PERRIN is offline   Reply With Quote
Old 10-09-2012, 10:10 PM   #2
25rsti
Member Sales Rating: (82)
Member#: 166324
02 V8 Spec C 03
V9 Limited 2013 Legacy
Will it fit you rotated downpipe without modifications.
Old 10-10-2012, 11:38 AM   #3
PERRIN
NASIOC Manufacturer
Member#: 6776
Yes it does.
Old 10-12-2012, 01:11 PM   #4
Ballocks
Member Sales Rating: (1)
Member#: 281928
2008 WRX hatch
obp
Edit: sorry ill ask in a different form. Would it be advisable or necessary to keep a closer eye on exhaust temps when using products such as up-pipe, turbo, and downpipe heat blankets?
Ballocks is offline   Reply With Quote
Old 10-19-2012, 08:27 PM   #5
HeroCrank
Member Sales Rating: (15)
Member#: 301089
2011 WRX 5 door
TP stage 2
how much will this downpipe blanket reduce downpipe and the surrounding engine bay temps?
HeroCrank is offline   Reply With Quote
Old 10-22-2012, 04:05 PM   #6
PERRIN_Chris
Vendor Sales Rating: (0)
Member#: 186665
2006 STi
Crystal Grey Metallic
Hello, no there isn't any more attention needed to be made to exhaust temp when our blankets are installed. Heat will be retained in the pipes, but it's not enough that it is going to cause any damage.
We haven't done any testing yes on the downpipe, for the turbo blanket, we've seen a reduction from 900F down to 300F on the surface of the turbo! The downpipe won't be as much, since the downpipe doesn't get as hot, but will make a good reduction in underhood temps!
PERRIN_Chris is offline   Reply With Quote
Old 01-22-2013, 05:12 PM   #7
DukeNeverwinter
Member#: 342363
I have a Perrin Downpipe with a Cat. Will this blanket capture too much heat and overcook the cat? Outback XT 5mt 08
DukeNeverwinter is offline   Reply With Quote
Old 01-22-2013, 06:25 PM   #8
PERRIN_Mladen
Member#: 339582
2006 EVO IX MR
Wicked White
The cats are rated to a temp that exceeds the EGT's seen at the catalytic converter. Adding the blanket does hold in more heat, but not enough that it causes any issues. We had this tested on a car with our downpipe for a long time and with dynoing and other abuse the cat was perfectly fine.
PERRIN_Mladen is offline   Reply With Quote
Old 02-01-2013, 12:08 PM   #9
castle1977
Member#: 332244
2003 wrx wagon
black
will this fit ok on a cobb downpipe?
castle1977 is offline   Reply With Quote
Old 02-01-2013, 12:16 PM   #10
PERRIN_Chris
Member#: 186665
2006 STi
Yes it'll work fine with the COBB downpipe, thanks!
Old 02-01-2013, 12:49 PM   #11
Ballistic1350
Member Sales Rating: (12)
Member#: 156877
04 sti
How much does it weigh?
Ballistic1350 is offline   Reply With Quote
Old 02-01-2013, 12:52 PM   #12
PERRIN_Chris
Member#: 186665
2006 STi
Shipping weight is 3 lbs, so maybe 2?
Old 02-01-2013, 01:12 PM   #13
Ballistic1350
Member#: 156877
04 sti
that's not bad at all; any plan for a header blanket?
Old 02-01-2013, 01:21 PM   #14
WhatTurboLag?
Member Sales Rating: (2)
Member#: 243992
2006 WRX TR
Any provosions for a 02 sensor in the bellmouth for twin scroll guys or ppl witj widebands
WhatTurboLag? is offline   Reply With Quote
Old 02-05-2013, 10:36 AM   #15
WhatTurboLag?
Member#: 243992
2006 WRX TR
also, a flap covering that hot metal flange would be an awesome addition. will get rid of my ugly rats nest of header wrap around it.
Old 02-05-2013, 06:07 PM   #16
PERRIN_Chris
Member#: 186665
2006 STi
We might, we were working on one at one point.
It doesn't have that, sorry! It might be something that we can add in the future, but we don't have any plans for it right now.
Old 02-05-2013, 06:10 PM   #17
meat_WRX
Member Sales Rating: (20)
Member#: 96919
2004 sti
black
i was wondering when someone was going to come out with this.
meat_WRX is offline   Reply With Quote
Old 03-08-2013, 12:11 AM   #18
Excision
Member#: 294622
2007 STI
was there something wrong with this design or something?
Excision is online now   Reply With Quote
Old 03-08-2013, 11:14 AM   #19
PERRIN_Chris
Member#: 186665
2006 STi
Nope, nothing wrong with it, just a prototype.
Old 03-24-2013, 10:42 PM   #20
2.5sbd
Member Sales Rating: (4)
Member#: 124818
2011 WRX
black
Stock Turbo & Invidia DP
I just installed the Turbo & DP Blanket today & it went very easy. Total time was like an hour. Although I did already have the heat shield off because of the Invidia DP install.
One note on the install:
It makes it easier to loose fit the blankets and then go back and snug up the wire.
This pair makes a huge difference in TMIC heat soak & also the front axel boot which is right next to the DP cat.
The fitment of the DP blanket was a little small around the DP cat and left about 1/4 inch of bare pipe in that area. Other than that I like the product.
The combination of these two blankets leads me to belive that I wont need to buy a turbo heat shield since the TMIC was cool to the touch on all surfaces.
2.5sbd is offline   Reply With Quote
Old 04-08-2013, 08:32 PM   #21
GregOrz
Member#: 339148
2011 WRX Sedan
Can anyone comment on noise insulation with the DP blanket. It seems like this blanket is insulated thick enough to not only trap heat, but also to perhaps reduce the noise coming from a down pipe.
GregOrz is offline   Reply With Quote
Old 04-09-2013, 04:30 PM   #22
PERRIN_Chris
Member#: 186665
2006 STi
The blanket will give a little noise reduction, but nothing super noticeable, since most of the sound will come from the engine and turbo. Thanks!
Old 04-26-2013, 10:36 AM   #23
SNE2040
Member Sales Rating: (7)
Member#: 72195
2012 WRX GV
Any plans on releasing the header blanket?
SNE2040 is online now   Reply With Quote
Old 04-26-2013, 10:39 AM   #24
besthaticouldo
Member Sales Rating: (5)
Member#: 279660
LOL Celery sits
down to pee
quick question on your downpipe blanket....how will it do with a EWG on it? will it burn away?
besthaticouldo is online now   Reply With Quote
Old 04-26-2013, 12:40 PM   #25
PERRIN_Chris
Member#: 186665
2006 STi
That is something that we've been thinking about. The only thing is that it would be pretty expensive.
I'm not sure if you're asking if it's made with a cutout for a EWG return, or if an EWG was blowing right on it.
It's not designed with a hole for a EWG return, but it should still be able to work.
I wouldn't recommend having a EWG blowing right on it. It will damage it over time.
Message Board Statistics All times are GMT -4. The time now is 11:49 AM.
