Go Back   NASIOC > NASIOC Classifieds > Private 'For Sale' Classifieds > Suspension/Brakes/Handling
Old 10-09-2012, 09:09 PM   #1
dsc_morpheus
Member Sales Rating: (2)
Member#: 201503
2016 STi
Dark Grey Metallic
Thumbs up 08+ 2.5i/WRX front donors for Koni inserts
on hold since it really looks like the 11+WRX shares the same front struts as the previous models even with the STi wide body...
dsc_morpheus is offline   Reply With Quote
Old 10-09-2012, 09:55 PM   #2
aod12
Member Sales Rating: (22)
Member#: 282701
2008 FXT
Just a small suggestion. The front struts from the sti will not work on your wrx stock.
aod12 is offline   Reply With Quote
Old 10-10-2012, 07:35 AM   #3
dsc_morpheus
Member#: 201503
2016 STi
Dark Grey Metallic
would you care to explain?
I now own a '12 WRX with the same wide body as the STi so the stut base as the same "width". Which is the reason I had to find new donors at the first place since there's about a 3/4" difference between the 2.5i/base-WRX and the WRX/STi strut construction.
The only thing I can think about would be that the knuckle flag is beefier and/or the 2 holes are not configured at the same location, but I strongly doubt that! The only real suspension difference between a 11+ WRX and a 08+ STi is the inverted front shock, which I already stripped apart (see my other FS thread here) because the only thing I need is the Macperson body itself...
Old 10-10-2012, 11:25 AM   #4
aod12
Member#: 282701
2008 FXT
This. Unless you plan to drill to realign the holes they won't fit up. The only part that's interchangeable is the rear setup.
Old 10-21-2012, 08:44 AM   #5
dsc_morpheus
Member#: 201503
2016 STi
Dark Grey Metallic
Price drop... 100$ OBO
Get the best street/track setup for any spirited drivers that is looking for a better suspension component than any knockoff coilover available in the market...
More details about the Sport (aka "Yellow") inserts on Koni's website:
http://www.koni-na.com/cat_search.cfm?mt_id=1&my_year=2008&mak_id=40&mod_ id=424&...
Old 12-29-2012, 09:28 AM   #6
dsc_morpheus
Member#: 201503
2016 STi
Dark Grey Metallic
Old 12-29-2012, 11:58 AM   #7
gsrcrxsi
Member Sales Rating: (8)
Member#: 236952
2010 WRX (SSM)
Stg "2+" 300hp/360trq
The STI struts won't fit your car.
The width of the strut attachment on the knuckle is wider on the STI than the WRX, even on the new 11-13 WRXs. The strut hole spacing is also different.
For the Konis on your car you need to use WRX or 2.5i struts. You might as well keep what you have. You'll get more camber using the 2.5i/08-10 WRX struts anyway.
gsrcrxsi is offline   Reply With Quote
Old 02-18-2013, 11:59 PM   #8
dsc_morpheus
Member#: 201503
2016 STi
Dark Grey Metallic
on hold since it really looks like the 11+WRX shares the same front struts as the previous model even with the STi wide body...
