Welcome to the North American Subaru Impreza Owners Club Tuesday May 31, 2016
Old 10-09-2012, 03:57 PM   #1
patrickrobare
Member#: 324177
2012 impreza WRX
pearl blue
Default How do my Datalogs look?
Code:
Time	A/F Learning 1 (%)	Boost Target (PSI)	Boost (PSI)	Dyn. Adv. Mult (DAM)	Dynamic Adv. ()	Feedback Knock ()	Fine Knock Learn ()	Ignition Timing ()	Knock Active Sw. (on/off)	MAF Volt. (V)	MAF (g/s)	RPM (RPM)	TD Boost Error (PSI)	Throttle Pos. (%)	Wastegate Duty (%)
0	3.91	1.26	-6.95	1	0.52	0	0	34	Off	2.4	32.69	2632	11.8	21.18	60.39
0.32	3.91	19.49	0.03	1	4.85	0	0	21	Off	2.9	60.76	2696	19.4	100	70.98
0.64	3.12	19.49	1.97	1	5.55	0	0	20	Off	3.1	72.31	2774	17.29	100	70.98
0.96	2.34	19.49	4.55	1	6.11	0	0	19.5	Off	3.3	89.01	2892	14.57	100	70.98
1.28	2.34	19.49	7.79	1	6.39	0	0	16.5	Off	3.44	113.19	3018	11.36	100	70.98
1.6	2.34	19.49	11.6	1	6.18	0	0	15.5	Off	3.72	138.61	3147	7.72	100	70.98
1.92	0	19.49	15.41	1	5.98	0	0	14	Off	3.92	161.79	3318	3.84	100	70.98
2.24	0	19.49	16.94	1	5.98	0	0	14	Off	3.96	177.19	3515	2.61	100	70.98
2.56	0	19.49	17.01	1	5.98	0	0	14.5	Off	4.04	183.05	3710	2.69	100	70.98
2.88	0	19.49	17	1	5.98	0	0	15	Off	4.08	186.82	3876	2.76	100	70.98
3.2	0	19.49	16.51	1	5.98	0	0	16	Off	4.12	196.39	4061	3.06	100	70.59
3.52	0	19.45	16.25	1	5.98	0	0	15.5	Off	4.18	205.44	4245	3.44	100	69.02
3.84	0	19.43	15.72	1	5.98	0	0	15.5	Off	4.24	214.5	4417	3.87	100	67.84
4.16	0	19.39	15.46	1	5.98	0	0	16.5	Off	4.26	219.5	4558	4.17	100	66.67
4.48	0	19.39	14.92	1	5.98	0	0	17	Off	4.3	224.92	4733	4.51	100	65.49
4.8	0	19.09	14.47	1	5.98	0	0	17.5	Off	4.3	226.69	4925	4.56	100	62.75
5.12	0	18.68	13.87	1	5.96	0	0	18	Off	4.3	223.25	5054	4.79	100	59.22
5.44	0	18.2	13.1	1	5.98	0	0	18.5	Off	4.28	224.08	5243	4.79	100	56.86
5.76	0	17.23	12.47	1	5.89	0	0	18.5	Off	4.3	226.22	5369	4.36	100	56.86
6.08	0	16.18	12.07	1	5.68	0	0	18.5	Off	4.32	227.08	5476	3.76	100	56.86
6.4	0	14.99	12.12	1	5.63	0	0	18.5	Off	4.32	232.86	5633	2.95	100	56.86
6.72	0	14.68	11.86	1	5.38	0	0	19	Off	4.38	238.64	5743	2.92	100	56.86
7.04	0	14.41	11.78	1	5.27	0	0	19	Off	4.38	241.75	5892	2.66	100	56.86
7.36	0	14.19	11.74	1	5.15	0	0	19	Off	4.38	241.3	5956	2.56	100	56.86
7.68	0	14.02	11.57	1	5.01	0	0	19.5	Off	4.38	242.19	6086	2.5	100	56.86
8	0	13.88	11.4	1	4.93	0	0	20	Off	4.42	247.55	6186	2.58	100	56.86
8.32	0	13.83	11.35	1	4.92	0	0	21	Off	4.42	247.1	6288	2.49	100	56.86
8.64	0	13.73	11.37	1	4.92	0	0	21.5	Off	4.42	248.48	6396	2.52	100	56.86
8.96	0	13.71	11.3	1	4.92	0	0	22.5	Off	4.4	250.35	6502	2.49	100	56.86
9.28	0	13.71	11.31	1	4.92	0	0	23.5	Off	4.44	251.29	6600	2.51	100	56.86
9.6	0	13.71	11.36	1	4.92	0	0	24	Off	4.44	251.76	6741	2.49	100	56.86
9.92	0	13.71	11.4	1	4.92	0	0	25.5	Off	4.44	252.23	6837	2.43	100	56.86
patrickrobare is offline   Reply With Quote
Old 10-09-2012, 04:01 PM   #2
subiebosch
Member#: 155548
2015 2500 Dmax
2011 WRX TP STG2 COBB DP
What map are you running? Can you post the logs on google docs? and don't forget to make them public.
subiebosch is offline   Reply With Quote
Old 10-09-2012, 04:01 PM   #3
Andrewxxcarlson
Member#: 316415
2006 WRX
Try again.
Andrewxxcarlson is offline   Reply With Quote
Old 10-09-2012, 04:07 PM   #4
patrickrobare
Member#: 324177
2012 impreza WRX
pearl blue
Old 10-09-2012, 04:23 PM   #5
patrickrobare
Member#: 324177
2012 impreza WRX
pearl blue
Old 10-10-2012, 08:39 AM   #6
Cobb Tuning
Member#: 4803
Originally Posted by patrickrobare View Post
Logs look fine, except that you are underboosting. I assume this is a 2012 WRX based on your profile? What mods do you have? What exact map are you running?
Bill
Old 10-10-2012, 09:50 AM   #7
patrickrobare
Member#: 324177
2012 impreza WRX
pearl blue
I only have a short throw and its a custom map i designed.
Old 10-10-2012, 01:19 PM   #8
Cobb Tuning
Member#: 4803
For a stage 1 car, your boost targets are a bit high. Log looks fine at current boost level, but I would go stage 2 (i.e. turbo-back exhaust) before attempting to hit the boost targets you've designated in your custom map.
Bill
Old 10-10-2012, 01:56 PM   #9
patrickrobare
Member#: 324177
2012 impreza WRX
pearl blue
Bill
So is there too much pressure and thats why im not hitting target boost?
Old 10-10-2012, 02:49 PM   #10
Cobb Tuning
Member#: 4803
You'll require higher wgdc to achieve peak boost at stage 1 vs. stage 2, but, regardless, you need to free up the exhaust (i.e. stage 2) before you attempt to run those boost levels. If you wish to stick with stage 1, then you'll need lower boost targets. For example, our 93 octane map targets a peak of 16.5 psi for this car at stage 1 (and even lower for 91 and 91 ACN maps).
Bill
