Welcome to the North American Subaru Impreza Owners Club Monday August 31, 2015
Old 10-09-2012, 10:24 PM   #1
GiRaff3
Member#: 330747
2013 Crosstrek
Orange
Default 05 WRX only hitting 10psi
Hello all. Bought my WRX a few weeks ago. 103k miles, manual, only mod at the time was a Greddy Evo catback. Car felt fine, seemed to boost smooth. Last week, I bought a Cobb AP, tuned it to stage 1, drove around and was happy with the performance boost. Car felt much better. Gas mileage has been pretty bad since, dropping from ~27mpg mixed, down to around 22mpg mixed, and I have not been driving with a lead foot. I installed a boost gauge a few days after the tune and noticed the gauge was only reading 10psi. The car hits 10psi like a brick wall, I have only seen it go above 10 psi once, and it hit MAYBE 12 psi. I hooked up the AP and it sees 10 psi as well...
Where are the common spots to check in hopes of resolving this problem? I have owned several turbo cars (all Volvo before this one) and I was thinking wastegate actuator? I am still learning the ins and outs of the WRX.
Thanks in advance!
GiRaff3 is offline   Reply With Quote
Old 10-10-2012, 02:20 AM   #2
Awais
Member#: 295663
2004 V7 STI swap WRX
on a stage 1 flash the target boost is 12 pounds on the ACN 91 map, and 14.5 +or-1psi. whats the exact map flash you have? also things to check are
-vacuum lines around the boost controller \ waste gate
-make sure restrictor pill is present
-test the boost solenoid make sure its functional
also are running the stock wrx top mount? i had a similar issue with the stock coupler, it had a tiny crack in it.
Awais is offline   Reply With Quote
Old 10-10-2012, 02:27 AM   #3
SlverEJ20
Member#: 157158
05 WRX stage 2
^^ check those things first and get back to us.
SlverEJ20 is offline   Reply With Quote
Old 10-10-2012, 11:29 AM   #4
GiRaff3
Member#: 330747
2013 Crosstrek
Orange
I am using the stage 1 93guy octane map.
I am not familiar with the restrictor pill, sounds kind of like headlight fluid, LoL.
I am currently away at training with limited time to check things. I want to formulate a strong plan of attack and execute it as soon as i get home.
Thanks for the replies, I will report back.
Old 10-10-2012, 02:49 PM   #5
art@grimmspeed
Member#: 301037
2004 Forester XT
Read through this and it will explain alot and also give you places to check.
http://www.cobbtuning.com/Technical-...es-s/70674.htm
art@grimmspeed is offline   Reply With Quote
Old 10-10-2012, 04:29 PM   #6
Awais
Member#: 295663
you should be boosting around 14.5 give or take 1 psi. thats a great link i was just gonna post it up you can feel for this "pill"
it should be there if you haven't changed the lines around at all.
whats your DAM (Dynamic Advanced Multiplier) at also? i hear a low DAM on the Acessport the car goes into "failsafe"
to check that go monitor > scroll down > Dynamic Adv. Mul. i think thats what they use and tell us the number that shows up!
if thats not the case then we will have to do a quick data log and take a look into your boosting characteristics. but this will be later.
on a side note the waste gate opens up at 8psi... so the solenoids somewhat working
start small, keep us posted
Old 10-10-2012, 05:06 PM   #7
WRXSD
Member#: 136539
2005 WRX Wagon
CGM Stg. 2
You say you installed a boost gauge. Why don't you watch your boost levels on the AP and compare? It will give you current psi, and max and min down below it while you are displaying it. Also, do a third gear pull and check boost. I don't think the AP tunes hit max boost in 1st and 2nd.
WRXSD is offline   Reply With Quote
Old 10-10-2012, 05:28 PM   #8
trex93
Member#: 333368
Check for leaks as well.
trex93 is offline   Reply With Quote
