Old 07-11-2013, 11:06 PM   #1
revolutionz
Member#: 362074
2007 WRX
Default 2007 Wrx hose question
So I was inspecting my engine bay today, since I was going to wash the engine bay the next day and noticed a hose being crimped by my bypass valve hose, sorry if that doesn't makes sense, I took a picture to try and clarify my problem.
Anyways I've been trying to figure out why I have a bad idle (going from running to a full stop the rpms would jump around for a bit then stop) or (creeping in first during traffic), (going reverse having the wheel turned all the way one direction) situations like those would set off the jumpy rpm.
I was wondering if this could be a potential culprit and if it was how would I fix this problem?
Last edited by revolutionz; 07-11-2013 at 11:11 PM. Reason: Fixing the pictures that weren't showing
revolutionz is offline   Reply With Quote
Old 07-11-2013, 11:25 PM   #2
Leafy
Member#: 330625
2006 WRX
That looks like the throttle body coolant heating hose. I have not studied the subaru cooling diagram enough to know if that causes any real issue.
Old 07-12-2013, 12:20 AM   #3
04ScoobyWtf
Member#: 287974
That's not your problem
04ScoobyWtf is offline   Reply With Quote
Old 07-12-2013, 02:47 AM   #4
revolutionz
Member#: 362074
2007 WRX
Ok so I looked up a few things about the coolant line going to the TB and people say its only for preventative measure during winter seasons where there is a chance your TB can freeze. Answers my question, but I find it strange. I drove to work an hour ago and it was pretty cold (51*F) and I didn't have any idle issues, but when I was running a few days ago, when it was around (75*F ish) it was showing the same symptoms. Any ideas? Also I don't know if this will help, but my idle during hot temps is under the 3 last line on the tach.
Old 07-12-2013, 04:01 PM   #5
alexandern05
Member#: 266954
04 wrx v7 sti swap
agile tuned 389hp 342ftlb
That's definetly the coolant line for heating the throttle body I have mine bypassing the throttle body with no issues
alexandern05 is offline   Reply With Quote
Old 07-12-2013, 04:06 PM   #6
alexandern05
Member#: 266954
04 wrx v7 sti swap
If your still having jumpy idle maybe PCv valve is broken my buddy's 04 sti had a bad pcv valve and cracked hose and I replaced it now idles fine
