Old 11-09-2012, 10:02 PM   #1
8R0G4N
Member#: 304436
2007 wrx
Default bottom coolant hose on turbo swap help!!
I'm having trouble getting the bottom hose on the new Turbo onto to coolant drain.. does anybody have any tips to get it on?
8R0G4N is offline   Reply With Quote
Old 11-09-2012, 10:03 PM   #2
8R0G4N
Member#: 304436
2007 wrx
Correction the oil hose..
Old 11-10-2012, 11:55 AM   #3
jrodm12
Member#: 296705
05 STI
I put the hose on the turbo first just barley and then slid it on the nipple on the motor side. Its the biggest pita on a turbo swap just keep at it sooner or later it will go on. Did you put a new piece on there they get brittle really easy over time and cause leaks.
jrodm12 is offline   Reply With Quote
Old 11-11-2012, 09:33 AM   #4
Mr. AWDriver
Member#: 176505
07 SWP STI
I remember that hose, took me 15-20 mins to work it back on. Just requires your patience
Mr. AWDriver is offline   Reply With Quote
Old 11-11-2012, 10:28 AM   #5
BlackFighter
Member#: 193940
2004 WRX STI Black
RalliSpec Shortblock
i got lucky. Mine went on with a first try.
Old 11-11-2012, 10:45 AM   #6
Black94Snake
Member#: 274499
1994 5.8T Cobra
565rwhp @ 10psi
When I swapped my VF in, I just coated the drain nipple with oil and pressed it straight into place.
Old 11-11-2012, 09:01 PM   #7
batteryman
Member#: 209986
2006 WRX Wagon
Defiantly replace it. if you go to a trusted shop they should be able to provide you with a stiffer high quality hose that's easier to get on.
I have done 2 swaps on mine, both times I attached the hose with clamps on the turbo then slid the turbo into place. It helps if you have somebody down below to help guide you and the hose.
batteryman is offline   Reply With Quote
Old 11-12-2012, 06:25 AM   #8
FCmaniac
Member#: 142029
2013 Forester
2008 350z, 1991 Miata BRG
This works for me every time.
FCmaniac is offline   Reply With Quote
