Old 10-10-2012, 05:35 PM   #1
fullCircling
Member#: 290547
Default What heads for 2.5 high compression street build? Anyone make NA dual AVCS cams?
First of all, does anyone make any dual avcs cams that would be good for an NA application? How about single AVCS?
I threw a rod in my stock ej25d (97 legacy gt), so I picked up a 257 block that needs pistons. I'm gonna put in a set of high compression CP pistons, but I still don't know what heads I wanna use. I still have the stock ej25d heads in the car that I hear aren't too bad, flow wise...
...but... I'm gonna convert the car to use dual AVCS at some point. Right now I'm prob just gonna go high compression NA while I get parts together for a turbo setup.
Soo, if you could point in the right direction as far as heads/cams, and manifolds I'd appreciate it.
fullCircling is offline   Reply With Quote
Old 10-10-2012, 05:36 PM   #2
fullCircling
Member#: 290547
Can I go 100mm bore on a 257 and still have room for another bore later on?
Old 10-10-2012, 05:37 PM   #3
dangerousatom
Member#: 70710
2002 04STi Swaped RS
w/PPGS & 02 Wagon w/PPGs
07^ 2.5i head are AVCS and flow better then WRX or STi
dangerousatom is offline   Reply With Quote
Old 10-10-2012, 06:20 PM   #4
Counterfit
Member#: 124254
2006 06 SGM Slowbaru
"The Scoobinator"
No, 06+ are AVLS heads. AVLS and AVCS are different.
Counterfit is offline   Reply With Quote
Old 10-10-2012, 07:13 PM   #5
fullCircling
Member#: 290547
o.0 ...really?
so even if i swap out the pistons and go turbo later on, which i definitely will, will converting to AVLS still be better (as far as power/driveability/cam options go) than converting to dual AVCS?
lol are there even any aftermarket cam options for them?
Old 10-10-2012, 07:23 PM   #6
fullCircling
Member#: 290547
waitwaitwait this: (AVLS)...?
(controls valve lift, pretty much like hondas vtec)
http://drive2.subaru.com/Spring07_whatmakes.htm
flows better than this?
(controls cam timing, pretty much like i-vtec without the variable valve lift... right?)
http://drive2.subaru.com/Win05_WhatsInside.htm
Old 10-10-2012, 07:33 PM   #7
Counterfit
Member#: 124254
"The Scoobinator"
I'm not making any claims as to what flows better.
Yup. Delta has them available. AVLS has only been in the US for 6 years...
Old 10-10-2012, 08:28 PM   #8
fullCircling
Member#: 290547
cool, ill give them a call and see what they say
Old 10-14-2012, 02:49 PM   #9
JRVmotorsports
Member#: 335076
Default Sorry to hitch hike your thread , But I need help
Just joined the site , and they won't let me start a thread until I have posted on other threads first . Sorry again !!
I race a class 5 Unlimited desert car with tons of race wins and 5 total championships , We run an unlimited displacement VW style type four engine modified to the moon , starts out as a 2.0 ltr and now is well over 3.0 liter and makes close to 350 hp with a motec 800 engine managment system , This is a $36,000.00 engine package that must be gone thru every race. Due to this situation there have been some recent changes to our class rules
I can now build a Subaru naturally aspirated engine package at 2.5 ltr. max and maybe get a few thousand miles before a rebuild instead of one race . So this is where you guys come in . There are tons of Turbo race engine builders out there , but as soon as I start talking about pistons , camshaft profile , ect. they start to get crazy . I need help to figure out what 2.5 model will be the best to build aspirated . and if you guys can help me find a engine builder that has experince Subaru N/A race engines it would be way appreciated
JRVmotorsports is offline   Reply With Quote
Old 10-14-2012, 03:04 PM   #10
chazly413
Member#: 151079
2005 2.5RS RBP
too many friction losses
^ Lawl, that doesn't mean you threadjack. You should post in some useless threads in OT and then you can make a real thread.
chazly413 is offline   Reply With Quote
Old 10-14-2012, 03:18 PM   #11
JRVmotorsports
Member#: 335076
No offense intended
Old 10-15-2012, 01:16 AM   #12
dangerousatom
Member#: 70710
Old 10-15-2012, 02:53 PM   #13
Patrick Olsen
Member#: 120
1997 Legacy 2.5GT
QuickSilver Metallic
lol AVCS offers advantages for turbo spool. lol
lol
You are correct that AVLS alters lift while AVCS alters timing.
And the method of cam actuation has nothing to do with the flow capability of the heads. I have no idea which heads flow better (STI vs WRX vs EJ25D vs EJ251 vs whatever) - go do some digging in the Built Motor Discussion forum to find that sort of info. Really, this whole thread belongs in that forum.
Pat Olsen
