Old 10-10-2012, 06:18 PM   #1
ncbmx64
Member#: 334480
Default Can you check out my data logs
Just got my AP today and a noob to subaru mods and did a couple short pulls in 3rd gear and would like some feedback on how it looks I am running the cobb ots Stage 1 93oct map on a 2012 STI should I use the HWG map looks like boost is not making the 18psi target and does everything else looks ok?
https://docs.google.com/spreadsheet/...fN0FWVXc#gid=0
https://docs.google.com/spreadsheet/...DZ0RVSWc#gid=0
https://docs.google.com/spreadsheet/...fSkp4eVE#gid=0
ncbmx64 is offline   Reply With Quote
Old 10-10-2012, 08:25 PM   #2
ncbmx64
Member#: 334480
Old 10-10-2012, 09:04 PM   #3
hutch959
Member#: 267463
make logs public. cant see them
hutch959 is offline   Reply With Quote
Old 10-10-2012, 09:08 PM   #4
ncbmx64
Member#: 334480
Sorry should be fixed
Old 10-10-2012, 09:09 PM   #5
BarTmaN
Member#: 235650
2011 WRX
I think with a 6 speed you're generally supposed to log a pull in 4th
BarTmaN is offline   Reply With Quote
Old 10-10-2012, 09:36 PM   #6
mikeydrives1
Member#: 262117
2001 Forester
STi II type M
What were the ambient temps when doing these pulls?
Hot, humid air generally works against our subarus, especially the top mount. Looking breifly at your logs everything seems OK from what i understand. I dont notice any wild swings or fluctuations on any parameter and the boost seems relatively consistent.
Please understand that off the shelf maps, while they do much good in regards to setting an industry standard for plug-and-play upgrades for our cars, do not cater 100% specific to your car. While the engine setups are all uniform and the testing is done very thoroughly by COBB, you may or may not live and drive that car in an environment different than where the research dyno was. Different local temps, humidity and elevations play crucial factors as to how the car reacts. This is easily overcome by a road or dynotune by your local proffesional.
Just my two cents.
-Mikey
mikeydrives1 is offline   Reply With Quote
Old 10-10-2012, 09:42 PM   #7
ncbmx64
Member#: 334480
The last two the temp was around 63 with around 80% humidity. The first ones I posted it was in the low 70's with around the same humidity. Yeah I knew a protund would be the best for my car just wanted to make sure everything looked good and didn't know if the boost was low since the map said the target was 18 psi not sure if its lower since I did a 3 rd gear pull didn't have a safe area to do the 4 th gear pull so just did a 3rd
Old 10-10-2012, 10:07 PM   #8
mikeydrives1
Member#: 262117
2001 Forester
STi II type M
In my experiences and learnings, ive found that relative humidty plays a large role (on top mounts at least) on how effectively the turbo reachs and holds target boost.
Old 10-11-2012, 08:58 AM   #9
Cobb Tuning
NASIOC Manufacturer
Member#: 4803
It looks like some of these runs are in intelligent mode. Want you want to do is a 4th gear run in Sport Sharp from 2500 RPM on up, if you can do so safely. 3rd gear is fine if that is safer for you.
Bill
Old 10-11-2012, 09:07 AM   #10
ncbmx64
Member#: 334480
Bill
all those runs are in sport sharp mode in 3rd gear should I be running a different map? I am using the newest stage 1 93 oct map
Old 10-11-2012, 09:17 AM   #11
Cobb Tuning
NASIOC Manufacturer
Member#: 4803
No, that map is fine. In the AccessPORT, go to "Tune" -> "Show Current Map" and report back the exact map name that is shown in the "reflash" slot and the map name that is in the "realtime" slot.
Bill
Old 10-11-2012, 09:48 AM   #12
ncbmx64
Member#: 334480
Reflash - Stage 1 93 v310 boost select
Realtime- Stage 1 93 v310 boost select
Old 10-12-2012, 08:28 AM   #13
Cobb Tuning
NASIOC Manufacturer
Member#: 4803
Your maps are correct. The odd thing was a few of your logs showed a really low boost target at WOT (ex. the very first one you posted). Other than extreme altitude, the most likely scenario would be intelligent mode with the boost select maps. But, let's get a few more logs. Try a 4th gear run in Sport Sharp from 2500 RPM on up, if you can do so safely (3rd gear is fine if that is safer).
Bill
Old 10-12-2012, 07:40 PM   #14
ncbmx64
Member#: 334480
i did another log it was a 3rd gear pull
https://docs.google.com/spreadsheet/...4bjJSMWc#gid=0
Old 10-13-2012, 08:53 AM   #15
Cobb Tuning
NASIOC Manufacturer
Member#: 4803
Log looks good. You'll likely see higher peak boost with higher gears and since you are within 1 psi of your peak boost target in 3rd, you are good to go and should not use the HWG map.
Bill
Message Board Statistics All times are GMT -4. The time now is 11:19 AM.
