Old 10-10-2012, 10:05 PM   #1
Uruchima
Member#: 322246
2013 WRX Sedan
Question Next Tune Process: Stage 2
Hey guys,
I have a 2009 Impreza 2.5i with a Cosmo Racing CAI and a OBX catback and a Stage 1 Opensource tune by Phattbotti Tuning (STiMikey).
I was wondering what would be the next step to get a bit more HP/TQ?
A high-flow Fuel Pump with High-flow injectors (like the ones from the AVO turbo kit for 2.5i)
or would be more internals?
Uruchima is offline   Reply With Quote
Old 10-10-2012, 10:25 PM   #2
ShinjiML
Member#: 257231
2011 STI
You already have the intake, get a HFC and you'll free up more of your exhaust bottleneck, then follow with a set of Delta 1500 cams to help move even more air and make even more power, finish it off with a tune!
This was what I wanted to do with my 2005 RS, but I never got to that stage...
so,
HFC + cams + your CAI and exhaust + Tune!
ShinjiML is offline   Reply With Quote
Old 10-10-2012, 10:29 PM   #3
revin-it02
Member#: 287184
2005 RS-T & 15 Sport
so,
This, but you finihed the cams part... Just not the tune .
revin-it02 is offline   Reply With Quote
Old 10-10-2012, 10:40 PM   #4
rhino6303
Member#: 181314
2005 Impreza OBS SRR
05 Legacy GT RBP
I will save you the heartache; one of the only mods that is worthy of gaining hp is a twe el header. Search if you don't believe, it has been talked about over and over. Cams are cheap and easy but don't do what you would hope or expect.
rhino6303 is offline   Reply With Quote
Old 10-11-2012, 07:52 AM   #5
NH8991
Member#: 197937
2016 Golf R
Under the radar silver
TWE isn't the only one that produces a decent EL header, but it depends on your budget.
Cams - A year ago the only AVLS cam grind available from Delta was the 1000, I don't know if they've expanded their range since then. There are no massive gains anywhere as they are a 'torque grind' cam (to use Delta's expression).
The cams themselves are cheap, if you have to pay for labour then it gets pricey.
HFC - yep, you have 2, you can lose at least one and replace the other with a HF version.
Injectors/fuel pump - don't waste your money unless your stock ones are maxed out, which I doubt very much that they are.
Get a tune to optimise it all (with a higher octane fuel) and that's about it without spending really really silly money for minimal gains.
Then it's all about weight reduction....
NH8991 is online now   Reply With Quote
Old 10-11-2012, 09:18 AM   #6
ShinjiML
Member#: 257231
2011 STI
Well, you continued where I left off
@Op, sorry forgot your car has AVLS, so your cams options are pretty limited...
