Welcome to the North American Subaru Impreza Owners Club Sunday April 19, 2015
Old 10-11-2012, 11:12 AM   #1
simer1228
Member#: 171039
99 RSTi Type-R LTD
Black Diamond Pearl
Default Lean A/F ratio's all of a sudden [solved]
I noticed this morning as I was warming my car (99 RS w/ v5 EJ207) up, it was skipping a bit at idle. I just knew it didn't sound right and lo and behold, my car is idling at 17:1 when it should be around 14.7 +\- 1.0. I thought hey, maybe if I just start driving, it'll work the kinks out ...wrong! Ratios seemed normal under boost but at cruise it was still lean. Soooo I richened the mixture up via the commander and gently drove her back home.
I didn't get to take a look as I was on the verge of running late for work but I'm confident my AEM wide band o2 is accurate as its only a few months old.
I'm hoping that its just a vacuum leak or a dirty MAF sensor. If not, I'll toss my factory ECU in and see if that fixes the issue.
Does anyone have any ideas, other than what I already posted, why overnight my car would run lean?
Turned out to be a bad primary o2 sensor.
simer1228 is offline   Reply With Quote
Old 10-11-2012, 12:30 PM   #2
TommyAtomic
Member#: 257043
1993 JDM WRX Wagon
Dirty or defective MAF is possible but if it happened all of the sudden I would definitely not swap ecu's. Troubleshoot the problem you actually have.
I would bet on preturbo leak. Unmetered air. Could be an old cracked pcv hose or bad clamp.
Your location says vermont. I bet its starting to get pretty cold at night there. Old rubber hoses will absolutely crack from drastic temperature changes. Changes such as hot engine bay vs cold night air.
Dont make your initial troubleshooting more complicated than the actual problem.
TommyAtomic is offline   Reply With Quote
Old 10-11-2012, 12:56 PM   #3
simer1228
Member#: 171039
99 RSTi Type-R LTD
Black Diamond Pearl
Thanks TomTom. When I get home this afternoon, I'll check the inlet as last night was the coolest it's been this month. Hopefully it's something simple like an air leak.
Old 10-11-2012, 05:38 PM   #4
simer1228
Member#: 171039
99 RSTi Type-R LTD
Black Diamond Pearl
Didn't find any obvious leaks and I cleaned my MAF for the hell of it. Started it up and it idled and warmed up normally, with the as usual, slightly rich a/f ratios, just like it always has. But once the water temp got just above "C", I watched the a/f ratios lean right out to 17ish. RPM's also takes longer than usual to settle to idle.
I poked around the engine bay with some starter fluid and still couldn't conclude that I had an air leak.
Ideas?
Old 10-12-2012, 10:17 AM   #5
sonic rex 03
Member#: 62313
2003 16G 38mm ewg
sonic yellow
Did u check your o2 sensor operation?
sonic rex 03 is offline   Reply With Quote
Old 10-12-2012, 08:35 PM   #6
simer1228
Member#: 171039
99 RSTi Type-R LTD
Black Diamond Pearl
