Old 10-26-2012, 10:28 PM   #1
i_c_the_light
Member#: 88618
1994 Legacy
"The Silver Slug"
Default Just bought a phase II EJ22 by accident.
Okay, I didn't buy the engine by accident. The seller just didn't know what year the engine was and I had assumed it was phase I. I still bought the damn thing anyway. My original plan was to use the shortblock with 20H heads...
I probably already know the answer to this but just out a mere sliver of hope that I might be wrong because I know jack **** about SOHC engines but are there ANY sensors at all that are phase I compatible?
i_c_the_light is online now   Reply With Quote
Old 10-27-2012, 03:11 PM   #2
ballitch
Member#: 74907
98 cam'd EJ251
Wrx Tranny,slowr than ish
The intake manifold has the sensors...and you use the intake mani that fits your heads, so that shouldn't be an issue since,IIRC, the 20H uses an EJ25D style manifold. I would use the HG for the phase II EJ22 though, and not the 20H.
~Josh~
ballitch is offline   Reply With Quote
Old 10-27-2012, 03:53 PM   #3
i_c_the_light
Member#: 88618
1994 Legacy
"The Silver Slug"
~Josh~
That doesn't answer my question at all.
I'm actually using a G manifold. The H long block was in a garage fire and as a result all sensors were destroyed. The idea with the EJ22 is I use the short block and the sensors. But being phase II the sensors aren't likely to work in a phase I car. Which is why I was asking in case there might be something that will work from EJ22 SOHC engine.
Old 10-28-2012, 01:35 PM   #4
eg33GC
Member#: 206851
99 V4
EJ20K RS
H/G share about nothing sensor wise with the phase 2 engines, youre sol
Old 10-28-2012, 05:15 PM   #5
i_c_the_light
Member#: 88618
1994 Legacy
"The Silver Slug"
Ha! On the bright side I can sell the sensors online as "v5/6 wrx/sti parts"!
Message Board Statistics All times are GMT -4. The time now is 11:05 PM.
