Old 09-22-2012, 09:39 AM   #1
jake1191
Member#: 326058
2013 WRX
World Rally Pearl Blue
Default 2013 WRX Goals
Wel lI have had my 2013 for about 3 weeks now and have been loving it since the day I picked it up. What I am looking to do is a good reliable stock block car for a daily and want it to last a long time. I have already started doing the mods to the car that I can while I wait for Cobb to release support for the 2013s. In the end I would be content with +/-300whp with decent drivability and good reliability. Anything that will help the car spool faster or anything like that is worth it to me as well.
So far the mods I have done are:
TiC Super Shifter Kit
I have on the way:
Nameless Catback(4in mufflers and non-resonated)
Group-N Engine Mounts
Group-N Trans Mount
TiC Crossmember Bushings
Torque Solutions Pitch Stopper
Torque Solutions Driveshaft Mount Bushings
Now my question is for my end goal what should I do to the car performance wise? My thoughs were Nameless Downpipe(Catted), Process West Top Mount, Cobb SF Intake w/ Box, and an Aeromotive 340lph fuel pump, all buttoned up with a dyno tune. Are up-pipes with or without EWG worth it? I also see nameless is working on headers/manifolds would these be worth waiting for before I go past stage 2 and get the dyno tune? Anything else I should add to my list or anything I should change performance wise?
jake1191 is offline   Reply With Quote
Old 09-22-2012, 10:28 AM   #2
redline23
Member#: 285799
2012 WRX 5-Door
Just remember that the more power you add, the more likely you will need engine or transmission rebuild. For reliability, I would wait for a bit to make nothing breaks due to factory defects before adding more power.
I would still do a stage 1 tune. I had feedback knock completely stock on my 2012 WRX with 93 octane. Had very minor amounts of knock on the Cobb map too. Currently running torque performance stage 1 and it is running great.
Parts list looks pretty good. Consider a set of 22 mm whileline sways and kartboy endlinks. Car felt so much more planted.
I'm getting a nameless cat back with 5" mufflers and resonated mid pipe. Can't wait for it to arrive.
I think most people will tell you that ewg is not worth it on stock turbo. I remember reading a post on here about that, which said that ewg on stock turbo is still decent and will help with spool. I would find the thread yourself and read it. I may remember incorrectly on the ewg part of my post.
redline23 is offline   Reply With Quote
Old 09-22-2012, 11:10 AM   #3
jake1191
Member#: 326058
2013 WRX
Started a thread in the suspension forum about all that stuff. The plan is to do all the suspension and other mods before stage 2 which will give me time to find any defects in the engine n trans.
In due time I will start building another engine for the car which will be completely built. As for the trans I am not sure of what options I have and can't seem to find what these newer trans can take.
Old 09-22-2012, 11:27 AM   #4
rob1n1
Member#: 276425
2013 335is
Alpine White
Find a good tuner (local or an e-tuner) and tell them your power goals. Then listen and do what they say.
Keep in mind that 300/300 on one dyno could be different from another dyno. But as long as you're satisfied with the power, numbers are just a guideline.
rob1n1 is online now   Reply With Quote
Old 09-22-2012, 12:43 PM   #5
cruisnhard
Member#: 254408
2008 Impreza WRX
Clark Turner does an awesome job. I heard the nameless a couple days ago in person and it sounds amazing. I also did the suspension first and it changed the whole car for the better.
cruisnhard is offline   Reply With Quote
Old 09-22-2012, 01:44 PM   #6
bacalhau16
Member#: 297565
2011 WRX hatch
If all you would like is around 300whp, then stage 2 with a good tune will get u there. The intercooler may not even be necessary.
An EWG on the stock turbo is not a bad idea, but again not necessary for your goal. Also, they work great with the vf52 for holding higher boost and better control of that boost.
Im not a huge fan of changing out the headers, up pipe and such. I just don't see the need for it unless you want bigger numbers. Stage 2 should be made simple. Save that money for other Mods like you have already begun with.
Good luck with the car.
bacalhau16 is offline   Reply With Quote
Old 09-22-2012, 01:56 PM   #7
Unabomber
👌 Big Ron 👌
Member#: 18062
on car parts so PM
me b4 j00 buy
Read post #4 again. Now stop being pig headed and really read post #4 again. That is the key to you concentrating on getting what you want while spending the LEAST amount of money. By listening to other advice you will talk yourself info an expensive circle-jerk and do nothing.
Old 09-24-2012, 10:25 PM   #8
the_truth
Member#: 332140
Chapter/Region: HIIC
2013 WRX
Any advice on a good e-tuner? Sorry for the thread jack, but I liked the advice being given and thought that a bump might help too!
the_truth is offline   Reply With Quote
Old 09-24-2012, 10:40 PM   #9
BigRob74
Member#: 305107
2016 GT 5.OHH
DIB
www.torquedperformance.com
BigRob74 is offline   Reply With Quote
Old 09-25-2012, 02:36 PM   #10
SWP n Gold
Member#: 110783
2010 WRX
E-tune: Torqued Performance
Dyno: IAG Performance is 4 hours away from you
SWP n Gold is offline   Reply With Quote
Old 09-25-2012, 02:44 PM   #11
Tripintaz
Member#: 245218
2013 STI Limited
Downpipe + pro tune will get you what you are looking for. Keep in mind Subaru may reject any warranty work on the drivetrain if you do these mods. If that is not ok with you then get a Cobb AP and a TP Stage 1 map and call it a day. Then if you need to go to dealer just unmarry the AP and take it in.
Old 09-28-2012, 05:04 PM   #12
the_truth
Member#: 332140
2013 WRX
just out of curiosity, if something DID happen that would require warranty work done while on a tune, why can't you just put the stock tune back on? Can Subaru pull up your car's tune history?
Old 09-28-2012, 05:26 PM   #13
S1CkWrx
Member#: 325249
2012 wrx
dgm
you have to remove the parts that you added on then flash back because your car will not run correctly and have more problems to deal with.
S1CkWrx is online now   Reply With Quote
Old 09-28-2012, 06:14 PM   #14
Tripintaz
Member#: 245218
2013 STI Limited
You would have to remove the aftermarket parts, remove the tune, and hope Subaru does not suspect anything and check my ECU. Not to mention that is dishonest.
Old 09-28-2012, 06:23 PM   #15
nate_fisher
Member#: 270482
2011 turbotek fxt
[email protected] 4eat xt record?
Turbotek tuning is a great e tuner his name is ray and he is a real good guy.
nate_fisher is offline   Reply With Quote
Old 09-28-2012, 06:25 PM   #16
codesoccer
Member#: 179573
2002 MBP Bugeye
Flip Flop Tuned on corn
Phatbotti. Mikey and Ron are amazing.
codesoccer is offline   Reply With Quote
Old 10-12-2012, 12:37 PM   #17
jake1191
Member#: 326058
2013 WRX
As I stated in another thread my plans have changed.
Sitting at my house next week will be:
Nameless down pipe
Process west intercooler
Dw65c fuel pump
Accessport
What I want to know is what Max whp can I make on a stock engine? I have no issue buying a bloutch or amr turbo and some injectors to get a good safe number.
Suggestions on what to do?
Old 10-12-2012, 12:45 PM   #18
SWP n Gold
Member#: 110783
2010 WRX
Nameless down pipe
Dw65c fuel pump
Accessport
There's no magic number of what you can make on a stock motor; too many variables. What are your plans for the car? You haven't mentioned that yet.
Old 10-12-2012, 12:45 PM   #19
the suicidal eggroll
Member#: 51961
2005 STi
2012 WRX
I would keep it under 350whp for both the engine and transmission's sake.
Old 10-12-2012, 01:12 PM   #20
jake1191
Member#: 326058
2013 WRX
Car will be my daily but it will occasionally see some track/auto-x time n possibly some rally use.
Old 10-12-2012, 01:15 PM   #21
Member#: 51961
2005 STi
2012 WRX
If it's your daily, then keep it at stage 2.
Old 10-12-2012, 01:27 PM   #22
jake1191
Member#: 326058
2013 WRX
I am already dead set on what torqued performance calls stage 3. Which is stage 2 plus the intercooler fuel pump and ebcs
Old 10-12-2012, 01:51 PM   #23
PROcede
Member#: 293500
2015 FXT Stage 2
CWP
That's what I'm running and its great. Honestly I got dynoed and its putting down some impressive numbers for just a stage 2 set up plus intercooler/FP.
PROcede is offline   Reply With Quote
Old 10-12-2012, 01:55 PM   #24
Dave D.
Member#: 130990
06 Red Ltd.Wagon
20g-xtr 427/427 JJtuned
Sounds like a good, dependable plan. The difference over stock will amaze you.
Old 10-12-2012, 01:56 PM   #25
SWP n Gold
Member#: 110783
2010 WRX
For daily driving/auto-x/rally, the stock turbo with all the bolt-ons will be the best turbo, to be honest. A bigger turbo is just going to shift your powerband to the right, which is the opposite of what you want for the type of driving you do.
