Old 10-11-2012, 08:27 PM   #1
02nismokiller
Member#: 322963
04 wrx
psm
I just moved up a few months ago from Florida and I had my 04 wrx tuned with Jester Tuning at Titan Motorsports and he did an amazing job. But now that I'm in upstate NY and the weather is starting to be pretty cool (40-50*f)... So I went tonight for a fun spirited run and my car is running ridiculously rich at 10.0 flat (reading afr with my aem uego wideband) and when it reaches 5500rpm it bogs really bad and I let off the gas... I'm only running 18psi, bigger fmic, turboxs bov, intake, and 3" tbe
I'm in upstate Patterson NY
Thanks in advance
02nismokiller is offline   Reply With Quote
Old 10-11-2012, 08:48 PM   #2
quazimoto
Member#: 70395
So..........what's the question?
quazimoto is offline   Reply With Quote
Old 10-11-2012, 09:15 PM   #3
02nismokiller
Member#: 322963
04 wrx
psm
Why was it that when I was in Florida and her tuned she was running awesome and now that I moved up to NY the car is super rich and bogging past 5500rpm... What's wrong? What's causing this?
And no I ain't new to turbo cars as I also have a turbo sentra spec v that I built...
Old 10-11-2012, 09:29 PM   #4
SpecBlitzed
Member#: 331188
No smart ass here. Air becomes thicker (dense) the cooler the air becomes. Your car was tuned in a relative humanity density air point. ( Flordia very high humanity and probably high 80 90 degrees) Now the colder air is thicker meaning there is a lot I say a lot more air being brought into the engine. The ecu thinks the motor is at higher rpms due to more air flow. Turn your boost up to compensate the richness, but don't do this because this = excessive boost pressures. It would help correct you air fuels ratio but will mess with other shiz it.
SpecBlitzed is offline   Reply With Quote
Old 10-11-2012, 09:39 PM   #5
the suicidal eggroll
Member#: 51961
2005 STi
2012 WRX
Holy crap that's so incredibly wrong I don't even know where to begin...
No offense, but you should probably stick to the Newbie forum and stay out of Technical for a while.
Old 10-11-2012, 09:45 PM   #6
BlackEyeII
Member#: 65140
2007 STI Limited#213
05 STI (rip) 03 WRX (rip)
oh the relative humanity of it...
I wonder what your temperature compensation table looks like?
Also, has anything else changed with the car? 10/1 ratio doesn't seem like it should cause the car to bog badly, something else may be up. I would check everything and make sure you don't have a boost leak after the turbo. I am no pro but if your using the MAF and you loose air after it has been metered it could theoretically cause a rich condition.
That being said I have blown up two STI's so my name is mud.
BlackEyeII is offline   Reply With Quote
Old 10-11-2012, 09:55 PM   #7
02nismokiller
Member#: 322963
04 wrx
psm
Originally Posted by BlackEyeII
+11ty billion
You guys talking to me or specblitzed?
Old 10-11-2012, 10:02 PM   #8
Member#: 51961
2005 STi
2012 WRX
Talking to specblitzed
Your issue sounds like a boost leak to me.
Old 10-11-2012, 10:51 PM   #9
02nismokiller
Member#: 322963
04 wrx
psm
I'll do a boost leak later in a bit... Nothing else has been changed nor touched... Lets hope it's just a leak lol
Old 10-12-2012, 06:28 PM   #10
02nismokiller
Member#: 322963
04 wrx
psm
So I have a leak right where the intercooler meets the bov... I sprayed soapy water and saw bubbles
Old 10-13-2012, 04:11 PM   #11
02nismokiller
Member#: 322963
04 wrx
psm
Any other ideas? Now I can't even build boost and its pig rich!! I can email someone my data logs...
Old 10-13-2012, 04:15 PM   #12
Member#: 51961
2005 STi
2012 WRX
Did you fix the leak? Do you have an exhaust leak? Have you taken any logs?
Old 10-13-2012, 04:33 PM   #13
02nismokiller
Member#: 322963
04 wrx
psm
Lol exhaust leaks won't do this... I did find a boost leak where by bov mounts to in my tmic... I can email my logs to someone...
Old 10-13-2012, 04:46 PM   #14
Member#: 51961
2005 STi
2012 WRX
It will if it's between the engine and the uppipe.
Old 10-13-2012, 07:01 PM   #15
lukeskywrx
Member#: 59837
2004 Spec-C Type RA
What MAF? -Speed Density!
Similar thing happened when my old uppipe cracked in half, screwed up fueling all over the place.
lukeskywrx is offline   Reply With Quote
Old 10-14-2012, 10:11 AM   #16
rkramer
Member#: 118209
2015 WRX Limitec
back to the first part, did you fix the boost leak? Logs are pointless, you have a leak, fix it!
Old 10-14-2012, 07:47 PM   #17
02nismokiller
Member#: 322963
04 wrx
psm
No not yet, I'm waiting for tomorrow that the Subaru dealer is open so I can order new gaskets...
Old 10-14-2012, 08:01 PM   #18
alexmartynyuk
Member#: 191967
2002 wrx
Captain America tuned
a boost leak will do that, also another thing could be that your drawing more air at colder temps and hitting untuned cells of your maf.
alexmartynyuk is offline   Reply With Quote
Old 10-15-2012, 05:23 PM   #19
BlazeRex
Member#: 268354
02 WRX 05 LGT
Slow Automatics
You could also have a failing sensor for the wideband. So many things could be happening here. Fix the leak and report back, good chance that's the problem.
BlazeRex is offline   Reply With Quote
