Welcome to the North American Subaru Impreza Owners Club Wednesday December 17, 2014
Old 10-10-2012, 06:30 PM   #1
trex93
Member#: 333368
Default P1507 Help...!
Hey guys I have a 2002 Subaru Wrx completely stock except for a motorsport exhaust (had it for 5yrs no probs) Now I recently installed a aftermarket BOV and apparently it was not bolted correctly to the adapter for the tmic. After accelerating quickly and shifting into fifth gear the BOV popped off and was un-attached from the fmic adapter. The car lost acceleration power and got the check engine light. I pulled over and noticed the BOV un attached I figured it was the only problem. I uninstalled it and installed the OEM BOV and scanned the cel code. The cel code given was P1507. I reset the ecu and let the car rest. I drove it this morning and it seemed to run fine for about 5 miles then the Check engine light came up again with the same code. The car runs rough and accelerates on its own when idle. Any ideas, help?
trex93 is offline   Reply With Quote
Old 10-10-2012, 06:59 PM   #2
Uncle Scotty
OK Houston
we have an Uncle
idle air control valve issue
search it
Old 10-12-2012, 06:27 PM   #3
V8Slayer
Member#: 111565
1999 Legacy 2.5GT
2007 Legacy GT Spec-B
P1507 can also be triggered by a bad neutral position switch, after replacing it my code went away.
http://forums.nasioc.com/forums/show....php?t=1196685 <- check this thread for more info on p1507
V8Slayer is offline   Reply With Quote
