Welcome to the North American Subaru Impreza Owners Club Sunday July 31, 2016
Old 10-13-2012, 02:03 PM   #1
subbi7
Member#: 241967
02 wrx
Default intercooler efficency
hi !
while i was tunning my car i saw that the air temp after the intercooler on wot was 158f and the ambiant temp was 85f .
is it ok?
subbi7 is offline   Reply With Quote
Old 10-13-2012, 02:09 PM   #2
the suicidal eggroll
Member#: 51961
2005 STi
2012 WRX
How were you measuring the air temp after the intercooler?
What turbo/boost/other mods?
In general, no, that's horrifically hot. That said, you've given us absolutely no information to work off of, so who knows.
Old 10-13-2012, 02:30 PM   #3
subbi7
Member#: 241967
02 wrx
sorry for the miss of info...
it gt30 bolt on turbo with "big" top mount intercooler on 1.4 bar of boost.
i run haltech ecu and the air temp sensor located after the intercooler.
Old 10-13-2012, 03:02 PM   #4
Member#: 51961
2005 STi
2012 WRX
gt30 is too big for a TMIC IMO, and you're seeing why. Unless you're running water injection or something else to help cool it back down, TMICs just don't have the necessary air flow from the hood scoop to cool that much charge air.
For comparison's sake, I'm running a rotated gt30 with a Turbo XS FMIC and my IAT/MAF located in blow-through. At 20 psi WOT and 85 deg atmospheric, my post-IC IAT is around 90, 95 if I'm coming right off of a heat-soaked idle. 90 deg air is 11% more dense than 158 deg air. That means 11% more air at the same pressure, and close to 11% more power, even ignoring the fueling/timing compromises you'd have to make to keep 158 deg air from preigniting.
Old 10-13-2012, 04:39 PM   #5
NSFW
Member#: 140444
05 Stage Free LGT
ATP 3076, 6MT, AVO FMIC
OMG, an intercooler thread with actual temperature measurements.
Kudos to both of you.
Sounds like a GT30 really does need a FMIC.
Old 10-13-2012, 04:42 PM   #6
subbi7
Member#: 241967
02 wrx
so what is youre whp/tq?
Old 10-13-2012, 04:51 PM   #7
Member#: 51961
2005 STi
2012 WRX
Don't know. Last time I was on a dyno it made 340whp at 16.5 psi on 93 octane and the stock motor at close to sea level. I'm now running a hair over 20 psi (more once I get a new MAP sensor) on E85 at 5300 ft with higher compression and head work. So your guess is as good as mine.
Old 10-13-2012, 04:54 PM   #8
subbi7
Member#: 241967
02 wrx
how boost is safe in 93 oct?
p.s tanks for the help
Old 10-17-2012, 10:40 AM   #9
DerekB707
Member#: 220114
07 2.5i EJ257 6MT
Rotated BW S200sx-56
What TMIC are you running?
DerekB707 is offline   Reply With Quote
Old 10-17-2012, 03:15 PM   #10
Big_DeWeY
Member#: 37078
95 L
Blue-ish
I'm interested what top mount you are running too. Also was this measured on the road? If so what gear? Are you running any sort of a splitter?
Big_DeWeY is offline   Reply With Quote
Old 10-17-2012, 03:22 PM   #11
Paul
Member#: 56203
00 RSTI Coupe
Twin Scroll 2.5XTR EJ207
^this is key!!
YOu need a splitter/seal to direct as much air as possible over the TMIC
Old 10-17-2012, 07:01 PM   #12
Big_DeWeY
Member#: 37078
95 L
Blue-ish
Originally Posted by Paul View Post
^this is key!!
Totally agree. Air will always take the path of least resistance. If there isn't a splitter then the path if least resistance is over the back of the intercooler and down the firewall. This is why there is a MASSIVE misconception to what you can and can't run with a top mount.
Old 10-19-2012, 09:33 AM   #13
thisisntjared
Member#: 177891
06 wrx wagon
child seat/tow hitch cgm
i would like to know as well...
thisisntjared is offline   Reply With Quote
Old 10-19-2012, 12:35 PM   #14
kellygnsd
Member#: 32669
2007 2.34LR, EFR7670
LINK G4 hybrid STi
Where are you taking tour post intercooler temp measurement and with what type of sensor?
Old 10-19-2012, 04:56 PM   #15
1QUIKV6
Member#: 9427
2006 WRX STi
You can actually make good short term power with one of the upgraded TMIC's but keeping that power thru multiple pulls is near impossible. There just isn't enough real estate and airflow. Providing you aren't trying to road course the high(er) temps with a TMIC aren't the end of the world on E85 as knock isn't an issue. You just take a slight power hit when you've been n the gas for awhile.
158F is kinda crappy though. My ETS TMIC in 100F ambient (AZ) will hit around 138F post IC during a 4th gear 2000-7500 rpm pull at 26 psi and 3000' altitude (3.0XT-R). Although the retune/checks are done I haven't paid attention to WOT IAT's since I moved to KS a few weeks ago. Been digging seeing <70F IAT's while putting around though.
1QUIKV6 is offline   Reply With Quote
Old 10-20-2012, 09:58 AM   #16
Member#: 51961
2005 STi
2012 WRX
As I mentioned in post #4, I'm using the stock IAT in blow through.
Old 10-20-2012, 12:35 PM   #17
subbi7
Member#: 241967
02 wrx
its custom top mount very big.
im running the splitter+water spray on it...
and still high temp..
im really didnt want to go with fmic (because of turbo response)
but it seems that i have no other options...
Old 10-20-2012, 01:16 PM   #18
Member#: 51961
2005 STi
2012 WRX
On a gt30 it's not going to make much, if any difference.
Old 10-20-2012, 04:40 PM   #19
aboothman
Member#: 127745
06 WRX 30r 6 speed
99L EJ255 6 Speed
Agreed. You will learn to roll into the throttle quickly enough anyway. My 30r w/ fmic is responsive enough to be fun... Unless I expect to go WOT at 2500 RPMs and move instantly. It actually changed the way I drive turbo vehicles I'm general... Whether my swapped GC, or my work f450 or International
aboothman is offline   Reply With Quote
