#101 | |
Member#: 104200
Vehicle:828 WHP BUGEYE Street Proven Performance |
I just pulled some Edward Cullen Twilight moves and stopped the car ![]()
#102 |
Member#: 81102
#103 | |
Member#: 188598
Vehicle:2002 Built v7 ej207 Holset power ;) |
#104 |
Member#: 64908
Vehicle:10.8 XT+ Real stock turbo record holder 11.4 |
Adrians competion in the shop..lol... 6766 FWD Face @ 46psi c85 fuel.. This one trapped 144 with 680
#105 |
Member#: 127704
TXIC
Vehicle:2013 Leggy Scooby no4 - huntin for 5 |
This makes me grin like a Cheshire cat
#106 |
Member#: 265589
NESIC
Vehicle:2004 STi GT35R'd WRB |
#107 | |
Member#: 193757
Vehicle:2006 XTI Limited OBP, Junior tuned |
gotta go change them now![]() |
#108 |
Member#: 184267
#109 |
Member#: 81102
#110 |
Member#: 278519
SCIC
Vehicle:KBiz KeeganLB 30rSTI phatron tuned |
Did the head on that stop you from reving further? When do you think it would stop making power 10-10.5k and over 1000whp? Thats amazing
Ba-ZING |
#111 |
Member#: 232458
SWIC
Vehicle:2008 STi (OBP) CAMTuned |
Wow!!! That Evo holds over 500ft/lbs to redline!!
#112 |
Member#: 257195
South East
Vehicle:2004 WRX 2.1L 12k miles strong |
Pretty awesome where is the video of 900 HP
#113 |
Member#: 193757
I would think it's the rotational forces that prevented higher revs. 9-9.5K is pretty crazy for a 2.5L Subaru. I would love to see what this FFT setup would do on a 2.35L de-stroked 2.5, 4mm long rod motor
![]() But that's a pretty crazy power band for a Subaru 500+ HP and TQ for 4K rpms ![]() Can't wait to see what this does in the 1320! |
#114 | ||
Member#: 64908
Both p&l cars see 9500-10000rpm @ 2.5ltrs. 0 problems We are getting a set of 17" drag radials loaned to us, so lets see what Xdrian can do.. lol |
#115 | |
Member#: 193757
Still a nice power band even if it's an evo Very nice Junior and Nightshift Performance!Not to divert from this awesome work but check out this thread and this Subie's power band. The Killer B headers I believe contribute to a not so typical Subaru graph. http://forums.nasioc.com/forums/show....php?t=2415750 What rods and pistons are on the p&l cars spinning those revs? |
#116 |
Member#: 316296
Vehicle:2006 STIROID GT3794@30psi |
Junior- Any plans on a higher boost run for the OP's car?
#117 |
Member#: 145795
NESIC
Vehicle:2001 Impreza RSTi |
hands down one of the sickest cars in the game! this is the kind of **** that should start trending .... cleen amazingly built cars ...... nahhhhh that'll never catch on
#118 | |
Member#: 64908
Remember on your own car!I'm going to try and get an RPM based graph soon, this thing hits and holds for a while.... to 8500rpm to more specific For comparison the P&L car holds over 850whp to 9800rpm P&L Spec Pauter rods and CP pistons, stock crank Yep!! 42-44psi after the track saturday I love it... All the nightshift cars end up like this though... Form and function, hella flush and hella fast.. |
#119 | |
Member#: 193757
Are you tuning at P&L any time this month? My car is running and will be in need of a good tune! |
#120 | |
Member#: 64908
Call the shop I think we have 2 slots, I dont know which of the 3 days though. Jr |
#121 | |
Member#: 108051
Vehicle:2005 TickingTimeBomb Jr tuned TT Sleeved |
If that Evo is a stroked motor what would you think would be a good rev limit? They need balance shafts just to reduce vibration at 2.0L add balance shaft delete and it only get's worse. Balance away and pray! Timing/E85 possibly? And a good setup will get you this. |
#122 | |
Member#: 64908
Some 2.3s will do 8500 others 9500.. Our 2.1did 10,500, the Magnus 2.2 will do 10-11k all day long. Depends how it is built, rod ratio, bore etc |
#123 |
Member#: 193757
10-4 including the clutch assembly! Even Subaru motors can rev to 9-10K if balanced well with the right rod ratio.
#124 |
Member#: 193757
Are you talking about the 26th-28th of this month? If those are the dates I could possibly do either the Monday afternoon or Tuesday. I will give the shop a call. Do you know how the E85 is right now here in the midwest, have they formulated it for the winter E70ish? thanks!
#125 | |
Member#: 108051
Yea the one's that usually aren't throw rod's threw the block! ![]() |
