Old 10-15-2012, 05:23 PM   #1
giosoccer20
Member#: 328622
1999 Impreza 2.5 RS
Default strange buffeting/ish noise coming from passenger side while driving
when i'm driving, (i think only when the gas is applied) i started to notice a sort of buffeting noise and vibration from underneath../passenger side-ish area a few days ago. Today, the noise started to get more prominent, and now, when starting after a stop, there were prominent chirping sounds coming from the same side (sounded like belts or something). My engine is rebuilt, and my timing chain was done like 1k miles ago. I know my car also has a bad center diff/viscous coupling (slow parking lot speed thuds, etc), but I wasn't going to change that until it became undrivable practically. Is this sound something tied in with the center diff.. or what could it be? I really do not know how to describe the problem any better, other than it sounds like when an oscillating fan makes that weird noise, lol. If i remember correctly, i can feel the thing through the steering wheel as well
and the car has aftermarket adjustable coilovers, not sure which brand
Also, the cv joints were replaced around 2 months ago.
any input would be greatly appreciated! thanks
giosoccer20 is offline   Reply With Quote
Old 10-15-2012, 09:26 PM   #2
Matt Monson
Member#: 832
99 2.5RS, '85 911
'73 914 and 2012 BRZ
Old 10-15-2012, 10:36 PM   #3
giosoccer20
Member#: 328622
1999 Impreza 2.5 RS
Yes its that hard to describe the problem lol
Old 10-16-2012, 11:50 AM   #4
KevinKe
Member#: 283593
2008 Impreza 2.5i
Red
Brakes? I had a rubbing sound coming from my brake on the driver side not long ago - ended up being the dust shield.
KevinKe is offline   Reply With Quote
Old 10-16-2012, 05:48 PM   #5
yarrgh
Member#: 80465
2001 2.5RS
Black Diamond Pearl
Fix the known issue first, then come back with questions.
Get a passenger to listen while the issue occurs.
Put the car up on jackstands, start up, put in gear. Does noise happen?
Use one of the multitude of audio recording devices available these days to record said noise. Post it.
Old 10-19-2012, 10:40 PM   #6
giosoccer20
Member#: 328622
1999 Impreza 2.5 RS
After taking a few more drives to better describe the problem, I diagnosed the problem myself as most likely being the wheel bearings. Went to my mechanic, as the problem became extremely prominent, and, low and behold, it was indeed the wheel bearings. the front right one was ridiculously shot, and so was the front left, but not as bad as the other. I may post a few pics just to show what the front right bearing did to the hub...ridiculous.
