Welcome to the North American Subaru Impreza Owners Club Monday February 8, 2016
Old 10-13-2015, 04:54 PM   #1
Ethan2.5i
Member#: 409573
2007 2.5i
Default Passing Washington emissions
Hey nasioc community,
I have a couple of questions.
I'm currently running some crappy ebay headers and an exhaust shop cat back. I'm not going to be able to pass emissions in December when I have to go in. My plan is to get this header/ mid pipe combo, and I would like to get the N1 catback exhaust from Invidia
Header/mid pipe combo: http://www.semotors.com/tsudo-1997-0...ytic-downpipe/
My question is do you think with this set up I'll be able to pass emissions? Or is there anything I can do to my current set up too pass Washington state emissions? I feel like there's no way I will with the set up I have now because I've had 2/3 cats removed, a bad exhaust leak from the cheap headers, and I've got a CEL on because of the O2 sensor. Any feed back much appreciated.
Oh, the car is a 2007 subaru 2.5i
Thank you,
Ethan
Ethan2.5i is offline   Reply With Quote
Old 10-13-2015, 05:38 PM   #2
James2.5i
Member#: 305063
2016 VDUBBB
Note: This downpipe included with this Headers removes the OEM catalytic converter, which will trigger a CEL (check engine light) because of increased emissions. In this case, CEL fix is included to avoid 98% check engine light to turn, but the light does not affect performance. (some vehicle might need oil relocation kit)
Honestly, find a an oem part on ebay/cl/junkyard. Any other aftermarket part will prob still fail you.
Do they do a visual/tailpipe test or just the OBDII?
James2.5i is offline   Reply With Quote
