Go Back   NASIOC > NASIOC Classifieds > Vendor 'For Sale' Classifieds > Services
Old 10-16-2012, 05:55 PM   #1
kineticmotorworks
Vendor Sales Rating: (1)
Member#: 250944
Default Performance Services-For the harsh New England Conditions
Kinetic Motor Works is a complete performance service center, able to take on
the smallest or largest projects. Whether you need help installing sway bars
or a complete engine build and rotated turbo system, we are here to help.
We are experts with the entire Subaru line of vehicles, you can feel comfortable
knowing your vehicle is in good hands while the work is performed.
Your satisfaction and comfort during the service is very important to us.
We are here to build long term customer relationships, not short
term self serving inflated service tickets.
Performance Service List:
Engine Building and or Replacement
Turbo Upgrades, Stock location or Rotated
Professional Dyno Tuning Using COBB AccessTuner PRO and OpenSource
Suspension Upgrades: Coilovers, Springs, Shocks, Sway Bars, End Links
Alignment
Corner Balancing
Wheel and Tire mounting including aggressive fitments
Fender Rolling and Pulling
Intercooler Installations
Fuel System Upgrades
Competition Brake Packages
Upgraded Driveshaft and Axles
Upgraded Clutch, Pressure plates and Flywheels
Transmission Swaps, Differential Swaps and Gear Upgrades
Interior Gauges, Boost Controllers, Seats, Harness Bars, Harnesses etc.
Custom fabrication including turbo kits, intercooler piping, roll cages, and much more
Stereo and In Car Entertainment Installations
SHOP LABOR RATE: $98.00 per hour
30 & 90K Subaru Performance Service $499
-Oil change with Motul 8100
-WIX Performance Oil Filter & new drain plug washer
-Replace Transmission Fluid w/ Motul 75w90
-Replace Differential Fluid w/ Motul 75w90 (WRX) or Motul GEAR 300 LS (STi)
-Inspect cooling system, hoses and connections
-Coolant flush with Subaru coolant and Motul MoCool
-Air Filter Service (replace factory filter w/ K&N Drop-In, or clean & lubricate existing filter)
-Flush & replace brake fluid with Motul DOT 5.1
-Inspect brake pads and rotors
-Inspect brake lines and check operation of parking brake
-Inspect Front & Rear axle boots and axle shaft joint portions
-Inspect clutch operation
-Inspect Steering & Suspension
-Inspect tires & rotate
-Replace PCV Valve
-Top-off all fluids
-Replace fuel filter if required and inspect fuel system
-Perform full safety inspection
-Clean windshield
-Vacuum interior
60K Subaru Performance Service $599
-All services performed in 30K service
-Change spark plugs with NGK Iridium
-Complimentary engine compression test
105 Thousand Mile Service $899
-Replace timing belt
-Replace timing belt tensioner
-Replace 4 timing belt pulleys
-Replace water pump & water pump gasket
-Replace thermostat & thermostat gasket
-Inspect and replace crank seal if required
-Replace A/C & P/S belts
-Inspect and replace cam seals if required
-Clean windshield
-Vacuum interior
Timing belt & water pump service only $499
Subaru Performance Oil Change $89
-Motul 8100
-OEM Drain Plug Gasket
-Wix Premium Oil Filter or OEM Filter
-Clean windshield
-Vacuum interior
Drop Shipping is available also
Call today!
Contact Information
Kinetic Motor Works LLC
313 Kent Farm Rd
Hampstead NH 03841
[email protected]
www.kineticmotorworks.com
Monday-Friday 9-5
Saturday-Appointment Only
1-603-329-6083
kineticmotorworks is offline   Reply With Quote
Old 10-31-2012, 12:03 PM   #2
kineticmotorworks
Member#: 250944
Call or PM with any questions you may have or even questions about your build, we are here to help!
Old 11-06-2012, 10:09 AM   #3
kineticmotorworks
Member#: 250944
Did i see a snowflake? Time for the snows to go on, no salt on the enkei's!
Old 11-20-2012, 10:38 AM   #4
kineticmotorworks
Member#: 250944
Happy Thanksgiving Everybody!
Old 01-05-2013, 08:11 PM   #5
chrispsti
Member#: 342676
11' lexus isf
sti sold 2011 Lexus isf
Looking for a new shop after DSG closed. You guys will be hearing from me soon as I hear good things.
chrispsti is offline   Reply With Quote
Old 01-22-2013, 05:01 PM   #6
kineticmotorworks
Member#: 250944
Thanks, see you soon!
Old 02-25-2013, 10:04 AM   #7
kineticmotorworks
Member#: 250944
Bump!
Old 03-09-2013, 10:59 AM   #8
Ridetrails4130
Member#: 312833
2006 WRX Wagon
Kinetic is on the top of their game, dedicated, hardworking car enthusiasts who stand by their quality work, and you will too.
I scheduled an appointment march 4th for the 105k mile maintenance. After shooting the breeze for a few upon arrival rob talked in detail about everything that was going to happen and looked over all the parts of installation with me to ensure I knew exactly what was going on. As this service took about 4 hours I stayed in the shop watching the trailer park boys movie and some always sunny episodes, a good laugh always speeds up the time.
You can be confident when you are pulling out your wallet at the final transaction. I do recommend this shop as it was recommended to me.
Thanks again Kinetic, Joel
Ridetrails4130 is offline   Reply With Quote
Old 04-11-2013, 04:55 PM   #9
kineticmotorworks
Member#: 250944
Thanks, Joel!
Old 05-23-2013, 12:00 PM   #10
kineticmotorworks
Member#: 250944
Check out our new website, and follow us on face book!
