Old 10-16-2012, 10:39 PM   #1
ryan2.5impreza07
Member#: 262238
Default help with opensource 2007 2.5iT
i just turboed my 2007 2.5i with the avo turbo kit..i have 440cc injectors 255 walbro t25 turbo FMIC AEM wideband ect.. i just had it dynoed and it made 182 on 3psi... while i was getting it tuned my tuner tuned the fuel trims mint but then we had a problem with it going into open loop..after driving for a little bit the air fuels will read 13.3 on open throttle ful boost and not go much more richer then that but the car runs like it is running rich and as soon as he reflashes it the air fuels read 11s easy....im not sure why its having problems with the open and closed loop...i dont know if it goes into fail safe mode..we are both stumped..i tried to research on this but i cant find much...hope fully you can help me maybe if someone has a map he can work with or something..
please let me know if you have any ideas..
thank you
-Ryan
ryan2.5impreza07 is offline   Reply With Quote
Old 10-17-2012, 11:43 AM   #2
ryan2.5impreza07
Member#: 262238
no body can help me>?
Old 10-17-2012, 09:15 PM   #3
GrundleJuice
Member#: 165749
1982 Sex Machine
Flesh
Chk my reply in the engine management sub forum
Was the MAF table rescaled? Did you change the MAF housing from stock? (Not familiar with the AVO kit plumbing)
The injectors were rescaled in the tune?
What are your c, d fuel trims?
We're the load ranges rescaled for the flow increase? Is that possible or do you have to rely on your D range to handle everything above it?
Old 10-18-2012, 12:17 AM   #4
ryan2.5impreza07
Member#: 262238
the maf housing is stock...it goes from the inlet of the turbo right near the radiator support and the filter right is off the maf housing...ill try to upload pics of the set up.
my tuner has all the info about the tune...i dont know much abou tuning ive just been watching him tune it..
i know when he first tried to tune it he didnt have the correct ROM for it since its not wrx or a sti and alot of the options arnt avalible for him to access in his lap top..
im pretty sure the injectors were rescaled
ill try to get the fuel trims tommorrow
Old 10-18-2012, 12:20 AM   #5
ryan2.5impreza07
Member#: 262238
[IMG]C:\Documents and Settings\TEMP\My Documents\My Pictures\sj[/IMG]
