Go Back   NASIOC > NASIOC Subaru Models > BRZ Forum
Old 10-17-2012, 01:45 AM   #1
kayetealynn
Member#: 253304
2001 Impreza 2.5RS
Plus MOAR
Okay BRZ owners - Chano asked me to post this up for you guys.
Basically you'll need to go to a dealership to get these options changed because as far as I'm aware you can only access most of them via the Subaru Select Monitor that the dealership has. The BIU allows for certain things to be "customized" per each owner's preferences. Some things are available only on the limited BRZs - so keep that in mind. ALSO - Although I know how to access some of these I am by no means an expert and honestly don't know what all of these mean and whether or not their available on all trims. I've messed around with a few, but haven't revisited it since I recently put my BRZ in storage for the winter.
Example Picture of the SSM screen with options listed:
There are more - this is all I could grab from the literature I've read and I'll add more once I find them in the manual.
List:
[Wireless Control]
Description: Function to turn OFF/ON the wireless door lock function
Available Options: OFF or ON
Factory setting: ON
[Wireless Buzzer Resp]
Description: Wireless door lock buzzer response
Factory Setting: ON
[Hazard Answer Back]
Description: When the wireless lock switch of the transmitter is pressed, all hazard warning lights are illuminated simultaneously. All hazard warning lights illuminate twice when the unlock switch is pressed.
Factory setting: ON
[Open Door Warning]
Description: The buzzer sounds when the lock is pressed while any door is open.
Factory setting: ON
[Unlock 2 Operation]
Description: Function to unlock the driver’s door when the unlock switch of door control transmitter module set SUB-ASSY is pressed once, or unlock all doors when the switch is pressed twice. If the setting is OFF, all doors are unlocked when the unlock switch is pressed once.
Factory setting: ON
[Panic Alarm Function]
Description: Function to activate the anti-theft system when the panic switch of electrical key transmitter SUB-ASSY is held down for 1.5 second or more.
Factory setting: ON
[Wireless Auto Lock]
Description: This function turns ON or OFF the wireless auto lock function.
Factory setting: ON
[Auto Lock Time]
Description: This function controls the time from unlocking all doors until the activation of auto lock function.
Available Options: 330 seconds, 60 seconds, 120 seconds
Factory setting: 30 seconds
[Function code selection for wireless trunk opener]
Description: Function to change the method of opening the luggage compartment door by the door control transmitter module set SUB-ASSY.
Available Options: 1 time ON, 2 time ON, Long1 or Long2
Factory setting: Long1
[Wireless Buzzer Volume]
Description: Wireless door lock buzzer volume
Available Options: Level 7, Level 6, Level 5,Level 4, Level 3, Level 2, Level 1, or Level 0
Factory setting: Level 5
[Ignition Available Area]
Description: Function that sets the area that the key must be in before the engine switch can be operated.
Available Options: Front or All
Factory setting: All
[Parking Wait Time]
Description: Function that sets the period of time (lock confirmation time) that the door is prevented from being unlocked by operating the front door outside handle assembly after an entry lock operation is performed.
Available Options: 0.5s, 1.5s, 2.5s or 5s
Factory setting: 2.5s
[Trunk Open Mode]
Description: Function that opens the luggage compartment door when the driver has the electrical key transmitter sub-assembly and presses the luggage door opening switch assembly.
Factory setting: ON
[Display for ’Engine start possible’]
Description: Function to Turn ON / OFF of the Engine Start Indicator.
Factory setting: ON
[Smart Cancel]
Description: Function that enables or disables the entry and start system.
Factory setting: OFF
[Smart door unlock mode]
Description: Function that chooses the doors to be operated by entry unlock operation.
Available Options: All or Driver
Factory setting: Driver
[Touch Activation Over Threshold]
Description: The function that limits the consecutive entry lock operation to only 2 times can be changed between Active and Not Active. When in Not Active mode, there is no limit for the number of times that the consecutive entry lock operation can be performed.
Available Options: Active or Not Active
Factory setting: Active
[Lighting Time]
Description: Set the function to automatically turn off the interior light after all the doors are shut, when the interior light is set to the DOOR mode.
Available Options: 15/7.5/30 seconds
Factory setting: 15 seconds
[Light Sensitivity Adjustment]
Description: Adjusts the brightness of the MAP light
Available Options: Can't Remember
Factory setting: 0%
[I/L when ACC OFF]
Description: Set the function to automatically turn on the interior light by turning the ignition from ACC ON → OFF, when the interior light is set to the DOOR mode.
Available Options: Activated/deactivated
Factory setting: Activated
[I/L ON W/Door Key Unlock]
Description: Set the function to automatically turn on the interior light in accordance with the door unlock operation with the smart key or the mechanical key, when the interior light is set to the DOOR mode.
[Room Light when Aprchd]
Description: Set the function to turn on the interior light when the driver approaches the vehicle carrying the smart key.
[Interior Light Control]
Description: Set the function to turn on the interior light by a timer.
[Key Remind Sound]
Description: Setting of the warning cycle when the driver's door is opened while IG OFF or ACC ON
Available Options: 600 ms/900 ms/1200 ms
Factory setting: 1200ms
[Taillight warning buzzer]
Description: Setting of the function that sounds a buzzer when the driver's door is opened while IG OFF and tail SW ON
Available Options: ON/OFF
Factory setting: ON
[Vehicle speed warning buzzer]
Description: Setting of the function that sounds a buzzer when the vehicle speed reaches 100 km/h {MPH} or more
Factory setting: ON
[Ambient Air Temperature Setting]
Description: Function of adjusting the difference from actual measurement by increasing/decreasing the displayed temperature
Available Options: +3C/+2C/+1C/0C/-1C/-2C/-3C
Factory setting: 0C
[Driver Side Seatbelt Warning Buzzer]
Description: Function to sound the driver seat belt warning buzzer
Factory setting: ON
[Front Passenger Side Seatbelt Warning Buzzer]
Description: Function to sound the front passenger seat belt warning buzzer
Factory setting: ON
[Light Auto OFF Delay]
Description: Keeps the headlights on for a certain period of time after turning the ignition switch off and closing all doors with the low beam headlights on.
Available Options: OFF, 30 s, 60 s or 90 s
Factory setting: 30s
[DRL Function]
Description: ON/OFF of the DRL function
Available Options: ON or OFF
Factory setting: ON
[Rear Defogger Operation Mode]
Description: Changes the interval of the defogger switch (meaning defogger will automatically turn off after 15 or so minutes if set at "normal" and won't turn off if set at "continuous")
Available Options: Normal or Continuous
Factory Setting: Normal
[Key Low Battery Warning information]
Description: Enables or disables the sounding of the buzzer when the key battery is low and the engine switch is turned off after being on (IG) for 20 minutes or more.
Factory Setting: ON
[Key Left in Vehicle Buz]
Description: Function to warn when left the electrical key transmitter sub-assembly in the vehicle.
Factory Setting: ON
[IG ON Key Out Warning]
Description: Enables or disables the lock sensor function that sets off the alarm if the lock sensor is touched when the shift lever is in P (transmission A/T) and the power is ON.
Factory Setting: ON
[Security System]
Description: This function operates the theft deterrent system ON or OFF
kayetealynn is offline   Reply With Quote
Old 10-17-2012, 09:36 AM   #2
2point0
Member#: 150248
'13 BRZ Ltd WRB
'67 Mustang
Good stuffs right there. Thanks!
2point0 is offline   Reply With Quote
Old 10-18-2012, 03:05 PM   #3
RYU_007
Member#: 308624
Brilliant! Thank you!
On this one...
[Auto Lock Time]
Is there a way to turn this off completely?
Also, wish there was an option to automatically lock as you drive away but I hear no Subies have that
RYU_007 is offline   Reply With Quote
Old 10-18-2012, 03:51 PM   #4
chanomatik
Member#: 159474
2013 BRZ Ltd 6MT CBS
SNOSLO
Trust me. When it doesn't say "Off" as an available option, it really means it's not available.
I'm kind of agreeing on the auto-lock while driving thing, but I've been used to doing it myself for so many years on so many Subies that it's whatever at this point.
Old 10-18-2012, 05:10 PM   #5
kayetealynn
Member#: 253304
2001 Impreza 2.5RS
Plus MOAR
On this one...
[Auto Lock Time]
There's this function:
Factory setting: ON
that can be disabled... I'm pretty sure that would do it.
The function that you quoted I think is just to adjust the time if you have the wireless auto lock function turned on.
Old 10-20-2012, 03:29 AM   #6
Getagrip
Member#: 2045
BRZ
On this one...
[Auto Lock Time]
I totally wish there were these options, too.
Getagrip is offline   Reply With Quote
