Old 10-17-2012, 06:20 AM   #1
Layvon
Member Sales Rating: (135)
Member#: 195711
STi 04/05/06/07
Default Fuel Injector Clinic - Rails and Injectors
Well, now that my car is running, I wanted to do a little review of some of the parts that I purchased, that maybe aren't considered mainstream.
I bought my 2150cc injectors and rails from Fuel Injector Clinic. Couldn't be happier.
These rails went into my STi without a hitch. Granted, I do have all the stock stuff out already, but the entire start to finish of this project was about 20 min. I had a leaky AN fitting, and so I needed to take the rails off. Bryan and I had been PM'ing back and forth, and he asked if I could document a little about what I had to do for the install.
First thing you have to do is put the rubber piece in the TGV housing. she just falls in.
My picture showing the injectors sitting there turned out to be blurry as all get out. So I apologize for that. Basically all you have to do is put the two blue anodized washers on the bottom of the injector and feed it into the black ring. This is when I also plugged my clips in. At this point, lubricate the top injector o-ring, and the fuel rail hole. They dont snap in, so don't bother trying to hear a audible noise
Grab your fuel rail and get it over the front injector and use your bottom two fingers to guide the injector into the hole, same thing for the back.
Once sitting on the injectors, grab one of the allen bolts and get it started. I had issues with the back ones both times, so I started with the front. You cannot fit a 3/8" 6mm socket in there freely. This was my one complaint about these fuel rails. I was able to get it in there, but it wasn't 100% seated into the allen. I hand tightened with a allen key for both, then got the last 1.5 turns with the socket before checking to see how the injector looked.
You can see how the little blue oring is compressed. This is good. There is another oring up in the fuel rail as well. Take a look at the top of this page at the FIC logo.
tighten on fittings on either end, and test er out... I got lucky and the AN fitting was the culprit. 45psi as planned and no leaks on the rails / injector!
Make sure to let pumps prime for a while to get air out of system. I had drained the surge tank, so I had to cycle the key a few times to get the lifter pump to fill the tank up.
Overall, I think this is about as easy as it gets for STi guys switching to top feed. Install difficulty is a 3/10 if you have the stock system out already. If you have to start the day by gutting the old system out, expect to spend about 5-8 hours on this with a buddy if you have to make up lines and AN fittings.
One thing to note - these come with -6 male fittings. I already had -8 lines running to the rails, so I bought some -8AN / -8 ORB fittings and everything was hunky dory.
Any Questions, holler!
Layvon is offline   Reply With Quote
Old 10-19-2012, 10:17 AM   #2
NASIOC Manufacturer
Vendor Sales Rating: (0)
Member#: 270262
Thanks for the post and review, we're glad they're working out well for you!
We're trying to get the word out more about this as a great option for the side feed Subaru guys who are looking for a greater selection of quality injector upgrades.
If anyone has any questions about this setup please let us know and we'll be happy to try and help out.
__________________
-Bryan
Fuel Injector Clinic is offline   Reply With Quote
Old 12-13-2012, 09:15 AM   #3
tja1618
Member Sales Rating: (3)
Member#: 181995
2003 WRX
Thanks for the review. I'm looking to run a set of these rails and FIC 1000cc injectors on my WRX. Looks like a nice affordable custom fuel setup.
Any updates since the install?
tja1618 is offline   Reply With Quote
Old 12-13-2012, 09:13 PM   #4
Layvon
Member#: 195711
STi 04/05/06/07
Yeah - my car isn't running.
I have a air / fuel leak or a bad oxygen sensor. I've tried lots of tests and no dice yet, but have a spare O2 from a buddy on the way . Hopefully here next week
Old 01-15-2013, 05:09 PM   #5
NASIOC Manufacturer
Member#: 270262
Hey Layvon, just wanted to hop in to see how things are going now, hopefully you've been able to get the issues sorted out and are back to enjoying the car. Let us know .
__________________
-Bryan
Old 01-15-2013, 10:29 PM   #6
Layvon
Member#: 195711
STi 04/05/06/07
No not today - I was looking at buying a house FPR the first.time today! Exciting.
I did find the problem described above - bad O2
Hoping to get up n running soon. Once it was broke in I'm now tinkering with the link platform
Old 01-16-2013, 09:32 AM   #7
NASIOC Manufacturer
Member#: 270262
Awesome, hope the house hunting goes well (I think thats what you were saying)!
Let us know about the house and the car then
__________________
-Bryan
Old 01-16-2013, 11:15 AM   #8
sohchx
Member Sales Rating: (13)
Member#: 213634
2002 Impreza
Wow small world!! I had no idea you guys were members here. I need to get in touch with you about a setup. Had I known this I would have mentioned it to Yenz on the phone a few weeks ago.
Devin
ECM Tuning
sohchx is offline   Reply With Quote
Old 01-16-2013, 12:24 PM   #9
NASIOC Manufacturer
Member#: 270262
Ha, hey Devin! Yes we are on here, so help spread the word!
Get in touch when you have a chance and let us know what you're working on.
__________________
-Bryan
