Old 02-26-2013, 07:36 PM   #26
thisisntjared
Member#: 177891
06 wrx wagon
child seat/tow hitch cgm
awesome update! thanks for sharing! all this on a stock block and stock clutch??
thisisntjared is offline   Reply With Quote
Old 02-26-2013, 07:37 PM   #27
Slimsti
Member#: 155696
2007 BLK STI Dom3XTR
415/405 Precision Tuning
Ah the clutch is going. I was about to say what the hell is up with that graph. Lol
Slimsti is offline   Reply With Quote
Old 02-26-2013, 10:35 PM   #28
be0tch
Member#: 66206
2005 WRX STi
Stock block, stock clutch (slipping on meth map).
be0tch is offline   Reply With Quote
Old 02-26-2013, 10:39 PM   #29
Slimsti
Member#: 155696
Time for front mount,speed density and more boost. Lol
Old 02-27-2013, 10:42 AM   #30
be0tch
Member#: 66206
2005 WRX STi
It's actually on speed density now, sorry I must have left that out of my update. I think I could probably efficiently boost 25psi on my top mount and that would be plenty of power.
I don't particularly like the idea of removing my front bumper beam.
My short term plan is to replace the clutch, and perhaps drop in a built short block before the end of the year. There's nothing wrong with mine, but I don't want to end up stranded somewhere from a piston failure.
Old 02-28-2013, 04:03 PM   #31
mywifesSTi
Member#: 142709
07 STi Limited
FP HTA Green 372whp
Originally Posted by baisesti
Peak torque at 3800rpm???
my FP Green HTA only give me peak torque at 4800rpm. Am running APS top mount, 3" downpipe, 3" turbo inlet hose.
Any idea how to obtain peak torque earlier???
Wow thats odd. My Hta green hits peak tq @ 4k rpms with a fmic. Are you running el headers?
mywifesSTi is offline   Reply With Quote
Old 03-01-2013, 10:20 AM   #32
be0tch
Member#: 66206
2005 WRX STi
My peak torque now seems to be around 4100 rpm. It was previously 3800 rpm, and I have a feeling that if I get a proper dyno (w/o slipping clutch) run on the meth map, that the meth map will peak at like 4800rpm.
I do agree that baisesti's peak tq should probably be lower in the rev range. Probably should get an EBCS and EWG if he doesn't have them already.
Old 03-03-2013, 10:40 PM   #33
Slimsti
Member#: 155696
Wow u saw 22/24 increase off just 1psi on ur 50/50 meth map from ur 93 map. With a non slipping clutch,a fmic and 25-27psi you'll easily hit 450 and that thing will be an animal on the street
Old 05-04-2013, 12:27 PM   #34
be0tch
Member#: 66206
2005 WRX STi
Life update: I had the car retuned on May 1. Here are the 93+50/50 meth numbers from the 32nd dyno pull in a row (heatsooooaaaakkk)
This is with an aftermarket clutch and lightweight flywheel. All other mods are the same as before. For whatever reason the car sounded a lot louder this time, but nothing has been changed with respect to intake/exhaust/whatever. It did also break free from a dyno strap and almost go driving through the shop which was pretty hairy for a second.
377/382 is pretty decent in my opinion considering warm day and insane number of pulls.
I'll be going back in the next few weeks to open up the EWG and see just how much I gain. My theory is around 30whp but we'll see.
Old 05-04-2013, 04:34 PM   #35
DavC825
Member#: 201736
12 IS-F..its white
07 Sti Blk
I pretty much have the same set up as you. I made 357/367 on a dynojet... peak torque is at 4350rpm.
DavC825 is offline   Reply With Quote
Old 05-04-2013, 08:15 PM   #36
be0tch
Member#: 66206
2005 WRX STi
It is a very fun setup. That must be a low reading dynojet because these turbos make a lot of power - either that or are you running very low boost?
Old 05-04-2013, 08:45 PM   #37
DavC825
Member#: 201736
12 IS-F..its white
07 Sti Blk
I'm running 21psi. It's a stock 07 sti motor with 100k on it. I don't want it to blow up. Yet. lol
It's definitely a fun set up for everyday driving.
Old 05-04-2013, 10:03 PM   #38
kyd
Member#: 295685
2011 WRX
did i miss the boost somewhere? I know the last graphs were at 23psi, was this at the same level?
kyd is offline   Reply With Quote
Old 05-04-2013, 11:20 PM   #39
be0tch
Member#: 66206
2005 WRX STi
Yeah, its missing from the chart. 22.9 psi. The backpressure from my ewg reroute is killing hp, or at least I think so.
Old 06-05-2013, 01:15 PM   #40
be0tch
Member#: 66206
2005 WRX STi
My downpipe is taking a little longer in ceramic coating than I expected, but in the meantime look what has arrived!
An external wastegate muffler from a 1987 Porsche 911 Turbo (Porsche 930)! Hopefully my downpipe comes in soon so that I can get this welded on and a retune done.
Old 06-06-2013, 09:34 AM   #41
LittleBlueGT
Member#: 96204
2013 STI GR
Originally Posted by KurtP View Post
Interesting comparison. I wonder if an aftermarket CB would have made a difference when plumbed back?
How far from the turbine outlet was the WG dumped back in?
It does make a difference.
I had an EWG on an hta68 (c/w TBE) and I had it plumber back in, it made about 3 whp less plumbed back in for me.
LittleBlueGT is offline   Reply With Quote
Old 06-06-2013, 12:44 PM   #42
TROLL
Top Scoob 006
Member#: 14424
BugI w/ 07 STi Swap
www.TriStateTuners.com
Wo... where can I get an EWG muffler like that? I want to run one!
TROLL is offline   Reply With Quote
Old 06-06-2013, 12:45 PM   #43
be0tch
Member#: 66206
2005 WRX STi
I got this one on ebay, but you could check wherever used 930 parts are sold. There are also probably plenty of aftermarket solutions (tigwerks ewg mufflers, supertrapp, and the like).
edit: and there's this for the low, low price of $795 (lol) http://www.ebay.com/itm/Porsche-965-...67fb85&vxp=mtr
Old 06-07-2013, 09:30 PM   #44
DavC825
Member#: 201736
12 IS-F..its white
07 Sti Blk
FP makes a 10cm exhaust housing for the hta green now.
Old 10-05-2013, 12:39 PM   #45
be0tch
Member#: 66206
2005 WRX STi
I wonder what kind of gain I'd see with the 10cm hotside over the 8cm.
Old 10-06-2013, 02:58 AM   #46
Slow09
Member#: 346769
2009 subaru wrx
DMG
This is a nice build sir good work. I will be runing the fp green hta on 93pump prob @20psi I will post up dyno numbers when I am done.
Slow09 is offline   Reply With Quote
Old 11-11-2013, 04:06 PM   #47
be0tch
Member#: 66206
2005 WRX STi
Quick update for you guys. The car got a built motor with cams and a retune on 93+meth.
Event: dyno pull
Ambient Temp: 50 degrees F
Elevation: At sea level.
Weather: autumn day. dry.
Tires: Blizzaks - 225/45/17
Car: 2005 STi
Tuner: John Shafer (Akuma Motorsports)
Dyno Info: Mustang
Transmission: 6spd stock gearset
Gear: 4th
Peak HP at RPM: 430whp @ 6600
Peak Torque at RPM: 390 lb-ft @ 5100
Baseline hp/tq for a stock on same dyno: ~220 for STi 2.5L
Target Boost: 25.5psi tapering slightly at redline
Target AFR: unknown
Fuel: 93 octane unleaded pump gas + 75% meth / 25% water
Engine/Power Modifications: FP HTA Green Turbo 8cm^2 hotside, 1100cc injectors, Process West top mount intercooler, TGV deletes, top feed conversion, 300lph fuel pump, turboxs catless downpipe, Maddad whisper dual 3.5" exhaust, aftermarket EWG uppipe. Invidia equal length headers, 73mm KStech intake. Perrin 3" turbo inlet. Perrin fuel rails. Grimmspeed EBCS. 38mm tial wastegate venting to atmosphere, grimmspeed pulley. ACT clutch and lightweight flywheel. Aquamist HFS-3 methanol kit running 75% vp m1 methanol, 25% water. Aeromotive fpr. Fully built motor, kelford 199-b cams. Tial Q 50mm blow off valve. Apologies if I forgot anything but I think that's it.
Suspension Modifications: feal rebuilt sti struts on rce black springs.
Other Modifications: full interior and large subwoofer box in trunk.
Car is running great and pulls hard to redline.
Old 11-13-2013, 10:41 AM   #48
be0tch
Member#: 66206
2005 WRX STi
Old 11-13-2013, 05:51 PM   #49
bilt2run
Member#: 134211
Why wouldnt you go back to the same dyno/tuner..for repeatable results. Also this is the same company that just posted how low there dyno reads yet this time around the numbers are more in line with shop x...hmmmmmm?
Either way looks like a clean pull
bilt2run is offline   Reply With Quote
Old 11-13-2013, 07:50 PM   #50
be0tch
Member#: 66206
2005 WRX STi
I can't speak about the way the dyno reads. I haven't studied the output and I don't have a "before" baseline there.
I don't have any hard feelings about the prior work or tune at PAS.
I'm not surprised the numbers are higher though, the old motor was tired and now the boost is a few psi higher. I had a restrictive ewg recirculation (my idea, not PAS) and that hurt peak power. The car is cammed now and wasn't then. Higher percentage of meth now too. And it was catted last time, not catted now. Apples and oranges, I think.
I can go dyno it at PAS, if you want, internet person .
